Results 1 to 10 of 10
Like Tree4Likes
  • 2 Post By Di_Bartoli
  • 1 Post By WhatEverBeansNecessary
  • 1 Post By timmyjj21
Thread: Gaggia Classic cleaning
    Sep 2017
    4
    I recently bought a second hand Gaggia classic and have pulled some alright shots from it already.
    I took a look inside at the boiler and saw quite a bit of scale buildup around the sides (Brisbane has really hard water)
    I want to take the thing apart and descale the boiler and replace all the seals.
    Is there a list of all the seals I can buy before I do this?
    Apart from pulling it apart first and looking at all the seals.
    thanks
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    462
    Site sponsor Coffee Parts will be able to help you out! www.coffeeparts.com.au
    They have listings of most (if not all parts) to a whole range of machines at various ages including Gaggia Classic. Also they have a sale on right now.
    Sep 2017
    4
    Thanks WhatEverBeansNecessary,
    Can you recommend a descaler?
    Site Sponsor Di_Bartoli's Avatar
    Aug 2006
    647 Botany Road, Rosebery, NSW 2018
    922
    Enclose notes that we wrote to how to use the machine and clean
    Gaggia Classic manual with new logo.pdf
    Dimal and 338 like this.
    Apr 2017
    Adelaide
    462
    Quote Originally Posted by Electrofish01 View Post
    Caffeto Restore & EVO is very popular.
    matth3wh likes this.
    Feb 2016
    179
    Simple, basic, kitchen grade, citric acid powder.
    Cheap, simple and works.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,260
    Don't use citric acid, particularly in the case of heavy scale build up.
    As WBN suggested Cafetto restore is an excellent descaler. https://www.coffeeparts.com.au/acces...store-descaler
    Apr 2017
    Adelaide
    462
    Agree with Yelta, I wouldn't use citric acid for a full descale. However as part of a monthly or frequent routine dilute citric acid works a treat. Best option of the lot is to do a descale with caffeto and look at water softening or filtration to eliminate the need for either option.
    Jun 2009
    Moonta SA.
    6,260
    As I said don't use citric acid.
    This quote from Chris at Talk Coffee.
    "If you do have to descale, we recommend you use a proprietory descaler such as Clean Machine Activated Descaler. One batch will normally do 2 descales for mild to moderate scale. Itís cheap and effective. For bad scale, use the lot (100g). Do not use Citric acid or supermarket descalers such as CLR. Citric acid can move plaques of scale and these cause problems elsewhere in your machine. CLR is poisonous."
    Feb 2016
    179
    True, citric acid isn't perfect. But this is a Gaggia Classic, not a Rocket Giotto. The only location that can potentially get blocked is the Solenoid valve which is easy access and a simple fix. That's assuming the machine wasn't opened up, but the OP also indicated they were replacing the seals on everything, had the boiler already opened, so it is all stripped down and in pieces. I'll stick with my citric acid advice.
