Results 1 to 15 of 15
Like Tree5Likes
  • 1 Post By level3ninja
  • 1 Post By Barry O'Speedwagon
  • 2 Post By Yelta
  • 1 Post By artman
Thread: Aaaargh! Help removing stuck steam wand tip
    150
    Its very stuck - any tips on getting one off?
    I usually just grab with a cloth and can twist the sucker off but one wand (its a LM Linea) has become stubborn. Tried wrapping a cloth around the tip and exerting some force with some multigrips but all I did was leave some little dents in the metal! Anyone got any tricks?
    Apr 2008
    Brisbane
    5,103
    Re: Aaaargh! Help removing stuck steam wand tip
    Quote Originally Posted by 063D223A3720520 link=1303542902/0#0 date=1303542902
    Its very stuck* - any tips on getting one off?* *
    I usually just grab with a cloth and can twist the sucker off but one wand (its a LM Linea) has become stubborn. Tried wrapping a cloth around the tip and exerting some force with some multigrips but all I did was leave some little dents in the metal!* * Anyone got any tricks?*
    Try a little WD40 and let it soak in
    Then remove with the multygrips
    Dont use them directly on the metal but use a cloth between the tool and the steam tip to prevent damage
    If still stubborn, remove the arm from the machine and use a vice & multigrips* but remember to use a cloth to prevent damage
    Wash off all WD40 thoroughly & apply a little food safe grease to the thread prior to assembly*
    10,493
    Are you sure youre turning in the right direction?
    150
    Yep - same way the other wand goes.
    10,493
    What about turning on the steam to heat up the wand and tip then putting a cold cloth on the arm to cool it down a little and quickly trying again to remove the tip while its still hotter than the arm?
    150
    Thundergod,* we must think alike because today I tried cold wand with hot water on the tip, and hot wand with cold water on the tip.* I also tried after letting the wand sit in water with a bit of caffetto for a short while.
    The other tip is stuck now too.* Ive been off for a week and so I reckon the other guys arent cleaning properly so its probably stuck with gunk. Ill try the wd40 trick then we might have to take the bugger off.* *
    Thanks for the smurfy advice guys.
    Aug 2009
    469
    its a 30sec job to take the wand off, less time than it took to start this thread... it would be a false economy not to! :)
    Apr 2017
    3
    does anyone among u look back at ur comments?????? u all make suggestions but not one of u says AT WHICH DIRECTION to turn the steam wand tip in order to remove it .....clockwise or anti clockwise.
    May 2008
    3,819
    An old topic so don't expect the others to respond. Not good form to rant at the ones you want a response from but the answer to your questions is anti-clockwise to unscrew.
    Nov 2013
    Casula, NSW
    591
    Quote Originally Posted by bambi7 View Post
    That sounds like solid advice
    Barry O'Speedwagon likes this.
    Dec 2011
    PRL
    2,370
    You're luck you got a response. You'd do well to learn some manners.
    Yelta likes this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,852
    Suggest a read through this classic wouldn't go astray.
    As for removing the steam tip, pretty basic stuff, in fact I'd be embarrassed to admit I didn't know.
    Casa Espresso and magnafunk like this.
    Sep 2007
    Northlandia
    1,357
    Lefty loosey/righty tighty ol' sport.
    Senior Member artman's Avatar
    Jun 2006
    2,199
    Quote Originally Posted by Magic_Matt View Post
    Yep. Some exceptions including the nut holding the burr to the motor shaft on all grinders I have seen, and the left pedal of bicycles, and BBQ gas bottle/hose connection. One coffee related, two random useless facts!
    Magic_Matt likes this.
    Sep 2012
    Hobart TAS
    145
    Not to forget an old apprentice's test - left hand thread on left hand side air cooled VW hub nut. And many military vehicles had left hand threads on left hand side wheel nuts.
  1. Removing Boema Steam Knobs
    By eternaldrive in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 21st October 2010, 02:20 PM
  2. Changing Steam Wand Gaggia Classic to Silvia Wand
    By pricespringer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd May 2008, 01:53 PM
  3. [m]: Changing Steam Wand Gaggia Classic to Silvia Wand
    By Dimal in forum Milk Froth and Bubbles
    Last Post: 23rd April 2008, 04:33 PM
  4. Removing EM6910 Steam tip - handy tip
    By Saambo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th March 2007, 12:24 PM
