Results 1 to 4 of 4
Like Tree3Likes
  • 1 Post By pgseye
Thread: Plastic vs other material V60's
    Jun 2016
    64
    Hi Guys,
    I use a plastic V60 for pour-overs and find it quite good. I like the portability factor and that it's not so easy to break. However, I've read a couple of things suggesting that scalding water on plastics is not a good thing from a 'leeching chemicals' point of view.
    I'm actually a scientist in my day job, so I'm very evidence-based and take these sorts of claims with a grain of salt. Having said that I can't even find what material the V60 is made of, to be able to do a literature search on whether any toxicity studies have been done. In the scheme of life, I'd be willing to bet it's no more detrimental to your health than stepping outside in the morning and breathing the air, but curiosity has gotten a hold of me.
    Even though the ceramic/glass versions are probably a little nice aesthetically, the plastic version is completely functional and I'm having a hard time justifying the upgrade. Having said, are there any other better reasons to get one of the other models?
    Thanks,
    Paul
    Sep 2007
    Northlandia
    1,304
    I guess those materials would have more thermal mass, so if preheated might keep the brew warmer - or suck out more heat otherwise. But I'd say it would be pretty marginal either way TBH.
    I'm inclined to be sceptical of appeals to authority in general, but if it's approved food-grade material and intended to be in contact with hot water I wouldn't give it much thought. But if the ceramic/glass options appeal and health concerns help get you across the line, I say go for it
    Member GunBarista's Avatar
    Nov 2016
    71
    Quote Originally Posted by pgseye View Post
    Hi Guys,
    Paul
    I'm no scientist, but how much scolding can really be done during a pour over?
    Given that your brew water is generally around 91-95 degrees then minus the difference between the ground coffee which hopefully is sitting at room temperature - I'm sure by the time the solvent mixes with the soluble your vessel (the V60) should be no more than 90-/+ degrees. Especially being plastic (quicker heat disbursement)
    and the whole event shouldn't take you more than 3 minutes.
    Is that enough heat and time for chemicals to start leeching out?
    Jun 2016
    64
    Thanks for that guys - I'll stick with the plastic then!
    Magic_Matt likes this.
