Results 1 to 16 of 16
Like Tree8Likes
  • 1 Post By woodhouse
  • 2 Post By Beanz.
  • 2 Post By JCR33
  • 3 Post By JCR33
Thread: Where to after a Bacchi?
    Aug 2015
    9
    We are on our second Bacchi espresso maker and it looks like this one isn't going to stand the test of time either.
    My husband loves his single origin double espressos which are so hard to find in the cafes near us so where to from here? I don't drink coffee but i know he loves the process of the bacchi and i've no idea what to look for that may last a little longer but produce good results. We already have a grinder.
    Jul 2012
    653
    How much can you spend? Do you need to also be able to make milk drinks? Will you use it for entertaining or just for your husband?
    Aug 2015
    9
    No milk is ever used in the making of his coffee
    Entertaining isn't really necessary so it's really only for him.
    Senior Member woodhouse's Avatar
    Dec 2016
    165
    the flair espresso lever machine is cheap, easy to use and clean, and pulls amazing shots. i mostly drink filter, but every now and then i want a single origin shot.
    matth3wh likes this.
    Dec 2011
    PRL
    2,380
    Quote Originally Posted by Flinty View Post
    What is it that is actually failing on the Bacchi? I'm interested as I only use mine when I go away.
    Aug 2015
    9
    I'm not sure exactly what the problem is. Something to do with it leaking so it doesn't hiss like it should which means he has to time it. The first one the bottom somehow warped despite using it how it says.
    Aug 2015
    9
    Quote Originally Posted by Melbroaster View Post
    Sorry i didn't answer about price as I'm not really sure. Similar to the bacchi or possibly a bit more.
    Jul 2012
    653
    The flair is exceptional and probably unbeatable for similar money to your current device.
    Aug 2015
    9
    I have to say it looks pretty impressive. I'll look more into it and hopefully make a purchase.
    Senior Member Beanz.'s Avatar
    Apr 2009
    194
    The Rossa PG Air will make excellent shots every time. Highly recommended. If you have the grinder all you need are beans and a boiling jug.
    Better shots, easier and more reliable than the Bacchi. I have both so speaking from experience.
    There is a Rossa HC for sale on CS at the moment which is an absolute bargain and it will also make excellent shots once you are familiar with it. I cannot believe it was not snapped up in the 1st hour
    samuellaw178 and Otago like this.
    Dec 2011
    PRL
    2,380
    Fair enough, I've just made sure that mine has sufficient water and lubricate the seals with Inox and it's done exceptionally well, but I could just be lucky. Do you use it on a gas hob or something else? If you ever want to sell the old ones for parts PM me.
    Dec 2008
    13
    I have been using Bacchi occasionally for a few years, it is capable of producing some amazing shots, just a bit of practice to get the timing right.
    Dimal and LeroyC like this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,889
    Quote Originally Posted by JCR33 View Post
    Stunning! Is that yours?
    Dec 2008
    13
    Thanks, yes, it is mine!
    Dec 2008
    13
    Dimal, LeroyC and level3ninja like this.
    Sep 2010
    52
    maintenance
    Hi,
    Have just spotted all this…
    My Bacchi has also suffered with time and in part, seemingly in the same fashion as your husbands machine…
    I managed to find a local machinist to put the base plate on his lathe and true it once more.
    That fixed that problem, but there have been others… great idea, but….
    So, I am wondering what became of the failed machines, as I could use broken ones for parts…?
    (I'll also vote for the Rossa, particularly with a gauge.. better shot control…)
