Results 1 to 6 of 6
Like Tree4Likes
  • 2 Post By LeroyC
  • 1 Post By mulquemi
  • 1 Post By zeezaw
Thread: Sunbeam EM6910 - group handle needs to be pushed too far - why?
    aik
    aik is offline
    Dec 2013
    10
    We had an old EM6910, after a while the collar worn out and we had to push the group handle far to the end, like on the photo. I replaced the big blue gasket - it did not help. It would still leak so I replaced the collar - it was so worn out (edges were pushed out, "fine grade" brass alloy) so a group handle from a newer machine would not fit in there. Leaking stopped but the group handle still needs to be pushed that far.
    Then we got another EM6910 which was known for not working hard in the past, like 300 shots in its entire life, and first week the group handle did not have to be pushed to the position as on the photo, it would be enough just to push to a middle. But after a week of office use, it became like on the picture again, otherwise it leaks. Beans, grinder are the same.
    Why is this happening? Too strong coffee drinkers? Low quality collars? The collar still looks good so does the big blue gasket. Any way to fix this permanently? Or recommendation? Thanks.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,669
    As you've already found out, these collars are quite soft and easily damaged by over tightening. Apparently they also have a fair bit of variability in their manufacture so you can sometimes get a brand new machine that needs the portafilter pushed past the centre to the right. With that in mind it doesn't really matter if you have to push it a bit past centre, as long as you're not cranking it too hard. Make sure you're not overdosing the filter basket as this can cause issues and make sure everything is really clean as often just a couple of grains of ground coffee can cause leaks around the collar during extraction.
    The technique I've found that works for me is I flush a little water through just before I lock in the portafilter. Not heaps, just the preinfusion pulses is enough. Lock the portafilter in firmly but not too hard. Place cup(s) underneath (and scale in my case) then tighten the portafilter a bit more. I usually find that it tightens a bit more quite easily and if I forget this step I usually get leaks around the collar. After making the coffee and removing the portafilter I flush more water and give everything in the grouphead area a wipe with a cloth before making another shot. This is all with a virtually new gasket and collar. I think this technique is probably necessary due to the gasket being a fairly soft silicone.
    Not sure if this will help but there's a couple of ideas there for you to try.
    aik and zeezaw like this.
    Rbn
    Nov 2010
    Southland NZ
    396
    An intersting thing I have just discovered is that my brand new P/F tightens sooner than my old P/F.
    Actually I have 3 old P/F, they go around to the right, a bit like in the picture above, but the new one is in "about the right place" at 6 o'clock.
    May 2014
    516
    aik,
    Another idea would be to try something to pack the underside of the group seal,that way the seal has less room to compress with the group handle being tightened.
    I have successfully used stiff cardboard and even plastic ice cream lids ,cut to size to match the seal base.Using more then one can also help.
    Hope that helps.
    cheers,
    Mick.
    rawill likes this.
    Mar 2017
    Lisbon
    36
    Look for a group spacer either on eBay or sponsor web sites, spare parts shops will have them. You can get different thickness ones, I'd get a few 0.5mm and 0.8mm and see how I go. Get a few as they are cheap and easy to damage if installed incorrectly.
    I had to use one for an old group handle on an EM7000 once, didn't need it when using a newer handle. They should be placed above the blue group seal.
    rawill likes this.
    Mar 2017
    Lisbon
    36
    As for the 'why' part of your question, as LeroyC stated above this is most likely caused by brute force, overdosing, or both.
    These need to be treated gently, tell your workmates to make sure the seal is clean before pulling a shot and never go past 6 o'clock (ish). Maybe draw an arrow at the right position for your machine?
