Results 1 to 10 of 10
Thread: Bellman CX25P pressure query..
    Junior Member cub0ne's Avatar
    Nov 2017
    Mars
    6
    i bought a bellman cx25p and package doesnt include any pressure gauge with it. im so pissed and im still waiting for the sellers reply.
    i have a question regarding PSI. if i want to replace it with a 3rd party gauge. what would be required PSI? all i know is that it indicates 5bars on the original bellman pressure which i dont have..
    Dec 2011
    PRL
    2,466
    Yes, hi, how are you? Welcome to the site.
    Not 100% I'm sure what 'required PSI' is, but 1 bar = approx 14.5 PSI.
    Nov 2017
    Mars
    6
    thanks. ive been reading here for a while now.
    i used a converter too. so if im going to get a 3rd party gauge. it should be around 60-70psi.
    Nov 2017
    Mars
    6
    my seller will send a gauge.
    i have another question. what is the size of brass button connection of bellman's gauge? is it 1/4 or 1/2 npt? i will still get a 3rd party gauge and will make the original gauge as a back up..
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,012
    Quote Originally Posted by cub0ne View Post
    I’m not 100% sure, but I would imagine the gauge fittings on the Bellman would be BSP. Have you been told they’re NPT or are you assuming? Most likely size is 3/8BSPP, but as I said I’m not 100% sure.
    I wouldn’t recommend getting a 3rd party gauge. I looked into this in the past and to get a gauge that can tolerate the temps generated by something like a Bellman is really expensive. You can buy genuine Bellman gauges as a spare part from suppliers so if you want a spare this is what I suggest you do.
    Nov 2017
    Mars
    6
    so i really need to wait for the original bellman gauge. NPT is what is written on the gauges specs but i'll go with your advise. i shove a stainless bolt on the pressure gauge port for me to use it. its working fine now without the gauge. more like guessing the pressure..
    Sep 2013
    2,012
    Ok, maybe it is NPT. I suppose its just as likely as BSP. Di Bartoli have genuine Bellman gauges as a spare part for $40.
    Nov 2017
    Mars
    6
    im not sure if the bellman's gauge is NPT or BSP. it's the 3rd party gauge that says NPT.
    yah ive seen the website. kinda pricy tbh I had a laugh
    Sep 2013
    2,012
    Ah right. In that case you’d better check before you buy something as I still think BSP is the most likely thread type. I don’t think $40 is pricey at all for a gauge that you know will work, and as they are readily available I don’t think there’s much point buying a spare for it to sit around and never get used. I know you can pick up gauges from as little as about $10, but as I said above you need to check the operating temperature range. When I looked into this a few years ago it was very difficult to find a gauge with a high enough temp rating and when I did it was well over $100. So while you’d be able to get something cheaper than the genuine one it’ll be wasted money if it doesn’t work properly or dies quickly. It’s a bit weird that your machine arrived without the gauge in the first place, I hope the seller has sent you one by now.
    Nov 2017
    Mars
    6
    yah i ordered a spare. here is the picture of the modified gauge. problem is he did not include the info/specs of the gauge he used.
