Page 2 of 3 FirstFirst 123 LastLast
Results 51 to 100 of 107
Like Tree81Likes
Thread: Londinium L1 luxe Edition - Evolution
  1. #51
    Senior Member SniffCoffee's Avatar
    May 2010
    Canberra
    701
    Quote Originally Posted by SniffCoffee View Post
    I'm curious whether the Londinium temp issues are perhaps due to the smaller boiler?
    Both the Bosco and Achille have large boilers (6 ltr and 4.5 respectively) whereas the Londinium has a 2.4 boiler. Would the larger boilers keep the temp more stable by allowing a better flow through the thermosiphon?
    Sniff
    Rick, this question got lost in the posts above - would the boiler size affect the ts flow?
    Sniff
  2. #52
    Member ASchecter's Avatar
    Jan 2013
    USA
    98
    Quote Originally Posted by coffee_machinist View Post
    What gets me though is that there is no inherent complexity or possibility for variation in the construction of the machine, so why should most perform admirably when a small number don't seem to - it's not like the PID settings have been altered, it's all simple mechanics as Reiss says. Sure, there are complex fluid mechanics at work inside the TS that go way beyond my knowledge, but the machines should all work perfectly or they should all be stalling.
    Variation in the height of the auto fill probe in the boiler? More of the surface of a horizontal HX gets covered and uncovered with variations in water level as compared to a 45 degree or vertical HX.
  3. #53
    Sep 2005
    493
    Insulating the group feed would probably help also.
    This idea is simple and logically would keep the temperatures of boiler-in and boiler-out tubes at a greater temperature difference relative to eachother. Would this increased differential (over no insulation) be enough to encourage the TS and (hopefully) eliminate TS stall even after prolonged pre-infusion?
  4. #54
    Jan 2013
    USA
    98
    Quote Originally Posted by Paolo View Post
    It didn't do anything at all when I tried it.
  5. #55
    Sep 2005
    493
    Quote Originally Posted by ASchecter View Post
    Thanks for that info, Andy. The idea certainly sounded good in theory.
  6. #56
    Oct 2011
    1,373
    Are you experiencing the same temperature instability?
  7. #57
    Mar 2012
    1,275
    .. Oh ! Mr Jack...you dont know the irony of that question !!
  8. #58
    Oct 2011
    1,373
    Probably more than you realise
  9. #59
    Jan 2013
    USA
    98
    My L1 has the latest non-return valve/relief valve installed. It typically turns on in the morning via a timer about an hour or two before I use it. Lately the group temperature has been about 191F (88C) before the first shot.
    Per Reiss's latest recommendation, I have shortened my preinfusions from 6 to 10 sec down to 3 or 4 sec. I often do three or four shots a few minutes apart. If I do a short (1 sec) flush after each shot, the group surface temp seems to stay steady at about 188F (86C). If I don't do the flush after each shot, the group surface temp often drops to 181F (83C) or below. So, of course, I've gotten in the habit of doing the short flushes.
    How or why people like fransg and kfir experience superior temperature stability with their machines is a mystery to me. I will say, though, that despite the temperature management inconvenience, I like two things about the L1:
    1. quality of the massive group
    2. taste of the espresso
    And those things are why I am still using it on a daily basis.
  10. #60
    Jun 2011
    683
    Sniff
    Hi Sniff, Sorry, I missed that one. While I can't say for sure, my guess would be no, boiler volume should have a negligible impact on the TS's ability to restore flow after a shot. I keep coming back to a temperature differential and the resulting pressure (or impetus for flow, energy wanting to go somewhere and do some work) as being key elements in the functioning TS, thus it works flawlessly when the system is pressurised up to 6-7 bar, and stagnates at 1-1.4 bar (but only after a shot - why?). Theories only at present, but my earlier experiment with the machine set up as a discrete HX on mains water was enough to satisfy me that there's something there.
    Could be Andy, it's an experiment worth doing. I put forward this idea in the H-B thread and I remember Reiss posted something in response to EricS along those lines, an outright denial supposedly from the Fracino techs that this could influence the TS function. In my experience with E61 Isomacs, many of which have horizontal HX's, fill level did have an impact on group idle temperature and shot temperature but it was minimal - fine tuning only. Seems to me that the more the HX is immersed, the faster heat energy is conducted as the transfer should be more efficient between water/copper/water than water/copper/steam. But... does steam carry more heat energy than water if they are both nominally 120 degrees C?
    Anyone here have a physics degree? anyone...?
  11. #61
    May 2010
    Canberra
    701
    Thanks Rick
    I know you're modding an Achille soon for Chris and it will be interesting to see if the same issues arise - please keep us posted on the progress.
    Sniff
  12. #62
    Dec 2004
    Earth!
    15,041
    In the saturated environment of the boiler gram for gram the steam contains significantly more energy than the water does. You could see significant differences in the temp profile of the shot depending on how the machine is set up and how much of the HX is exposed to the steam and water. What the exact difference will be will vary one machine/setup to another. Only testing a specific machine/model will tell you how it responds.
    Java "Physics is fun!" phile
    Toys! I must have new toys!!!
  13. #63
    Oct 2011
    1,373
    Quote Originally Posted by Javaphile View Post
    This is true (roughly 6x), however the steam density at 10-12 barg is significantly lower than that of the water (roughly 1/20th, if these online steam tables are reliable ). The water will also likely to be flowing more, which has a significant effect on the rate of heat transfer. That said, the steam would be condensing on the HX so could give up a lot of heat with a relatively small temperature change.
    I suspect you would reach equilibrium temperature either way.
    In a smaller boiler, the addition of cold top up water will have a greater cooling effect, which means there could well be a reduction in the density difference between the boiler water and the thermosyphon return line (thus slowing the flow). How significant this effect would be is hard to say, and would depend on the geometry of the system. It could well be negligible in most cases, but perhaps is significant if the TS is already close to stalling? I suspect if the fill water enters at the bottom of the boiler, the effect would be greater.
    I really can't see how the system being pressurised will have any impact; as it is a closed loop. What matters in the thermosyphon is the relative density of the fluid at the top and bottom; the actual absolute pressure should be irrelevant. Unless perhaps you have water flashing to steam, and somehow interupting flow that way? (but that seems unlikely)
    This really sounds like it could be a significant factor; even if it's just purely a flow phenomenon (i.e. heat transfer rate aside). If the HX is truly horizontal, perhaps in some units there is a slight angle in the boiler, or the HX, or even in the frame, which results in the outlet of the HX being lower than the inlet. This would certainly mess up flow. Could even be that the element is closer to one end of the HX, and there is an temperature gradient in the boiler water along the length of the HX?
    Something else I've just thought of; if the element is off for an extended period, perhaps a temperature gradient develops in the boiler due to reduced mixing, which would slow the thermosyphon flow? It could be that a bunch of these factors all combine (that swiss cheese effect again) due to small fabrication differences (and a sensitive design) to cause stalling in some machines, but not others.
    Quite an interesting discussion, but could really use some schematics/details photos of the boiler/HX
  14. #64
    Mar 2012
    1,275
    .... I keep coming back to a temperature differential and the resulting pressure (or impetus for flow, energy wanting to go somewhere and do some work) as being key elements in the functioning TS,.....
    Rick,. my understanding is a TS functions primarily on convection circulation, relying on gravity acting on the difference between the denser cooled water in the return compared to the less dense hotter water in the feed line. I dont see how actual pressure in the system has much influence when the system is functioning normally and the pressure is the same in the feed and return lines
    ...but i acknowledge that your practical test suggested otherwise. !
    These convection loops need a vertical difference between the heat source and the heat sink in order for gravity to work its magic, and they work better with increasing height distances. Most HX/TS systems i have seen run the cooled return line down low to the bottom of the machine in order to improve the convection effect. ( not so the L1 !)
    ....I keep coming back to a temperature differential and the resulting pressure (or impetus for flow, energy wanting to go somewhere and do some work) as being key elements in the functioning TS, thus it works flawlessly when the system is pressurised up to 6-7 bar, and stagnates at 1-1.4 bar (but only after a shot - why?). ..?
    I may have an explanation as to why your mains water feed worked so well......
    Am i correct in thinking that when a shot (or a flush) is pulled, the feed to the group comes mainly from the RETURN side of the TS ....to prevent the brew water coming straight in a boiler temperature ? ..( i think there is a flow restrictor in the HOT feed line )
    BUT, if this is so, since the HX refills from the boiler, the cool "return" line will actually be refilled with HOT boiler temperature water !
    This would create an even temp' in both feed and return lines. cancelling out the convection effect, and effectively "Stalling" the TS loop.
    Worse,.. the actual flow "inertia" of water up that "return" line to the group may well impart a reverse flow impetus in the TS loop.
    Your cold water feed to the HX(TS) loop would have eliminated this tendency to increase the temperature in the return line, and encouraged the convection effect to continue. ??
  15. #65
    Oct 2011
    1,373
    I think you might be on the money Blend52...
    The return line isn't at the bottom of the boiler? (that's just silly)
  16. #66
    Jan 2013
    USA
    98
    Quote Originally Posted by blend52 View Post
    Except higher loop pressure may inhibit induction of air and/or compress air bubbles in the system so they are less disruptive.
    Stock machine has no flow restrictors in the HX loop.
  17. #67
    Oct 2011
    1,373
    Induction of air from where? I really doubt that. Would be easily fixed with some kind of strainer, in any case.
  18. #68
    Mar 2012
    1,275
    Ahh !, interesting ..(early discussion mentioned the flow restrictor).
    Isnt it unusual for a "tuned" TS loop not to have a restrictor of some sort ?
    But even without a flow restrictor, the "brew" water feed to the group will still be drawn from BOTH of the TS lines , evening out the temperatures.
  19. #69
    Jan 2013
    USA
    98
    I have often loosened the hex plug on top of the group neck, and air bubbles out about 50% of the time. Certainly air can enter the system dissolved in the feed water.
    What kind of strainer? Please elaborate.
  20. #70
    Jan 2013
    USA
    98
    TS loops can be tuned by varying the lengths of the feed pipes. I am told this can be more effective than using restrictors. FWIW, I tried various sizes of restrictors in the L1 with erratic effect.
    Yes, making the temps more even, but not necessarily equal.
  21. #71
    Oct 2011
    1,373
    Air or steam?
    The amount of air dissolved will be very low, and will mostly come out of solution in the boiler (as gas solubility decreases with increasing temperature). Its not implausible that air could enter the loop, issue is whether the small fluctuation in boiler pressure resulting from pulling a shot will increase the volume of gas in the system, and whether this change will have a noticable effect on the thermosyphon. I doubt it.
    I imagine a tee with a small diameter line branching off at the highest point in the loop (or close to it) would work if the flow is slow enough. A bleed valve or threaded end connection could be used to periodically bleed the system.
    A restriction orifice will create turbulence. Depending on where it is located, this could have unexpected effects. What did you experience?
    Which will slow the thermosyphon flow. For temperatures to fall continuously (to a point) all you need is for the heat to be lost from the group faster than it is provided by the thermosyphon.
  22. #72
    Mar 2012
    1,275
    Agreed, there are various methods of tuning TS systems, but the restrictor is probably the easiest to adjust with and hence one of the most common.
    There doesnt appear to be much "tuning" of TS pipe lengths on the L1..just some simple direct pipe runs.
    Air in the TS...
    Is it not likely that there could be air trapped between the brew water and the piston in the group when the piston is raised.. and when the piston is released, some of that air is forced ( at 10+bar) back into the TS loop before the piston covers the ports. ??
    Fine setting of piston height relative to port position ( gasket thickness, machining tolerances, etc) could make a significant difference between machines for this.
  23. #73
    Jun 2011
    683
    Air in the TS...
    Seems plausible to me, especially considering the omission of the one-way valve on the group neck. The dipper / single port version of this group has a one way ball valve in place of the thermowell. The theory is that nearly all the air should escape through the puck as the chamber fills with water but some could be pushed back into the group. As for making it all the way into the TS.... thats a long shot, but definitely would not be ruling it out. For this reason I always let the spring pressure kick in slowly until I feel no 'sponginess' in the lever.
    A post-shot flush would also likely purge any residual air in the group. And, as Andy said, at higher pressures this air, if present, would have less chance of playing havoc with the TS flow.
  24. #74
    Mar 2012
    1,275
    Whilst the piston is lifting, there is nothing but air in the group chamber..until the ports are uncovered near the top of the travel.
    To be honest, i dont see how the brew water can expel all the air from above the puck, ! since the air will naturally rise above the water .
    Is there some feature to allow any trapped air out up past the seals ?
    Any air left under the piston stands a fair chance of being forced back through the ports and up into the group. Once there, gravity/buoyancy will effectively move it up into the thermowell and TS loop.
    Your "mains feed" mod would also reduce this tendency due to the higher pressure in the TS.
  25. #75
    Oct 2011
    1,373
    If that channel from the thermosyphon to the chamber is small enough, the flow of water might prevent the air from travelling back up. Even with no flow, surface tension could do the job (think a finger over then end of a drinking straw).
  26. #76
    Mar 2012
    1,275
    Well it certainly is not happening often, and this is all speculation, but if for some odd reason there is enough air under the piston, for a brief period when the piston is released, there is 10+ bar of pressure to help that air back up into the group.
    And why else would a flush be recommended, other than to purge any air out of the group ?
  27. #77
    Oct 2011
    1,373
    It probably wont be at 10 barg initially though.
    Going from atmospheric pressure to 10 barg, the volume of the air would reduce to around 1/11 its original volume - the piston design might therefore accommodate this, preventing the air interfacing with the port (thoughts?).
    If air entering the thermosyphon is a problem, I wonder if a sealed vertical tube in place of that hex bolt in the diagram, would help, by acting as a strainer?
  28. #78
    Mar 2012
    1,275
    MrJ' ...true, but it depends how much air is trapped in there !
    .... and remember this .....
    ...especially considering the omission of the one-way valve on the group neck. The dipper / single port version of this group has a one way ball valve in place of the thermowell. .
    My thought is..someone previously thought there was a need for a one way valve to stop reverse flow back into the group!
    Can anyone explain how the air under the piston is displaced when the brew water fills the chamber ??
  29. #79
    Oct 2011
    1,373
    It would seem like a good idea, even just as a precaution.
  30. #80
    Jun 2011
    683
    As per my post above, the air is pushed through the coffee puck. Dry ground coffee is fairly permeable to air, but on many small lever machines (particularly those that run at lower pressures, pavonis, MCALs, etc) it's easy enough to end up with a partially saturated chamber, resulting in low shot volume, spongy lever action and often a violent sneeze.
  31. #81
    Mar 2012
    1,275
    Rick, the air will be above the water..how can it be pushed through the puck ?
  32. #82
    Jun 2011
    683
    I don't understand the thermodynamics at work, but trust me, that's what happens. Take a lever machine, a spouted group handle and put a cold glass under the spout as water enters the chamber, you'll see the condensation form as the air is pushed out.
  33. #83
    Oct 2011
    1,373
    Water flashing to steam perhaps? It will happen as the water reduces in pressure.
  34. #84
    Mar 2012
    1,275
    Unlikely.
    None of the temperature data has indicated any of the water entering the group much above 90 C.
  35. #85
    Apr 2008
    Victoria, Australia
    2,079
    Had the opportunity to have a session on the 'Australium' yesterday at CM's workshop.
    What a difference Rick has made to the performance of the machine.
    The quality of the group has never been in question and with what Rick has achieved, I was able to vary the dose and tamp and still
    pull really great shots. Smooth, sweet, rich and full bodied and very forgiving.
    Still looks ordinary tho'.
    All it needed was some intuitive, intelligent tweaking (as Rick outlines above).
    I would love to see an Aussie designed and engineered machine, using this group, something that would
    be a shoe-in at the very top of the lever market.
  36. #86
    14,665
    Quote Originally Posted by chokkidog View Post
    Agreed chokki- it's a transformed machine...
    Aussie machine for the top of the lever market- not as silly as it sounds. That convo actually occurred in the last 24 hours... Maybe some day....
  37. #87
    Jun 2011
    683
    Interesting developments from the L1 blog:
    If you place an order for a LONDINIUM I now it not only comes with solid wenge handles, but in the interests of burnishing its compact commercial credentials, it now comes with pop-off panels which attach to a subframe just as you find on a commercial machine, which gives the machine all rolled edges (i.e. no raw/cut edges) for a more refined look
    As previously posted LONDINIUM I now comes with three LED signal lights, white (power), blue (water inlet solenoid open), and red (immersion element on). These lights have all been moved closer to the centre of the machine for ease of visibility, as has the manometer
    The drip tray is also slightly different, with the 45 degree up stand on the back removed as a result of customer feedback, and a slightly different grate
    The Luxe is also now discontinued, the machine Andy received is looking more and more like a prototype. Improvements based on user feedback, sure, and good on Reiss for pushing Fracino to use better / more complex construction methods for the panels, but that has to hurt for the early adopters.
    Roz and TC like this.
  38. #88
    Apr 2008
    Victoria, Australia
    2,079
    Thanks for the update Rick.
    It also puts egg on the faces of all those people around the globe who tried to give Andy grief over the review I wrote.
    Although I didn't get into the technical details, that's for experts such as Rick, all I did was state the bleeding obvious.
    Now look what's happened………… and I'm sure it wasn't the only L1 that was questioned over (aspects of) design, build quality and temp stability.
    Hurrah, for customer feedback! ;-D but I agree with your sentiment, Rick, re early adopters. :-(
    I knew it I knew it I knew it…:-D
    TC likes this.
  39. #89
    Mar 2012
    1,275
    ...and good on Reiss for pushing Fracino to use better / more complex construction methods for the panels,..
    Yes , but he is still very defensive about the basic thermal design !...
  40. #90
    Jun 2012
    Brisvegas
    157
    Ever try tell a Mutha she's carrying an ugly baby? : huh
    Ever bought a ver. of windoze 'before' the first 'Service Pack'... : tear hair
    Or perhaps the first year of a brand new model car... AU... (Ford not country) : puke...
    Or perhaps you just sobered up after the honeymoon... : eek
    Life's like that.... : pan
  41. #91
    Oct 2009
    60
    Extremely happy with my L1. Even happier that it was only 3K which is about half of the other lever which is was considering.
  42. #92
    Mar 2012
    1,275
    Quote Originally Posted by Ol_Grumpy View Post
    ..ahh!, but in this case the parent has actually changed his baby's appearance.....but is ignoring its tendency for bad behavior occasionally !
    Vinitasse likes this.
  43. #93
    Jun 2012
    Brisvegas
    157
    I like the Volkswagon Amorok- 4wd double cab ute. I am a long term member of AusAmorok forum and have the same avatar. Anyway, This car was sold around the world for over 3 years before it was sold in Australia- apparently to 'prove' the vehicle.
    It was marketed here as 'Proven tough in Dakar', etc by VW Aus.
    The Marketing was amazing, and in hindsight appears to be a croc of s$@t.
    Now some years later it is absolutely clear those 'first adopters' got quite a 'buggy' version of the vehicle... The current resale on those 'first adopter' vehicles is horrendous. This is a $40-$50k vehicle and people are losing many tens of thousands at re-sale. There have been more than a few catastrophic failures of engines because of a stupid design fault on the timing belt cover. A small stone gets in and bang- engine kaput. Numerous gearboxes because of stupid design/placement of a slave cylinder inside the bellhousing, etc, etc this is a multi-multi- million dollar design/production team and they have made some amazingly stupid and in hindsight glaringly obvious mistakes... It happens....
    Yet, Others have invested tens of thousands pimping or modding their vehicle and they love them, warts and all. They mod their vehicles grudgingly or cheerfully, either way.... It happens... And individual vehicles can have enormous performance improvements because of it....
    For some people they have had no issues and don't understand what all the fuss is about?
    My point is like it or hate it, this is how things are.
    This is how the world works- whether it's a new 'high-end' consumer coffee machine or even a high-end vehicle from one of the worlds largest car manufacturers...
    Over time, the manufacturers are making small and sometimes large changes and improvements in the product... And so they should...
    I don't see any VW Aus. Executives putting their own name up for direct contact.....
    I don't like many things Reiss has done and I definitely have a love/hate thing going with his machine (I don't own one),
    But man, the guy has some big Kahunas and I admire and respect that...
    I'd give him a little more slack than some others are want to do....
  44. #94
    16,202
    Just wondering Rick and Andy, if you have seen this blog post on the Londinium website...
    Dear Coffeesnobs forum... - Blog - LONDINIUM Lever Espresso
    14,665
    I guess it's not surprising that a leopard rarely changes spots.
    The only Londinium I have seen is Andy's. I did get to see Rick's before and after data we also have this thread to see what Rick did to the machine to get it to work well.
    For mine, out of the box, there is no comparison to the build, performance nor finish of the Alex Leva. It's not even significantly cheaper.
    I'd be surprised if you'd require fingers and toes to count Londinium stock in Australia.
  46. #96
    May 2008
    3,912
    LONDINIUM I will always be the machine that people refer to as 'the one CoffeeSnobs forum tried to kill at birth
    That's some grudge Reiss bears. I say if his machine is a success then good luck to him. Ther are plenty of happy users out there. The L1 was a machine I was quite interested in until...wll, you know .
    Here's another perspective.
    Australium - Yeah mate, it's much better than a Londinium Luxe
  47. #97
    Senior Member Bosco_Lever's Avatar
    May 2009
    QLD
    431
    Quote Originally Posted by flynnaus View Post
    '[/FONT][/COLOR]
    Hardly surprising he carries a grudge. I am glad his machine is a success, as he identified a niche market and successfully fulfilled it.
    As to the ego aspect, it is prevalent everywhere. Some mistakenly think it works to their advantage, but there are many customers who can easily see through this and simply decide not to buy from people or companies with such an attitude. It also applies to this forum.
    Given this thread was quiet for so long, posting about the blog post is certain to rekindle interest in his product.
    Personally, I gave up reading his blog long ago, as the undertone irritates me. There are a couple of companies in the coffee business who regularly issue a newsletter. These are interesting and informative; and I enjoy reading what people like Alan Frew have to say.
    flynnaus, shapeshifter and TC like this.
  48. #98
    Mar 2004
    Internet
    16,292
    Blog Entries
    1
    Yep, that's it in a nut-shell. I (and other early adopters) was sent a dud that didn't go close to meeting the marketing hype that it was pimped with.
    Not till now. Wow, what a tosser he is. This was never personal, the expensive machine was a dud and it took a pile more expense to make it work like it should have when it arrived.
    I do find it interesting that many of the (obvious and stupid) problems that we found in the first model were fixed in the following builds... but I don't remember hearing thanks for the development work
    Here's hoping that machines he ships today are working far better and if our input helped deliver a better machine than that's great news for the consumer.
    Dimal, flynnaus, chokkidog and 3 others like this.
  49. #99
    16,202
    Quote Originally Posted by Bosco_Lever View Post
    Personally, I gave up reading his blog long ago, as the undertone irritates me. There are a couple of companies in the coffee business who regularly issue a newsletter. These are interesting and informative; and I enjoy reading what people like Alan Frew and Jeff Carlini have to say.
    Me either, have never read this blog at any time. Just came across this post while looking for something else entirely different, and was quite surprised about the tone there-in. Checked through this thread and found that he didn't, apparently, think that it would have been better form to have at least made some kind of referral....
    Oh well, as Andy says - What a tosser....
    Jan 2010
    68
    As someone who watched the development of Londinium I (and the blog)from the ground up, and waited patiently to order one, Reiss bitter post doesn't surprise me. Although I was very keen to order a Londinium, I did find the constant condescending tone irritating. Early adopters complaints of siphon stall were ignored until they could be ignored no longer and changes to the design were eventually begrudgingly made. The whole fiasco (and Andy's saga) made me lose confidence, and so when the Alex Leva hit the market it was a no brainer. Very little difference in landed price, and with local servicing if required. I'm sure there are now many happy Londinium I owners out there, but contrary to Reiss constant assertions, it ain't the only current Lever capable of producing top espresso (and with early production models clearly failed too often).
    TC likes this.
Tags for this Thread
