Results 1 to 16 of 16
Like Tree12Likes
  • 1 Post By ElShauno
  • 1 Post By sprezzatura
  • 1 Post By ArtW
  • 3 Post By 2muchcoffeeman
  • 3 Post By LeroyC
Thread: Why so little interest in ECM Casa 4?
    Dec 2016
    Brisbane
    4
    Question Why so little interest in ECM Casa 4?
    I've decided to take the plunge and buy a decent espresso machine after looking at an ECM Casa IV in a Brisbane shop recently. Apart from one or two youtube videos I can find out very little about them - they are certainly not a hot topic here. Why is that? Their bigger siblings are popular in the 'pointy end' forum.
    They look like a very solidly built single boiler but a bit more pricey than a Silvia. Comparing the two:
    Silvia
    • Does not have a pressure gauge. There are many threads here where people are having trouble with too rapid extraction followed by lots of guessing re: grind fineness, tamping and pressure adjustment. It appears the operator is flying blind without a gauge. I'm keen to avoid that.
    • Does have a low water cut off. Excellent feature. I don't know why they aren't ubiquitous.
    • 235mm wide
    Casa IV
    • Has a pressure gauge
    • 200mm wide
    • Does not appear to have low water cut off. Without this, the 'make coffee' button is more correctly labelled 'self destruct'. It's just a matter of time before one of my housemates tries to froth their milk with vaporised copper and brass.
    I guess it would only take one Casa IV repair and I could have bought (non suicidal) Lelit PL60 instead. But I don't really feel I need a dual boiler, 350mm wide machine on my kitchen bench.
    A northside brisbane shop sold their last display Casa IV and hinted a new model might be out in the next few weeks. I will wait and see what transpires. In the mean time is there anything else I should be looking at? I'm keen to keep it around the $1,200 mark.
    Feb 2014
    49
    Looks a lovely machine but is priced considerably higher than a Silvia and I couldn't tell you the $400-$500 benefit of a Casa IV over a Silvia.
    I wouldn't get hung up on the pressure gauge. The shop will help check your machine is running fine, and what comes out of the portafilter and lands in the cup will help you diagnose and improve your coffee extraction better than a gauge
    Good luck and enjoy the journey
    Magic_Matt likes this.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    909
    I really like the Casa IV from a purely technical POV. Glossy white insides; OPV/bypass on TOP! Eureka! It's great. Buy one.
    Senior Member ArtW's Avatar
    Nov 2012
    130
    Agree with the pressure gauge comment, it won't help you make better coffees or diagnose your shots. I think the reason this machine doesn't get a lot of attention is that it's a single boiler almost bumping into lower end HX machines price wise. That's fine if you don't drink milk drinks often. If you do, you might consider something like a Nuova Simonelli Oscar - not sure if that's pushing your budget?
    ElShauno likes this.
    Nov 2009
    Altona, Melbourne
    1,579
    $1200 for a single boiler is pretty poor value. There have been a number of hx come up for sale on the forum recently that would be better value.
    The 5 minute heat up times almost nespresso speed though.
    Dec 2016
    Brisbane
    4
    Trentski, yes I'm seeing that now. I'm also seeing how important a PID is after a bit more reading... either that or master temperature surfing.
    That's interesting about the stainless chassis Paul. I think I need to take a close look at the Lelit PL41 and PL60.
    How wide is the dead band on a modern thermostat (non PID) machine? If it's anything like the thermostat I once used to keep my home brew warm, it's far too wide; about 12 or 15 degrees. I ended up with wort that either went dormant, or bubbled over.
    Dec 2016
    Brisbane
    4
    I drink laté or sometimes cappuccino. So yes, double boiler or HX would be better. I've just watched a couple of videos showing the time it takes a PL41 and a Silvia to heat up to steam. I think that wait will grow tiresome real quick.
    Senior Member 2muchcoffeeman's Avatar
    166
    I have had a number of single boiler machines- an Audrey and a couple of Silvias and they were all great when well used. They were all PID free. Well calibrated e-61 single boilers are brilliant shot machines and take it to the next level.
    The elephant in the room though is the Simonelli Oscar II and they'll be available at under $1.5k (sponsor Casa Espresso). It will make life tough for the e-61 single boiler gear.
    trentski, ElShauno and JustinM like this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,848
    Quote Originally Posted by JustinM View Post
    That depends. Will you be making more than one milk based drink at a time? If so then a small HX or DB will definitely make life easier. However if you're in a similar position to me then a small single boiler is perfectly adequate as I'm the only coffee drinker in the house. My current machine is very basic, but with an upgraded steam wand a bit of experience I'm able to make a great milk based coffee each morning. This is it-
    I get heaps of steam power and by tricking the steam system into continuous cycling I get endless steam as well. This kind of operation also works on a Gaggia Classic, but I'm not sure about the Lelit. On the very odd occasion I'm making another coffee or two for guests it does become annoyingly slow, but this is infrequent enough that I don't worry about it. So work out how you'll be using the machine 90% of the time and base most of your decisions on that.
    matth3wh, ElShauno and LFM60 like this.
    Feb 2014
    49
    Loving this machine's retro vibe. What is the model?
    Sep 2013
    1,848
    Quote Originally Posted by ElShauno View Post
    Bialetti Viva Il Caffé.
    Jun 2009
    Brisbane
    25
    Well the Case IV went on sale at a shop in Brisbane as the new V has come out. I bought the Casa IV and yes I do realise it was $300 more then the Rancilio Silvia but I think that the German built machine had a few extras that were, "in my mind" worth taking the plunge.
    Am I happy with the machine - well yes I am.
    I dont think I would pay $400-500 more then the Silvia as I am starting to head into the lower priced HX range of equipment - which was very tempting but the budget had to stop somewhere.
    The Casa is just portable enough that I dont mind taking it on multiple caravan trips throughout the year.
    Still getting the steaming and frothing right but hey this is a great step up from my Sunbeam CAFE series machine.
    I am not regretting the purchase decision.
    Jul 2017
    30
    The Casa looks better but not sure of that makes it worth the extra dollars. German made has to be a good thing though.
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    836
    I’ve heard of the Oscar II selling for $1250 inc in Sydney recently (and an older Oscar 1 going for around $950) so like a few people mentioned there’s plenty of good competition and options at around the $1000-$1300 price point. All of which will make you a tasty coffee with varying degrees of speed steaming milk.
    BLW
    BLW is offline
    Oct 2017
    35
    Silvia
    • 235mm wide
    Casa IV
    • 200mm wide
    I'm not sure if the OP is still reading this, but does the Silvia really have a low water cut off?
    After watching the Whole Latte Love comparison of the Silvia vs Casa V (not sure about the Casa IV), the pressure gauge looks like a great feature to have if you would ever want to adjust the OPV.
    A faster overall heat up time/ to steam time (1:04 vs 1:45 min) would also be a plus - but even with a better finish, probably not worth hundreds of dollars more.
    338
    338 is offline
    Mar 2017
    348
    Congrats on the new machine Ha Da Ja, hope you get years of tasty use out of it. Thank you to you and CoffeeMan2, I was under the belief that ECM made their commercial gear in Germany and consumer gear in Italy, thanks for making me realise that has now changed.
