Results 1 to 6 of 6
Thread: Breville BES900 110V to 220V conversion?
    Apr 2013
    3
    Hi All
    I have a Breville BES900 XL (Canadian version) that I would like to take with me to South Africa. Any ideas (outside of a step-down transformer) to whether it can be converted from a 110V to 220V environment? Assume I'll have to change the PC board at least, but would the rest have a simpler solution? I read somewhere that Breville had been clever with enabling this machine to work in the US without having to re-engineer everything?
    Any informed help appreciated.
    Mar 2013
    Caloundra, Queensland, Australia
    32
    I think you will find a number of the major components are voltage specific and it will be a more cost effective option to sell your existing unit and purchase a unit built for the appropriate voltage (or use a step-down transformer)
    Apr 2013
    3
    Quote Originally Posted by nwood View Post
    Thanks for the reply. I'm hoping to find specific, technical specs to ascertain whether the step-down transformer is the only reasonable option. The only supplier of Breville in South Africa does not stock this model as far as I am aware, so I'm hoping to keep this machine that I got at a great price recently.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    With most machines this would be a pain, with a breville I think it would be close to impossible unless the same elements were used in the 110 & 220v models, where would you buy them since breville doesn't stock the machine in SA? You would also need two pumps, and maybe flowmeters unless they run from the control boards voltage.
    Apr 2013
    3
    Well, then step-down it is. Kinda didn't think about the pumps...duh! Thanks for the input.
    Jan 2018
    1
    Hi All,
    Has anyone been using a Breville expresso machine rated at 120 V (US) with a voltage converter for 220V? I have recently bought the BES870XL /A Barista Express machine and Breville customer service discouraged me on using power converters - why is that?
    Any thoughts on that?
    Thanks.
  1. Breville BES900 - repaired - still faulty. Breville don't care.
    By Nevin in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th August 2012, 06:53 PM
  2. need help with Breville BES900
    By rusjkit in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st September 2011, 08:53 PM
  3. 110V vs 220V?
    By el_cato in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 12th September 2009, 05:14 PM
  4. Converting a Silvia/Rocky from 220V to 110V
    By dcaffeine8d in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th April 2008, 09:55 AM
