Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By JavaB
Thread: Silvia Problem - No water through group head
    Nov 2005
    112
    Silvia is not working... :(
    I can get water through the steam wand, but none coming through the group head. Over the past week it would make a terrible cracking/spurting noise initially whilst pulling a shot and then work as per normal. Today no water comes out of the group head at all. I can hear the pump working, but no water coming out of the group head, the sound is kind of like when you grind to finely and choke the machine. Sounds like there might be a blockage somewhere?
    Any ideas on what the problem might be and possible solutions would be greatly appreciated.
    Thanks.
    3,498
    Re: Silvia Problem - No water through group head
    Sounds like the 3 way valve has seized....
    Do you regularly backflush the machine (with backflush detergent)?...... even though it is not recommended by Rancilio - it is essential or coffee oils can seize the 3 way...... and that is just like choking the machine with too fine a grind. No water is released and the pump just pushes against a closed 3 way valve.
    Site Sponsor
    Aug 2006
    929
    Bloop,
    JavaB is correct.
    Another thing will be, take out your shower screen could be this is all block with coffee.
    Gook luck
    Renzo
    Nov 2005
    112
    Hi JavaB,
    I last backflushed it about a month ago, I normally do this once every two months. I now notice though that there is no water going into the drip pan from the valve.
    Is it possible to fix the valve (i.e. take out and clean at home) or does it have to be replaced?
    If replacement is necessary, do you happen to offer this service Renzo?
    Thanks guys.
    3,498
    bloop,
    There is a site on the internet with detailed instructions on how to disassemble the 3 way - I cant remember where it is but a google search for " silvia 3way overhaul" should locate it for you. The instructions are very easy to follow and the procedure is pretty simple.
    Edit:
    try http://memweb.newsguy.com/~jenkins/silvia/
    Albeany71 likes this.
    Nov 2005
    112
    Hi JavaB,
    Thanks for the link.
    Ive just disassembled the valve and gave it a thorough cleaning, reassembled, but alas no water through the group head :(
    Looks like Ill have to take it to Renzo.
    3,498
    OK, if everything moves freely it might be a burnt out solenoid on that valve.....
    You could check if you have a multimeter..... but other than that.... probably is a trip to see Renzo.
    Nov 2005
    112
    Just a follow up post to say its been fixed :)
    JavaB you were right, it was a burnt out solenoid.
    I called Renzo however he had 8 machines in front waiting to be repaired so I thought Id try my luck and give replacing the solenoid a go, otherwise itd be a while without coffee...
    I called up Coffeeparts and luckily got Pedro on the phone. I described the problem to him and he told me to try changing just the coil, and showed me exactly which part was needed. Thanks to Pedro for his help and integrity.
    So the part came the next day and it was an easy 5 minute installation and hey presto all is well once again.
    If anyone gets the same problem with their Silvia, this is the part you need - 700179_22 from this page: http://coffeeparts.com/astoria/700181_22.htm
    So thanks to everyone for their help and especially JavaB for pointing me in the right direction.
    Feb 2007
    242
    I love a happy ending *sniff*
    162
    Pedro is the best. Glad you mentioned him, and congratulations, theres nothing better than being able to fix your own machine.
  1. No water from group head
    By afit1551 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th March 2012, 07:10 PM
  2. 6910 group head problem
    By russellb in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th February 2010, 11:14 AM
  3. Silvia not passing water through group head
    By Humphrey in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th November 2008, 10:22 PM
