Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By rawill
Thread: EM 5600 not heating.
    Rbn
    Nov 2010
    Southland NZ
    443
    I just bought an EM5600, for parts as it is not heating up.
    But, its exterior condition is excellent. I wondered if any CSers might know what I should check to see if it can be made to go again.
    Without too much cost, it's mate, with a real rough exterior is in the campervan, so does not get a lot of use.
    I just want it to look good!
    Robin
    May 2014
    532
    Robin,
    May I ask what is operational with your machine,is there water flowing when switched to brew and is water jetting from the wand when valve is opened?
    If water is flowing when brewing or wand jetting water then what is likely the fault is boiler thermostat x2 ,one for steam and other for brew temperature.
    what happening?
    cheers,
    Mick.
    Rbn
    Nov 2010
    Southland NZ
    443
    Thank you Mick, good pointer. Will get back to you when I have done a bit more investigating.
    I just picked it up as a non working machine, for $10.00, worth it just to get the tray and P/F.
    But thought, I should investigate more.
    Rbn
    Nov 2010
    Southland NZ
    443
    I am embarrassed! I was told the machine did not work, I took them at their word and posted.
    Should not have done that, just pulled a shot, made microfoam, on this non working machine.
    Not sure what was going on, but now I have an EM 5600 for NZ$10.00.
    So I have one spare, and also a spare EM 4800c!
    zeezaw likes this.
