Page 2 of 2 FirstFirst 12
Results 51 to 93 of 93
Like Tree31Likes
Thread: Faema Due - $100
  1. #51
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    909
    Remove pump. Soak entire pump in a container of de scale solution letting the solution flow through the pump. Let it sit for a few hours. Turn flat drive blade to circulate solution through vanes. Use gloves. I do a 50/50 water/descale ratio. Use liquid de scaler. Try to remove bypass internals after a few hours.
  2. #52
    May 2014
    526
    greencardigan,
    Your red fiber washer looks like it may be off the mushroom cap,off one of your group head's,usually fitted to these cap/mushroom bolt thingy!!
    Cheer's
    Mick.
  3. #53
    Feb 2008
    Wollongong
    148
    I've pulled the pump apart and have done a descale. The bypass internals have come out ok but the stainless shaft part with the small o-ring is still quite tight in the nut piece. I can only just move it in and out with my fingers. Should it move freer than that? I'll give a bit more descale and clean. Maybe it just needs a new o-ring.
    There is a spring inside the pump outlet side. Any idea what that is there for?
    The big nut adapter thing on the pump inlet has metal wool or something in it?! Normal? I guess it could just be a filter of sorts?
    Mick, the red washer isn't from the mushrooms. They both have white teflon washers already. I am now thinking it was on the hot water downpipe.
    mulquemi likes this.
  4. #54
    Dec 2013
    Hervey Bay, QLD
    909
    Don't worry about the spring in the outlet. Ensure the steel wool water filter passes water (you can descale it). Don't worry about the ss shaft w/ o ring not moving easily - it isn't supposed to. Put a little food grade silicone on the o ring and ensure it moves up and down slightly under tension and can spin 360 in the brass shaft.
  5. #55
    Feb 2008
    Wollongong
    148
    One more thing...
    My OPV seems to be stuck. I can't adjust the spring tension using the adjustment slot on the front. I've taken it apart and the threaded piece is locked into the housing. No amount of penetrating oil, heat or sweat has got it to budge. Any ideas?
  6. #56
    Dec 2013
    Hervey Bay, QLD
    909
    Spin the flat blade and listen for gentle suction sounds that the PTFE vanes make. The shaft should spin pretty easily with two fingers with a little friction (vanes are working).
  7. #57
    Dec 2013
    Hervey Bay, QLD
    909
    Hmmm ... might be seriously scaled up. Can you post an image?
  8. #58
    Feb 2008
    Wollongong
    148
    Photos of stuck OPV (expansion valve). It's a bit dinged up after my attempts to unscrew it.
  9. #59
    Dec 2013
    Hervey Bay, QLD
    909
    Nice! So ... no joy screwing in the adjustment slot screw inside, hey?
  10. #60
    Feb 2008
    Wollongong
    148
    No movement of the slotted part at all.
  11. #61
    Dec 2013
    Hervey Bay, QLD
    909
    How are the internals? Spring and seal mechanism? Is the seal ringed-out and hard? Can we see an image of the seal face and the spring connected to it?
    The adjustment end: put it in a small plastic container covered with water. Freeze it. Then, after frozen, pour water just off the boil on it in the sink. Run cool water on it until you can pick it up and clamp it in a vise; Vice Grips or a shifter. Try unscrewing it with the biggest slot screwdriver that'll fit. Apply constant and increasing pressure.
    Contraction and expansion may free it up.
  12. #62
    Dec 2013
    Hervey Bay, QLD
    909
    Another idea that works is stacking flat washers inside to provide more spring tension.
  13. #63
    Dec 2013
    Hervey Bay, QLD
    909
    Water can still exit the OPV
  14. #64
    Dec 2013
    Hervey Bay, QLD
    909
    Or, you buy a new OPV from Pedro @ Coffee Parts. It's 3/8" or 1/4" BSB and discharges into the drain cup or tray.
  15. #65
    Feb 2008
    Wollongong
    148
    Quote Originally Posted by sprezzatura View Post
    Internals of the OPV look ok. The seal was a bit gunky but is still soft and flexible.
    I have the housing in the freezer and will try again to release.
  16. #66
    Feb 2008
    Wollongong
    148
    Freezing then heating the OPV helped and I was able to release the thread. The thread was scaled up plus I think it had been over tightened.
    Time to get it connected back up and see if the descaled pump can produce more than 3 bar pressure.
    Dimal and sprezzatura like this.
  17. #67
    Dec 2013
    Hervey Bay, QLD
    909
    Fine work, Mr. Tech.
  18. #68
    Feb 2008
    Wollongong
    148
    Quote Originally Posted by greencardigan View Post
    Coffee Parts doesn't seem to list the old version of the steam valves that my machine has. Will I be able to find parts for the old valve locally? Or will I need to get the new valve unit as a complete unit?
    Coffee Parts - Newer version
    Attachment 11856
    My machine seems to have this older version as shown on Espressoparts
    Attachment 11854
    I received some replacement parts from Coffee Parts. I ordered the replacement seals/gasket/spring parts used in the water inlet valves with the hope that they fitted my old steam valve. The seals and gaskets were fine, but the spring is quite different. My old spring is much shorter and stiffer. The water inlet valve spring wasn't closing the steam valve properly. The old spring is still fine so no problems there.
    Old steam valve spring on top
    New water inlet valve spring below
  19. #69
    Feb 2008
    Wollongong
    148
    I've replaced the 3-way valve seals, and group head jet seals and have connected everything back up to test.
    No leaks, and more importantly, 9 bar pump pressure! Although I'm getting 9 bar with and without the blind filter. Is that normal?
    Pump pressure with and without blind filter
    Also when the boiler auto fill is running it's showing 8 bar. Seems a bit high?
    Next step is to get the boiler up to temp again to check the repaired leaky steam valve. Getting close to a fully functioning machine.
    260zman likes this.
  20. #70
    Feb 2008
    Wollongong
    148
    She's alive! I managed to make a coffee on the machine this morning! The extraction wasn't the best but was drinkable. My quick temperature check showed water from the group was around 92-93 degrees.
    Still a few minor issues. The repaired steam valve no longer leaks out the back through the main seal but slowly leaks steam through the wand. Would this settle down in time after the new seal settles in? Or possibly I need to put a spacer behind the spring to increase the sealing force.
    Also the OPV is slowly dripping regardless of the setting. Again, this may be just the seal re-settling?
    260zman likes this.
  21. #71
    Dec 2013
    Hervey Bay, QLD
    909
    OPV may drip anyway. Thermal expansion of water in circuit. Don't worry about it if you're getting your 9 bar at group. Steam. Always a hassle with this style valve. Occasionally reseating the brass part of the seal area allows the gasket to seat completely. It's annoying but can be lived with.
  22. #72
    Dec 2013
    Hervey Bay, QLD
    909
    Try your spacer; it may work.
  23. #73
    Feb 2008
    Wollongong
    148
    I've been getting some really excellent extractions from this machine! I'm using the single basket from my Breville BES920 with my usual grind and dosage but the Faema extraction seems a step up from the BES920.
    I'm still mesmerised by the steam volume! Anything I can do to make it more manageable?
  24. #74
    Dec 2013
    Hervey Bay, QLD
    909
    Raise water level probe. Less steam volume.
    260zman likes this.
  25. #75
    Dec 2013
    Hervey Bay, QLD
    909
    Plug some of the nib holes. Or, enjoy the steam power of a commercial machine, hey?
  26. #76
    Feb 2008
    Wollongong
    148
    Does anyone know where I can source these spring clip things? They clip around the plastic standoffs on the front button panels to hold it on. I'm missing three.
  27. #77
    15,800
    Perhaps a Circlip of the right size might do the job...
    sprezzatura likes this.
  28. #78
    Jul 2011
    Point Lonsdale Vic
    20
    Maybe a press-on "starlock" washer, designed to retain a part on a metal shaft, very hard to remove though.
    Ron
  29. #79
    Dec 2006
    Perth WA
    568
    Actual purpose not clear. I am thinking you could make one considering the patience and skills you have demonstrated. Is it just a flat disk or does part of it go through the panel. Is there one or are there a lot of then required. It's design is quite clever but I have not seen one before.
  30. #80
    Feb 2008
    Wollongong
    148
    A few 15mm binder clips borrowed from work has done the trick.
    Dimal, sprezzatura and 260zman like this.
  31. #81
    Dec 2013
    Hervey Bay, QLD
    909
    Hey! My La Marzocco steam wand circlip! Been looking for that everywhere since launching it during a overhaul.
    Dimal and 260zman like this.
  32. #82
    Member 260zman's Avatar
    Apr 2014
    43
    yep, heaps of steam!! its great.
    there are a few different option steam nozzles available. on my daily machine I have one steam wand with 4 holes, which I use for larger quantities of milk, and the other wand has 2 holes, which seems to have a lot less grunt (makes it easier to do small amounts).
    Also what is your boiler pressure at? if pressure stat is set too high, my understanding is you will have more steam pressure. This really needs to be set by measuring the water temp coming thru the group though, as you don't want to reduce the temp/pressure to the point that it compromises on extraction quality.
  33. #83
    Apr 2014
    43
    Try these,
    I need some too and we've got an account with them Comac
    Sorry mods, I hope this wont breach website rules?
  34. #84
    Feb 2008
    Wollongong
    148
    These look like a good alternative too. Metric Grip Rings For Shafts Without Grooves
    I added a small spacer (maybe 3mm) in front of the steam valve spring and it no longer leaks. I think it probably needs reseating ideally but the spacer is working so I'll leave it be for the moment.
    Justin, any progress on replacement side panels? I have been investigating making some carbon fibre panels or possibly just carbon fibre skinning the broken panels.
  35. #85
    Senior Member artman's Avatar
    Jun 2006
    2,198
    With the steam, it's not just the number of holes but also their size (total area).
    I have used a 4 hole tip with 1mm holes and it worked great for microfoam.
    Apr 2014
    43
    Hey brad,
    Well done, you've been ticking the issues off one by one. Great diagnosing too.
    No luck with panels yet, although I've just used some jb weld kind of stuff to fix up the cracks. I've also toyed with the carbon fibre idea, but I haven't got past the watching YouTube vids on how to make the molds etc! I figured that gluing up at least one good set of originals would be a start towards making a mold.
  37. #87
    Feb 2008
    Wollongong
    148
    I got a few new steam tips from CoffeeParts. A three hole and a two hole both with the same hole diameter as my existing 4 hole tips (1.5mm?). I'm finding the 2 hole tip very manageable and have some latte art happening again. Haven't tried the 3 hole tip yet. The threads on my steam wands don't quite match the new steam tips so they've been a bit troublesome to get on. I suspect my steam wands are not original.
  38. #88
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,840
    Nice work. And nice rosetta!!! It's starting to all come together.
  39. #89
    Feb 2008
    Wollongong
    148
    Just wrapping up this thread...
    I sold this machine a few months ago for $300. All up I spent around $50 in parts on top of the $100 purchase price. I believe it was heading to a fast food shop in Nowra for temporary use.
    Was sad to see it go, but I've just picked up an almost identical machine in a similar condition. New thread starting soon.
    Dimal and LeroyC like this.
  40. #90
    Feb 2008
    Wollongong
    148
    Link to my photo gallery for this machine.
    https://goo.gl/photos/ynMQk4c2ZRHj6yhJ7
    Dimal likes this.
  41. #91
    15,800
    Great idea for future reference 'gc'...
    Feb 2017
    2
    Help with replacing heating element in my Faema
    Hi all, Ive got a fame machine and need to replace the heating element ....... is there anyone out there that would be interested in showing how to replace an heating element. I'm an electronic engineer and would love to learn how to repair/rebuild my own machine. Can anyone help. I'm based in Doncaster in Victoria. Happy to use Skype if you can help but are interstate. Many thanks, Kind regards, Steve
  43. #93
    Jun 2006
    BRISBANE
    1,924
    There might be some useful information (generally) here
    http://coffeesnobs.com.au/brewing-eq...out-350-a.html
    ps. They are an awesome machine
    Dimal likes this.
