Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By LeroyC
Thread: Gaggia Classic overflow tube?
    Sep 2014
    Hi guys
    I just purchased a Gaggia Classic. Turns out the overflow tube is missing. The fixing nut is still attached. I was only able to find one online store selling the tube for $17 plus postage.
    Gaggia Overflow Pipe Classic - Di Bartoli
    - Who else might sell one or a physical store in Adelaide?
    - Can anyone confirm the size of the tube. I assume its simply seamless stainless steel. If so I can buy a length and make a few cheaper.
    Thank you
    Feb 2016
    It is a 6mm tube, but the original may not be stainless steel. They have a tendency to split through use/age down the length.
    You can get a length of stainless steel tube off the usual auction site and cut to size. The internal diameter will be 4mm and therefor smaller, but hasn't been an issue on the machine I put it on.
    Feb 2016
    Looks like a 250mm length will be about $3.50...
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    I just used black plastic. Was cheap (actually free cause I pinched an off cut from work), still looked fine and was actually easier to take on and off to take the drip tray out for cleaning.
    Dimal and solace like this.
    Oct 2016
    I was in the same boat with my new (second hand) Gaggia Classic, bought 5m of black irrigation tube from Bunnings and works a treat plus heaps spare should I need to replace it - not a bad $5 investment
