Page 3 of 3 FirstFirst 1 2 3
Results 101 to 120 of 120
Like Tree207Likes
Thread: Rocket R58 vs Profitec 700 vs ECM Synchronika
  1. #101
    Apr 2013
    33
    Quote Originally Posted by bowser View Post
    Anyone have the details on the improved hole size?
    old and new, hard to believe the larger holes make so much difference
  2. #102
    Jul 2014
    90
    Do you have anyway of measuring the holes?
  3. #103
    Apr 2013
    33
    The small ones are 0.8mm, haven't bothered to measure the bigger ones
  4. #104
    Jul 2014
    90
    thanks, i'll check what mine are tomorrow. I may drill them out to 1.2mm and test
  5. #105
    Jul 2014
    90
    mine are 1mm
  6. #106
    Sep 2007
    Northlandia
    1,304
    I grabbed a replacement tip today. Factory options are two or four hole; the guys here send the factory two-hole tips to a local place to have a third hole drilled in the centre for people who want a bit more steam performance. It doesn't look noticeably different to my stock two-hole tip otherwise; the holes are perhaps positioned slightly further from the centre, but don't visually look to be any larger.
    What a difference in performance though! Steaming power is now on-par with the LMLM (though of course it won't keep up the power for as long with the smaller boiler).
    Between this and my fast grinders I'm now able to sleep for at least an extra 90 seconds every morning
  7. #107
    Aug 2017
    30
    Lots of happier users ☺
    I remember Matt Perger explaining something when talking about his Tampers and the effect of extra 0.05mm; complicated maths, where if a circumference of a circle is increased by just a little, total surface area increases massively.
    I'm guessing it's the same reasoning here..
  8. #108
    Sep 2007
    Northlandia
    1,304
    Quote Originally Posted by u2jewel View Post
    I may yet drill out the original two-hole tip a little; most of the time I'm using a 350ml jug so really don't need high power. But it's good to know the power is there if needed!
    u2jewel likes this.
  9. #109
    Senior Member magnafunk's Avatar
    May 2014
    East Kimberley, WA
    494
    I recently reamed out my stock BFC 2 hole tip with welding tip cleaners. Worked a treat if you don't have suitable drill bits. I always assumed that it was slow to steam because I had come from a cimbali junior and was spoilt before. Turns out the 1.3l boiler can hold it's own speed wise if you're doing up to ~400ml
  10. #110
    Jul 2014
    90
    Damn you guys, i'm going to have to mod mine now
    Magic_Matt likes this.
  11. #111
    Jul 2014
    90
    Got the better of me and I drilled a third 1mm hole in the centre. Definitely an improvement, much stronger frothing now. They should come like this from new
  12. #112
    Aug 2017
    30
    I've had my machine now for about a month, and suddenly remembered this post.
    My synchronika was shipped from Bella Barista (UK)
    I only realised the other day, but mine came stock with 5 holes!
    All the websites and brochures (that I was looking at) said that it was a 2 hole tip, so I never questioned it.
    Just as you guys might be curious as to how this 5 holer goes, I'm curious how the correct 2 tip is, and have a nagging feeling that maybe 2 is more suited for me. I'm having a hard time taming the vortex.
  13. #113
    Marcus
    Jun 2016
    Stockholm, Sweden
    50
    Sorry for the late update.
    I added Pro 500 to the spreadsheet: https://docs.google.com/spreadsheets...it?usp=sharing
    Still waiting for more information regarding the pre-infusion differences between Profitec, ECM and Rocket
    - Marcus
  14. #114
    Jul 2014
    90
    Wow 5 holes would be too much I think. 3 works great.
    you could remove the tip and mix up some metal putty like this Devcon https://www.blackwoods.com.au/part/0...ss-steel-454gm and block up the extra holes
    Magic_Matt and u2jewel like this.
  15. #115
    Sep 2007
    Northlandia
    1,304
    Yeah, with a three-hole tip I've found it's on par with the LMLM. 5 would make life difficult I imagine!
    Espresso Connect had the standard two and four hole tips for $10, so it shouldn't cost much to grab a few and experiment.
  16. #116
    Aug 2017
    13
    Quote Originally Posted by Tanax View Post
    - Marcus
    Some suggested edits:
    Rocket Typo V Vibration
    - Insulated boiler should be yes
    - No-burn steam-arm should be yes
    - No-burn water-arm should be yes
    - Steam tip holes should be 2
    Rocket Appartamento
  17. #117
    15,606
    No need to involve chemicals that may or may not be food safe...
    Just jam a toothpick into the unwanted hole(s) then break or cut off.
    338 and u2jewel like this.
  18. #118
    Marcus
    Jun 2016
    Stockholm, Sweden
    50
    Quote Originally Posted by Dazzy View Post
    Rocket Appartamento
    I appreciate it! Updated the document with your suggestions.
    If anyone else has more, keep 'em coming or send me a private message
  19. #119
    May 2005
    Perth
    1,033
    I remember buying two holed tips for my Bezzera years ago. All this stuff is available on the internet. The smaller the holes, the higher the velocity, better foaming but increased times. I preferred these to the standard one on the Bezzera which was for steaming a one litre jug of milk not the 150mls we might use.
    My tip anyway...
  20. #120
    Senior Member artman's Avatar
    Jun 2006
    2,086
    Yep it's not just the number of holes but their size (total area). The boiler capacity and power also should be matched (can't go too big if the boiler can't keep up).
    My favourite is 4 holes at 1.0mm diameter, have used this over 3 machine. Quite quick and easy to do nice microfoam.
