Results 1 to 5 of 5
Thread: About descale Breville dual boiler
    Nov 2011
    224
    Hi All,
    Any comments on descaling the Breville dual boiler machine?
    What if using the BRITA filtered water to fill BDB since begining of use, is the descaling aviodable?
    Nick OY
    Senior Member artman's Avatar
    Jun 2006
    2,187
    Re: About descale Breville dual boiler
    It seems the Brita jugs dont do much in terms of reducing scale (water softening), the Breville has a water softner filter in the water tank. I recall reading here on CS that if you replace this filter as required, the machine will normally not need a descale for a few years.
    Nov 2011
    224
    Quote Originally Posted by 4251574E424D230 link=1323004493/1#1 date=1323006928
    Hi artman,
    I bought the Brita filter and the user manual said the filter can reduce limescale and substances.
    Nick OY
    14,665
    Quote Originally Posted by 494E444C485E464940270 link=1323004493/2#2 date=1323007460
    artman wrote Today at 00:55:
    It seems the Brita jugs dont do much in terms of reducing scale (water softening), the Breville has a water softner filter in the water tank.* I recall reading here on CS that if you replace this filter as required, the machine will normally not need a descale for a few years.
    Hi artman,
    My expreience is that the small supermarket drinking water filter achieves a result somewhere between zero and nothing as far as scale is concerned.
    Jun 2006
    2,187
    Yeah, the consensus is it might do something for the first jug or 2, but then its negligible. My wife used a Brita jug to fill a kettle and it developed a thin layer of scale in a relatively short time.
    Also, some people have reported a build up of carbon in the boilers of machines that have been filled with brita jugs.
  1. Breville Dual Boiler for $995 from Breville factory outlet
    By goduncan in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th May 2012, 06:21 PM
  2. Breville Dual Boiler
    By thecoreycolak in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd September 2011, 01:49 PM
  3. Breville Dual Boiler
    By cuppacoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th June 2011, 12:34 PM
