Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By MorganGT
Thread: To convert or to not convert - Faema Smart S-2
    Dec 2017
    1
    Hi Guys,
    I have a 2009 Faema Smart S-2 described on the Faema website as semi-automatic, that is, it has just one button for each of the two groups. The button is used to manually turn on and off the water flow when brewing. The A-2 is described as their automatic machine and has 6 buttons on each side. It looks like there is the same size cutout in the machine so that the touch pads are interchangeable.
    Does any one know whether I can convert my semi auto to an auto machine
    so that I can use 6 buttons to control the amount of coffee brewed?
    If I replace the single buttons with the 6 button touch pads what else do I need to do to convert it? I think there is a microprocessor in the auto models but that is about the extent of what I know about the electronics.
    Any thoughts would be greatly appreciated.
    Rudi
    Aug 2010
    322
    It's a lot more than just some extra electronics - you need to add flowmeters, which requires replacing a lot of pipework to add them plus a bunch of extra wiring, plus the appropriate new control board and touchpads.
    Essentially you would need an entire A-2 to pinch all the parts from, in which case you might as well just replace the S-2 with an A-2.
    Dimal likes this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,664
    Woah! Yeah doable, but itís a fairly big job and would end up being quite pricey.
