Results 1 to 24 of 24
Like Tree5Likes
  • 1 Post By Journeyman
  • 1 Post By Steve82
  • 1 Post By Yelta
  • 1 Post By JamesM
  • 1 Post By Javaphile
Thread: Hate my Gaggia Classic
    Nov 2008
    10
    I've had this machine for a few years now and have never felt that I have command of it.
    Previous was an older Italian machine called Novitalia – it was a cracker and would pump out espresso with good crema from a Lavazza pre-ground bricks every time. And when I bought freshly ground it was right up there! Alas, that one has gone to the barista gods.
    I buy my coffee purpose ground (fine –> very fine) from Seven Seeds or St Ali. When it's fresh (hours) it's ok – but never gives out a luscious, golden, thick, syrupy crema. That's what I want.
    The machine has had the pressure mod done to it.
    I overdose, as is common for these machines and even when the pour is slow and fine, it is quite dark and watery. And when I get the grid done just a whisker finer it just chokes.
    Hmmm. Have been wondering if I should take the thing to St Ali and ask one of the dudes there to road test it. Would they do that? Are you listening in, even?
    Tips welcome.
    May 2009
    Bendigo
    1,028
    I'm a noob so this is probably a stupid suggestion - but hey, how else can I learn? I noticed a radical difference with using the double wall filter as compared to the single wall with the preground coffee crap I have tried (all I had for my as-of-yesterday arrival of my first machine) - might you have been using a double wall in the old machine but now you're on single wall? So your normal procedure needs adjusting?
    Smee likes this.
    May 2010
    Sydney North Shore
    1,320
    Get a grinder and grind on demmand fresh coffee beans from a local roaster. You will never get good coffee from that stale preground muck.
    Barry
    Oct 2011
    1,353
    Re: Hate my Gaggia Classic
    Fresh is a few minutes, not hours. The right 'fineness' takes testing on your machine, and adjustment. Your not going to get the best result possible with preground beans.
    Maybe a grinder is the solution?
    Nov 2008
    10
    Journeyman, I just use the standard single and double filters. I get a slightly more consistent result with the double, though, as it tends to slow the pour with more resistance.
    Barry, the symptoms are still there if I get freshly ground from the coffee dudes and make at home 15 minutes later. I never use the branded pre-ground stuff these days – the Gaggia Classic just pisses through it.
    Oct 2011
    1,353
    Then its probably too coarse, or you are under dosing or undertamping (what tamper are you using?)
    15 mins, to me, is still too old. We're talking < 2 mins.
    Edit: looking back at your original post, just sounds like stale coffee.
    Nov 2008
    10
    I don't think the grind is too coarse – I've played with it and the shops do it a notch finer than they would do for any other home espresso machine.
    <2 mins? Seriously? I'll have to work on riding home from the coffee roasters a bit faster then!
    All the above makes sense, except my benchmark is that old Novitalia machine that had the goods day in and day out and was not too worried about the exactness of the grind.
    If I have to buy a grinder, what do I buy. (Small is better – space is tight in the kitchen.)
    Jan 2012
    22
    Quote Originally Posted by Johnonetrillion View Post
    those little conical sunbeam puppies are good!
    Feb 2012
    Central Coast NSW
    635
    You hate your classic? I would say it hates you more for feeding it crap.
    As others have said get some fresh beans, get a grinder, learn or fine tune your techniques and you will produces pretty good espresso on the classic.
    I have been using a Porlex hand grinder for the last year, can be had for around $60 fits in your pocket.... it does an OK job if you secure the adjustment with a 10mm nut using a spanner, but will soon be upgrading to my first electric grinder.
    robusto likes this.
    Senior Member coffeechris's Avatar
    Jul 2011
    687
    You need a grinder, that way you can buy freash roasted coffee beans, take them home waste a few getting it right. What Barry Duncan is saying is right. Im not saying theres not other issues, however if its one thing i have learnt about owning a coffee machine. Besides that fact a grinder wont make a coffee, the grinder is the more important part of producing a perfect cup that the machine is.
    Dont by pre grounded coffee, get a grinder
    Aug 2010
    158
    You'd make better coffee if you sold the Gaggia and bought a grinder for the money! It really doesn't matter that much how you make the coffee, as long as it's fresh ground (< minutes) from fresh beans (< 4 weeks) on demand, it will always be better.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,908
    Check this post, it has great easy to read and understand information. http://coffeesnobs.com.au/general-co...tml#post493600
    robusto likes this.
    Nov 2008
    10
    Alright, I'll buy one. Would prefer something non-electric – just to keep the bench clear. The Porlex number looks the goods, but a bit small. What else is available with similar function in Australia? Kyocera ceramic?
    Senior Member deegee's Avatar
    Sep 2012
    Brisbane Southside
    305
    I LOVE my Gaggia Classic. Here are a couple of pics of a shot from an un-pressurised double basket.
    15 grams of Colombian Supremo, roasted to the start of second crack on Feb 27th.
    Ground with the Hario Skerton also shown. they can be bought for about $50 to $60 last time I checked.
    Senior Member NakiChap's Avatar
    Apr 2011
    Perth , WA , Australia
    352
    I get great espresso from my Gaggia classic
    I have it at work and use my Lido hand grinder
    With fresh beans and the correct grind and dose you should be getting good espresso.
    May 2009
    Bendigo
    1,028
    Quote Originally Posted by deegee View Post
    15 grams of Colombian Supremo...
    :I had a laugh: I'm just going to go ahead and assume here there is a coffee called Colombian Supremo? I knew it as another product entirely... back in the day.
    Sep 2012
    Brisbane Southside
    305
    Quote Originally Posted by Journeyman View Post
    Yes it is also the name of a coffee - a fairly generic one. I think it refers to the bean size/grading, more than anything more specific.
    Cheers, Deegee.
    Nov 2008
    10
    So, if I want to get a ceramic bur grinder, say Hario Skerton/Kyocera, a decent tamper (mine is Gaggia issue plastic) and a Sylvia steaming wand – where do I go in Melbourne's inner north Brunswick, Carlton)?
    Cheers – and thanks for all the replies! I reckon that's good going for a day's work.
    enjoy black coffee JamesM's Avatar
    Nov 2008
    Perth
    672
    site sponsor dibartoli do a steam wand kit, it's bolt on. comes with the brass adapter required. etc.
    a real tamper would help.
    a real grinder and grinding on demand sounds like your problem.
    I was getting magical shots on my gaggia classic. I cut out the portafilter (naked) and just loved watching it rip. It really is excellent at pulling shots, can't say the same for texturing milk though
    nell2233 likes this.
    Nov 2008
    10
    Ok, that's all working much better now – thanks for the tips.
    Bought the Hario hand grinder, a Sylvia wand and a decent tamper.
    Took about 4 shots to get the setting for the grinder right – just a few clicks back from minimum. It's a bit sensitive down that end of the range, but I would a sweet spot that was a wee bit above choking it and I got myself a good 25 second pour. Just by way of feedback, the open top to this grinder means there's a bit of eruption going on when you get to the end of the process, with little bits of bean flying onto the kitchen bench and floor, so I might cut myself a cover with a slit out of plastic/nylon etc.
    Have not put the wand on, but will do tonight. Expect that to help as well. Always hates that Gaggia frother!
    Jun 2009
    Moonta SA.
    5,908
    Good result John.
    Do you still hate your Classic?
    Only 4 shots to get the grinder adjusted? well done, have seen others claiming to have gone through kilo's of beans and still not get it right.
    Dec 2011
    1
    I know it's an old post, but i really hope that Colombian Supremo isn't this: commercial link removed as per Site Posting Policy Gloria Jean's Colombian Supremo
    Last edited by Javaphile; 14th February 2017 at 05:24 PM. Reason: Commercial link(s) removed
  23. #23
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    845
    Surely not!? :-)
  24. #24
    Dec 2004
    Earth!
    14,653
    Quote Originally Posted by TooMuchCoffeeMan View Post
    Supremo refers to the size of the beans, not an origin source.
    Java "No!" phile
    deegee likes this.
    Toys! I must have new toys!!!
  1. Replies: 6
    Last Post: 15th March 2012, 09:20 PM
  2. Gaggia Classic portafilter and GAGGIA PROTEO ROMANZA
    By cazby in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th October 2011, 06:50 PM
  3. Replies: 6
    Last Post: 23rd November 2009, 07:19 PM
