Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By NickC
  • 1 Post By gazza
Thread: DIY Cold Drip Party Size for $37
    Jan 2015
    27
    So I went to Kmart today and bought all the stuff needed to make my new cold drip coffee maker. Quite pleased with the result, especially given the price tag - $37 all up. Could make over 5 litres in one go, so enough for a few people on a hot day! Hardest part was getting the flow rate right.
    matth3wh likes this.
    Jan 2009
    ACT
    147
    What is the container you have used for the water ??
    I have found that if you fill it with ice instead of water then the flow pretty well sorts itself out.
    Gary
    NickC likes this.
    Jan 2015
    27
    Ah of course - using only ice makes perfect sense. It was going a bit quick last night but this morning I see it stopped before it was finished. Not enough pressure from more water I guess.
    The top container is just a salad bowl with small holes drilled into the bottom, then sticky tape of the holes, then pin pricks into sticky tape.
    Jan 2015
    27
    *of the holes = over the holes
    Banned
    Jul 2017
    30
    Great Nick. Clever stuff mate
    Jun 2012
    12
    great DIY, but you can get drip coffee makers for around $55 including shipping on eBay. Just search cold drip coffee.
    The unfortunate thing about DIYs these days, is that somewhere in the world, slave labor and mass production has the item cheaper than you can DIY in most cases ... Pity it takes away from innovation .. but great idea none the less.
