Results 1 to 16 of 16
Thread: My Knob is STIFF need help
    May 2008
    41
    ;D On my Via Venezia that is !!!
    When I turn the steam knob its very tight.
    History: 4 years old, on every day, steam button has been left on a few times,
    never been serviced however has been cleaned.
    Shane
    DONT USE
    Jan 2008
    432
    Re: My Knob is STIFF need help
    hi hornet
    the staem valve in the via venezia is brass
    if these are not lubricated they become stiff
    if they become stiff, and continue to be used
    it damages the thread
    sometimes the shaft needs replacing other times complete valve
    needs serviocing
    graham
    Jul 2008
    Blue Mountains
    136
    I thought I was on the wrong forum when I saw that subject
    May 2007
    Perth, Western Australia
    3,056
    Me too!!!
    May 2008
    41
    Hi Graham,
    How do I lube it up.....so to speak.
    Lizard,
    So what forums do you usually visit ??
    Shane
    DONT USE
    Jan 2008
    432
    you pull it
    apart
    Jul 2008
    Port Fairy
    2,993
    Couple of tips dont use KY Jelly for lube (its water soluble) Vaselline tastes bad so try your local bearing shop for Food grade grease or lube ;)
    If that fails seek out the services of a Professional to make you knob less stiff :o
    Senior Member Coffee2Di4's Avatar
    Sep 2008
    Ipswich, QLD
    1,472
    All I can say is that, Im completely disappointed... ;)
    Mar 2008
    554
    In recent communications I have discovered that Urnex is using Viagra as an anti-foaming agent in their espresso machine cleaner. If you have recently cleaned your machine it could explain how the knob became stiff. If the stiffness lasts more than four hours you are advised to consult your nearest appliance repair centre.
    May 2008
    41
    Has anyone actually done a service (Lube) on this machine?
    Ive taken it apart (steam knob handle was interesting) but not sure where to put the lube?
    Shane
    Jul 2008
    Port Fairy
    2,993
    Oh you actually wanted a serious reply ;)
    If it is like most valve assemblies then the area that needs lubrication is the valve stem where it goes past the gland and packing. Do not lubricate the valve face where it seals.
    The pic is just for reference and placing a name to the bits.
    Apr 2007
    78
    I have to congrat all respondents for one of the funniest threads I have read in many a long day.
    May 2008
    275
    Id say let a professional service your machine thoroughly with lubricant to rub out any stiffness. It should blow very well after a good servicing (steam that is).
    DONT USE
    Jan 2008
    432
    hi shane
    when you dismantle the steam valve you will have a brass spindle (or valve stem as per previuos pic) with a thread on it. this is where the it needs lubing
    we use a high temp food grade grease
    if the thread is damaged, then a new shaft needs to be fitted
    graham
    Jul 2008
    Port Fairy
    2,993
    If you are still having problems then try Spoilers Relaxation Centre in Ringwood for your nearest professionals ;)
    May 2008
    41
    I had a laugh...Cyril & Bean- thanks for the pic
    Graham, Ive taken (Broken) (will get a new one from saeco) the knob off, however the part that needs to be lubed I cant seem to get it off ( brass spindle or Valve stem OR SHOULD WE just call it a shaft & be done with it.) is there a trick to it ? (another can of worms) thanks
    Shane
  1. A Stiff Coffee in the Morning or all day?
    By TEPIN in forum General Coffee Related...
    Last Post: 7th July 2009, 04:28 PM
  2. Giotto - Stiff Lever
    By Boris in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th July 2008, 08:57 AM
  3. If you actually want stiff froth + hot milk...
    By gregpullman in forum Milk Froth and Bubbles
    Last Post: 13th December 2006, 08:56 PM
