Results 1 to 24 of 24
Like Tree9Likes
  • 1 Post By Javaphile
Thread: La cimbali M29 (Basic) Help - Water Overflow
    Jul 2012
    New Zealand
    14
    Hello all Friends,
    I am a new bee on this forums site.
    Having a slow water leakage issue with recently installed (a second hand machine approximately 7 years old)
    Water is continuously dripping from the little overflow down pipe connected to the head group which goes into the base tray (connected to drain pipe)
    I tried shutting off the mains water supply - it stops after some time if the main water supply is turned off and slows down if mains water supply pressure is controlled by turning the manual tap valve (slightly shut) which means not fully open.
    Is it normal or is there some serious issue which I need to get fixed straight away?
    Please advice what to do to fix this problem.
    Regards,
    Dec 2004
    Earth!
    14,594
    It sounds like a bad or gunked up 3-way valve. Try doing a backflush or two or three and see if that solves the problem.
    Java "Still loving Simba" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    Hi Javaphile,
    Thanks for a quick reply buddy :-)
    As suggested I've tried back flushing 3 to 5 times at different times however it did not make any difference so far.
    Can it be something to do with the little solenoid attached in between the head group and back flush down pipe?
    Please advice what should I do next?
    Regards,
    Dec 2004
    Earth!
    14,594
    Have you backflushed with detergent? Not the kind for dishes but the kind specifically made for backflushing an espresso machine. If you don't have any it is readily available from many of our sponsors.
    That solenoid is the 3-way valve.
    Java "Keeping the pipes clean!" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    Yes, I did it with the detergent especially made for espresso machines cleaning, I think i should try for few more times as this machine was sitting in stoarage from the last 7 months before i bought and if there is any gunk sitting in this valve it may take some time to clear.. thanks again and I will get back to you after doing back flush again.
    Dec 2004
    Earth!
    14,594
    If the backflushing doesn't work the next step I would do would be to isolate the problem part by swapping the coil with one from another working group. If the same head still leaks then the problem is with the valve. If the problem follows the coil then obviously the problem resides with the coil. If it's the coil that's bad replace it.
    If the problem stays with the head/valve I'd disassemble the 3-way valve, soak it (Just the valve assembly, not the coil of course!) in a detergent solution and manually clean it. Once reassembled, replacing any o-rings and washers in it, I'd do another few backflushes with detergent followed by ones with no detergent. If it still leaks after that I'd be looking at replacement.
    All of this presupposes you're comfortable and capable of performing this work and know how to safely work around electricity and water. If you don't know how to safely work around them then DON'T!!! Take the machine to a qualified service center instead.
    Java "Electricity kills!" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    Hi There, Thanks once again for your support, Would it be possible to have a copy of repair manual for this model?
    is it available online any link or suggestion please...
    Regards,
    Dec 2004
    Earth!
    14,594
    Sorry, I've never seen nor heard of a repair manual.
    Java "Fixerupper" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    Sorry, I meant owner's manual.
    Great help, Thanks I got the valve replaced it was badly chocked by water scaling gunk. no leakage any more.
    Very kind of you dear Javaphile :-))
    Dec 2004
    Earth!
    14,594
    While there are manuals for several other La Cimbali models floating around I've not seen one for the M29.
    Java "Sorry!" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    Hello Javaphile,
    It's been a long time since I have posted here. Just wish to have your advice on a recent issue with this M29.
    This time it's leaking from the *overflow valve* of its *water pump* there is a spring inside with a screw with a tiny hole in it. I tried adjusting the screw but did not help. Water is coming out of tiny hole in the screw on this overflow valve.
    Machine also makes squeaking noise whenever we extract coffee or whenever it takes water intake from main water supply (sounds like it's trying too hard)
    When I turn main water supply off - leak stops.
    PLEASE HELP
    REGARDS
    Dec 2004
    Earth!
    14,594
    First off before doing any disassembly inside the machine UNPLUG IT and turn off the water supply.
    The overflow valve, circled in green, is located in a brass assembly located under the drip tray on the right side near the the black plastic box that the drip tray drains into. The overflow valve has a plastic hose (Blue arrow.) that connects up to the back of the drain box (Red arrow).
    When the machine is making the squeaking noise you speak of is there water coming out of this hose into the black drain box? If so loosen the set screw (On the left side.) and turn the screw until the noise/water stops and then turn it 1/4 turn more and tighten the set screw.
    The valve on the pump, circled in yellow in the picture below, is a bypass valve used for setting the pump's output pressure. (Your pump may look different as this one is an older style/design.) If this is where the water is coming from and the above adjustment hasn't fixed the problem then remove the screw and any other parts in the adjustment mechanism and clean them and the interior to remove any debris/scale. Then reassemble it and adjust the screw until your gauge shows 9 bars pressure when pulling a shot. If your machine doesn't have a gauge that shows pump pressure you'll either need to acquire a gauge or count the number of turns it takes to remove the bypass adjustment screw and when reinstalling it turn it in that amount which should get it close to the needed 9 bars. To get it properly adjusted though will take a gauge. If cleaning the bypass mechanism doesn't stop the leak then you're probably looking at having to replace the pump.
    To do either of the above adjustments will require the machine running. Hence you will be working around live 240v and water. 240V kills! If you're not comfortable and knowledgeable working around live 240v DON'T! Bring it to a tech who is!
    Java "240v kills!" phile
    bibiz likes this.
    Toys! I must have new toys!!!
    Jul 2012
    New Zealand
    14
    Thanks for your quick reply Phile, water is coming out of bypass valve on the pump. As you shown in 2nd picture circled with yellow. It started with a very slow drip - I did remove the screw and a spring behind the screw refitted 6 months ago - it did not stop the leak so I have run a flexi hose from leaking valve to a bucket to stop the mess temporarily.
    Leak has increased today and continuous even when pump is not running or even when machine is tired off.
    Squeaking noise has become very frequent and obvious from few weeks. In the past noise was not that frequent.
    May be the screw and spring in the valve may have gone loose? If we tighten this screw that means we are REDUCING the pump's out put pressure or INCREASING it??
    Jul 2012
    New Zealand
    14
    Do have a gauge which reads from minimum of 0 to max of 2,5
    (Funny numbers) 0 to 0,8 is blue colour, 0,8 to 1,6 is Green then from 1,6 to 2,5 is red. My gague Indicator sitting in green - between 0,8 to 1,6.
    Did not notice reading while pulling shot. Will do that too however question is where in this reading it should read exact or near 9 Bar ?
    Dec 2004
    Earth!
    14,594
    Hhhmmm....Been a long time since I needed to make an adjustment. I think clockwise increases the pressure.
    That's showing the pressure in the boiler, not the pump pressure. Not all Cimbali's have a pump pressure gauge.
    Java "Gauging it" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    Thanks a lot Phile, I've tried taking assembly out clean it refit it, adjusting the pressure - nothing worked. Water coming out is quite a bit (10 litres per hour approx) It seems like I've to replace the Pump however can you please tell how complex this process would be to uninstall old one and installing a new pump on this machine? A step to step guide if possible will give me enough confidence and hopefully i can do it my self. If anything is critical at any stage Please Guide... Once again thank you so so much for your help Phile - Highly appreciated buddy
    Dec 2004
    Earth!
    14,594
    The pump will have a part number on it which can be used to order a new one from someone other than Cimbali. Only your machine's model number and serial number should be needed if ordering from Cimbali. Ordering direct from Cimbali will guarantee, or at least should, a drop-in replacement. If you order from a 3rd party, typically cheaper than buying from Cimbali, you may end up needing adapters between the pump and the lines.
    When the machine is completely cooled to room temperature:
    • Disconnect the machine from power.
    • Turn off the main water supply valve.
    • Use your manual fill lever, if the machine has one, to relieve the line pressure.
    • Take lots of pictures of the pump and piping as well as general area shots to document where everything goes..
    • Disconnect the 2 water lines on the pump being careful of the possibility of spraying water when they are first loosened. (Depending on the layout of your machine other pipes may need to be removed to access the pump and/or remove it. Take as few things off as possible.)
    • While holding the pump with one hand remove the ring clamp (Indicated by the blue arrow in the pic below).
    • Pull pump away from the motor to remove it.
    • Reverse the steps to put the new pump on removing old and putting new Teflon tape on any fittings that were undone that used it and making sure the shaft of the new pump lines up properly with the motor's shaft (It's most likely a slot type fitting.) and is slid on all the way before replacing and tightening the ring clamp.
    • Allow the machine to dry completely if any water leaked/sprayed during the process.
    • Adjust the pump's pressure.
    Java "Boom, Bob's your uncle!" phile
    bibiz likes this.
    Jul 2012
    New Zealand
    14
    BTW, that squeaking noise is gone, that was p,bally due to excessive pressure on water pump - this time I adjusted the screw to its original position by turning anti-clock wise, flow of water coming out has also reduced quite a bit but not stoped
    Jul 2012
    New Zealand
    14
    THANKS Phile, will start hunting for ordering a new pump and take it from there, You are GREAT
    Jul 2012
    New Zealand
    14
    Dec 2004
    Earth!
    14,594
    How do you know that's the correct pump for your machine?
    Not all pumps are the same. They have different threads, different size shaft sizes, different flow rates, different materials, and different pressure capabilities. If you're not ordering from Cimbali then you need to dissect the part/model number on your pump to make sure you're buying the proper one for your system.
    All the Cimbali rotary pumps that I've seen are Procon's so if you're buying another Procon it should be just a matter of matching up the part/model number on yours with the new one.
    Here's a model matrix that will let you figure out exactly what the specs on your pump are: PROCON Repair Center - Procon Pumps Matrix
    Java "Pump what?" phile
    Jul 2012
    New Zealand
    14
    Hmnn, thanks, where will i find the part & model # on my machine Phile?
  23. #23
    Dec 2004
    Earth!
    14,594
    It's stamped into the body of the pump.
    Java "Numbers" phile
    bibiz likes this.
  24. #24
    Jul 2012
    New Zealand
    14
    yep, got it - thanks
  1. Cimbali M27 Basic User Manual?
    By katchafire in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 11th March 2013, 05:08 PM
  2. La Cimbali M27 - Little water through groupheads
    By RZ350 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 29th November 2010, 03:10 PM
  3. Price for La Cimbali M27 basic?
    By Andy-Gadget in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 20th June 2009, 07:18 AM
Tags for this Thread
