Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By malliemcg
Thread: Sylvia - No water from group.
    Nov 2010
    150
    Greetings,
    I have an issue that occurred today - I've not had my coffee so hopefully this makes sense: When I flick the brew switch on my Sylvia no water comes out of the group. The pump runs and seems to be very strong. I've done a bit of searching and am unsure if it's the three way valve or something else.
    When I primed the machine switching it on this morning, there was a fair amount of clicking (1-2 seconds worth of click click click - similar noise to flicking the switch, but coming from down in the bowels of the machine) that was occurring just after I'd flicked the brew switch. I'd guess it would have been around the area that I have photographed.
    Should I whip off the three way valve give it a clean? See what's up?
    If it is borked, anywhere in Canberra going to have bits, already not enjoying the withdrawal.
    M
    Jan 2009
    ACT
    136
    Do you get water from the steam wand when you turn on the hot water switch ??
    Gary
    Nov 2010
    150
    CafeLotta - Looks like I'm at clean solenoid valve or change solenoid coil. Thanks for those links - very handy, now to get a 7/8" wrench or adjustable spanner, hopefully it's just dirty and I'll have coffee tomorrow morning!
    Gazza - yeah - I get water out the steam wand.
    Nov 2010
    150
    I've pulled it out and the piston bounces up and down with little to no pressure.
    I suspect now I need to get a new black thing that goes around it, which I assume is the solenoid coil.
    Nov 2010
    150
    How do I know which of these I need?
    Coffee Parts | Rancilio Silvia Electrical Components
    Jan 2009
    ACT
    136
    Do you have a multimeter, if so check the resistance of the coil.
    Gary
    Nov 2010
    150
    I have the flow chart image (from the removed one). I'll have to see if the old man in law has a multimeter to test the coil. Gazza - what should I be looking for some resistance or no resistance?
    Appreciate the help and responses, hopefully soon I'll be having coffee again (in a way that keeps the budget sane).
    Jun 2012
    435
    The existing coil on your machine should have the relevant information printed on it. Maybe give site sponsor coffeeparts a call to see if they can supply the coil seperately if that's all you need. Site sponsor the Coffee Machinist is also worth a try or use the quote form to reach all sponsors to see who may be able to supply the coil only.
    Jan 2009
    ACT
    136
    No idea but if is stuffed it is likely to be open circuit i.e very high resistance. If it can wait till the weekend I can measure mine.
    For some interesting info do a search on the HB forum for "solenoid valve operation"
    Gary
    Nov 2010
    150
    Well it's gone open circuit between all and any of the legs, so I assume it's stuffed, now to find a replacement (posted up on the quote form)...
    Thanks to all who have assisted with the process to trace the issue.
    M
    Nov 2010
    150
    Replacement bit ordered, should / is there a way to close the request for quote form?
    Nov 2010
    150
    We have water from the group. Shall attempt a coffee tomorrow!
    okitoki likes this.
  1. No water from group head
    By afit1551 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th March 2012, 07:10 PM
  2. Replies: 4
    Last Post: 15th October 2011, 05:27 PM
  3. Bezzera BZ35 - no water from group
    By SIBat33 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 23rd March 2010, 10:00 PM
