Page 2 of 2 FirstFirst 12
Results 51 to 75 of 75
Like Tree127Likes
Thread: Advice Opinions - Valexia or Pro800
  1. #51
    Jun 2005
    184
    Quote Originally Posted by K_Bean_Coffee View Post
    I'll leave it to the Aus Importer (2MCM) or an Aus Izzo retailer to comment on differences between Izzo Leva and Izzo Valexia so that I don't misrepresent a product I don't sell in any way.
    Cheers, Paul
    Identical internals and Leva.
    External aesthetic updated on Valexia to track changes to dual boiler machine.
    As I understand it.
    Magic_Matt and kbc like this.
  2. #52
    Feb 2013
    79
    Boy, that Brita water filter kit and the filters are expensive! I use a twin under sink kit from here which works great is excellent quality (around $200)
    Sorry, just remembered the site rules about posting to external sites so I removed the link. Suffice to say there are plenty of other options that are heaps cheaper and every bit as good. In fact it looks like the Brits only does 10 microns. Easy to find cartridges that filter down to 0.5 microns.
  3. #53
    Site Sponsor Casa Espresso's Avatar
    Dec 2008
    Australia
    667
    [QUOTE=wfdTamar;608713]Boy, that Brita water filter kit and the filters are expensive! I use a twin under sink kit from here which works great is excellent quality (around $200)
    Most of those systems you have linked to here look like drop in type sediment filters.
    These are a very, very different system from the Brita C series units that are specifically designed for coffee machines, have adjustable by pass filter heads and water softening agents.
    At circa $229 for a Brita C50 with a pressure reduction valve included, I will leave it to the purchaser to decide which one is best for them....
    Filtration Systems - Spare Parts and Servicing
    Regards
    Casa Espresso
    Casa Espresso - Home
    Dimal and Magic_Matt like this.
  4. #54
    Sep 2007
    Northlandia
    1,332
    200 bucks to protect a ~$5,000 investment is hardly excessive.
    Skimping on filtration is a bad idea unless you know exactly what you're buying imo. 🤔
    At least one site sponsor does also sell another brand of filter that's designed for coffee machines and is cheaper than the Brita C150. I went for Brita as anyhow for ease of sourcing replacement filters.
    Casa Espresso likes this.
  5. #55
    Feb 2013
    79
    They have two cartridges - one carbon (from coconuts) which can be had down to 0.5 microns so that's way better than the Brita 10 micron. Also a sediment one again down to 0.5 micron. You can get kits with more cartridges for filtering other stuff.
    Frustratingly the Brita site is light on for a description of what is in their filters. It mentions activated carbon and shows a small amount in a diagram (about a quarter of the cartridge volume). Most of the filter is some unknown substance (for the sediment, chemical and TH?), but it doesn't say what it is. It could be similar to what the sediment filters above are? Found this on another site:
    - 3 stage Brita Purity filter for effective sediment, chemical and TH reduction.
    - Blending valve on the head to adjust for softer and harder water areas.
    Not sure what 'TH' is. The blending valve would be useful if your water is too hard or soft, but that looks to be the only thing that it has the others don't.
    So I'm not convinced they are better than the other ones (if your water hardness is ok). In fact due to their being 10 micron, not as good (although they say 'up to 10 micron' which is weird, surely it should be 'down to'?).
    PURITY Finest C | BRITA Professional
    Gawd blimey - in googling I found a 14 stage filter! Starting at US$1600!
    Stage 1 - Filtration - Five Micron Sediment Pre-Filter
    Stage 2 - Filtration - Internal Coconut Shell Carbon Filter
    Stage 3 - Purification - Reverse Osmosis Membrane
    Stage 4 - Purification - Mixed Bed De-Ionization System 1
    Stage 5 - Purification - Mixed Bed De-Ionization System 2
    Stage 6 - Holding Tank - standard tank holds about 3 gallons of pure water. Other tanks are available.
    Stage 7 - Sterilization - 14 Watt Ultraviolet Light
    Stages 8 & 9 - Restructuring - Homeopathic Memory, Molecule Coherence
    Stage 10 - Reprogramming - Adding Natural Mineral Properties
    Stage 11 - Reprogramming - Adding Natural Earth Properties
    Stage 12 - Reprogramming - Lowering Surface Tension
    Stage 13 & 14 - Remineralizing - Coconut Shell Carbon Post-Filtration and Alka-Min Ionic Remineralization
  6. #56
    Feb 2013
    79
    Ha ha TH is total hardness
    Commercial link removed as per Site Posting policy
    That page has a convincing argument for something other than the two cartridge type kit.
    What you could do is have just the two cartridge holder and filters plumbed in line before the Brita. This would give you finer filtering and extend the life of the expensive Brita filter. That way you get the best features of both systems.
    Magic_Matt likes this.
  7. #57
    Feb 2013
    79
    Well 12 months at $150 a pop. Just been gawking around eBay and there are decent triple cartridge kits there (sediment, carbon, hardness) for under $150 - and the total filter mass is 3 times the Brita. So the only advantage the Brita has over those is the adjustable hardness, but once you measure your water hardness and get the appropriate cartridge you wouldn't need adjustability. So all the Brita has is a brand name. No sale Jose :-)
  8. #58
    Senior Member Logga's Avatar
    Mar 2010
    Napier, New Zealand
    305
    [QUOTE=wfdTamar;608722]Well 12 months at $150 a pop. Just been gawking around eBay and there are decent triple cartridge kits there (sediment, carbon, hardness) for under $150
    I have the Brita purity finest c150, and agree with K-Bean, running costs are low. They last longer than 12 months, its how much water goes thru, so with the amount of water I use for one coffee plus machine maintenance, a filter will last me about two years. The filter then would be costing me about five cents a day, pretty cheap machine insurance .
  9. #59
    Oct 2015
    17
    So I have had a week or so to play with new machine. And it's​ brilliant. Glad I went with the Izzo rather than the Profitec even if the plumbing at the moment is an absolute PIA.
    I got a WeMo timer to turn it on automatically and remotely which mostly alleviates the warm up time. The "I think I feel like a coffee" does still have to wait though.
    The Leva side of things is brilliant. Far from being more difficult, I would say it's easier than the Breville/Sunbeam machines to both get a great coffee and keep the thing clean. And the process of making the coffee with the lever is enjoyable
    Dr_Dave, Casa Espresso and 338 like this.
  10. #60
    Dec 2008
    Australia
    667
    Quote Originally Posted by wfdTamar View Post
    We use Brita in most of our commercial accounts. Brita or Evipure are the industry standards in commercial applications. Carry that across to a domestic situation and you are on the right track.
    We would change a C150 every 6 months in a commercial application, so really a C50 (or Evipure equivalent ) should last 12 months in a domestic environment. The only difference apart from the size between the C50 and C150 is the amount of water that can run through their rated life. In fact the C50 is IMO better for home use as it is just a bit smaller then the 150 and will fit under most kitchen benches.
    A C50 replacement filter is under $100, every 12 months, its a small investment.
    Antony
  11. #61
    Feb 2017
    61
    [QUOTE=Logga;608724]
    If I remember correctly, the filter will need to replaced after 12 months of use regardless of how much water goes through it.
  12. #62
    Oct 2015
    17
    Should also add a public thanks to Antony at Casa Espresso for the help with the purchase, all the questions and the photos requests. I am sure at some time he must of wondered if the sale was really worth it.
    No not really. Antony would be too much of a gentleman to think such things.
    In all seriousness though, thanks Antony, much appreciated.
  13. #63
    Dec 2008
    Australia
    667
    [QUOTE=sacsnob;608729]
    Quote Originally Posted by Logga View Post
    Yes 12 month replacement is really the go tied in with your 12 month group head service.
    Its another argument why, in a domestic environment, the C150 (as opposed to C50) is a bit of overkill
    Antony
  14. #64
    Dec 2008
    Australia
    667
    Quote Originally Posted by K1LL3M View Post
    Very kind words.
    Thank you sir, I dip my hat to you
    Antony
    K1LL3M likes this.
  15. #65
    Mar 2010
    Napier, New Zealand
    305
    Why is that?
  16. #66
    15,798
    Well...
    The Cxxx Finest does more than just soften the water. It also buffers the pH level to maintain a constant pH output, as well as that, eventually, the carbon element becomes exhausted as will the particulate filter element...
    It's all probably a "How long is a piece of string?" sort of argument regarding how long it will take for the filter to require replacement. Unless you have access to suitable, reliable test equipment, then changing out every 12 months seems like cheap insurance to me...
    Feb 2017
    61
    Quote Originally Posted by coffe4me2 View Post
    Thanks Mal.
    How long is a piece of string seems to be the qn. I'm going to go with 24 months. Someone told me Melb water is the 3rd best in the world. Not sure if thats true but I know it's good.
    JT
    I was told that overtime bacteria can grow inside the carbon filter which makes it necessary to replace it every 12 months.
  18. #68
    15,798
    Actually, the use of effective water softening agents/equipment reduces the proliferation of microbes such as bacteria....
    Feb 2013
    79
    See, I'm used to talking on OzBargain where people want the best equipment at the lowest price. I suspect here we have people being blinded by the marketing phrase 'designed for espresso machines' and also others that sell the Brita (quite understandably) pushing it over an alternative that may be at least as as good, certainly cheaper and actually better than the Brita (given the fineness of its filtering over the Brita and far cheaper & bigger filters).
    Another problem I foresee with the Brita is it uses proprietary cartridges so when Brita dump that design (which they regularly do with their retail jug filters) you have to buy a whole new kit. Hopefully filters would still be available for the working life of the kit.
    Sorry, I realise there is a more apt thread for this discussion. Doesn't matter anyway, coffee snobs are well used to paying over the odds for equipment. :-)
  20. #70
    Sep 2007
    Northlandia
    1,332
    "May be" is a key phrase there. 🤔
  21. #71
    Dec 2009
    361
    [QUOTE=Logga;608738]
    Quote Originally Posted by sacsnob View Post
    Why is that?
    Hygiene.
    I run a 3m HF15 system which is similar to the C150.
    Each cartridge can handle far more throughput than a domestic user will put through it, but they are very clear that you should replace the cartridge after a year regardless.
  22. #72
    15,798
    True Mal, but in my old lab I had a system running a 50um filter, a 10um filter, a DI tank, a carbon filter and a 5um filter to finish off. I still got bacteria growth on the carbon filter and had to replace it every 6 months.
    When my current C150 filter gets to 12 months I'll dissect it.
    Cheers, Paul
    Yep, get that...
    Why I used "reduce" rather than "eliminate"...
    kbc likes this.
  23. #73
    Mar 2007
    198
    Speaking of c150 finest, do people know if this is also ok for drinking water. I took a line off mine to a filtered water tap about 6 mnths ago. I can always taste a slight thin bitterness in the water compared to unfiltered.
    I am now due for a replacement cartridge and wondering if there is somthing better suited to both drinking and coffee machine water, or wether I should stick with the same thing.
  24. #74
    15,798
    Hi mate.
    I drink from it and get very pure clean tasting water.
    JT
    Ditto...
    Beautiful sweet water here too.
    matth3wh and kbc like this.
  25. #75
    Mar 2007
    198
    Good to hear. My filtered water is not bad by any means, and it is actually softer and sweeter than tap water too. I can just taste somthing extra in the aftertaste - a slight bitterness that is not in the normal tap water. I am sure it's nothing to worry about. My filter is now13 months old. So time for a new one anyway.
    Dimal, matth3wh and kbc like this.
