Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By level3ninja
Thread: La Nuova Era Altea pours faster from one side???
    Jul 2017
    1
    Hey anyone have any idea why my La Nuova Era would be pourng faster out of one side rather than the other?
    Machines works well but there's definitely a difference between the speed of the pours on each side...
    ie - one pours much faster than the other, even with exact coffee measurements and tamp pressure..
    machine uses e61 and is running through a good filter- it's a manual lever system.
    HELP>>
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    290
    I get this sometimes when some beans are over 3 weeks post roast and it also seems worse and more frequent during periods of hot dry weather. The Mazzer Mini e I use exaggerates the problem, I use some WDT to get me through those days.
    Nov 2013
    Casula, NSW
    587
    Someone recently mentioned that this was happening to them and when they cleaned their grinder part of the burrs were clogged with ground coffee. After cleaning the burrs the flow returned to pretty even. Might be worth checking out your grinder.
    Dimal likes this.
