Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By MattyRay
Thread: Cleaning a La Pavoni Professional
    Senior Member gonzob's Avatar
    Aug 2011
    211
    Hi all.
    I've just bought a LP professional from a CS. It's brand new. I've read the instructions, but it's next to useless about cleaning. I've just switched from a Silvia, and because the Silvia has a pressure release valve, you have to backflush regularly to keep it clean. The LP of course has no such valve. So should I be doing any flushing/cleaning after each use?
    Gonzo
    Nov 2013
    Casula, NSW
    591
    Someone who knows will hopefully chime in as I have no experience with lever machines, but I think I read on here that because lever machines don't have the pump pressure pushing forward then effectively creating a vacuum when the pump stops they won't have the grinds in the pipes the same way a pump machine will. So wiping / flushing is sufficient. Again wait for someone else to say.
    Nov 2014
    Adelaide, SA
    131
    Wiping & flushing is about all I do with mine. I've pulled it down a couple of times to replace seals etc and there is pretty much no visible buildup anywhere. If you were pedantic you could remove the group head seal/shower screen and clean the screen and in the seal area, but there is not much more that you can or need to do.
    Regards,
    Matt
    Dimal likes this.
    Coffee Nut fg1972's Avatar
    Jan 2012
    432
    I have the Piccola not the Pro but the concept should be the same. As the previous poster said, just wiping and flushing is all that's required. Just another thing I do if I'm not using the machine is after emptying the boiler, I leave the filler cap off for any moisture not to remain inside.
    Site Sponsor Casa Espresso's Avatar
    Dec 2008
    Australia
    697
    Definitely no back flushing.
    Good quality filtered water, a cleaning flush and using a group head brush is all you really need weekly cleaning.
    12 month group head seal replacement and maybe boiler cap o ring
    2 to 3 years fro the piston seals depending on use.
    Overall these are a very easy machine to maintain.
    Antony
    CASA EASPRESSO
    Aug 2011
    211
    Thanks Antony. Very useful advice.
    Gonzo.
    Aug 2017
    4
    Im thinking about buying one of these machines, just wondering how much I should expect to pay for a La Pavoni Professional.
    Any help appreciated
    Dec 2008
    Australia
    697
    Quote Originally Posted by dino823 View Post
    Hello Dino,
    Are you looking for new or used?
    Antony
    www.casaespresso.com.au
