Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By level3ninja
  • 1 Post By noidle22
Thread: Help! Breville*BES920 Dual Boiler*won't produce steam after descale
    Jun 2017
    1
    Exclamation Help! Breville*BES920 Dual Boiler*won't produce steam after descale
    Hi everyone! I'm new to coffee snobs and in dire need of help. Did my first descale last night and the everything seemed to go ok, but after switching the machine on this morning it doesn't want to produce steam.
    I've done another descale today hoping last night's process may have simply caused some build up to create a blockage but unfortunately I'm no closer to steam.
    Hoping there's something silly I've done and haven't caused too much damage. If anyone can provide any advice before I take it into the shop I'd very much appreciate it.
    Thanks everyone!
    Nov 2013
    Casula, NSW
    581
    Unfortunately there is a known issue with all 920s sold up until a certain point that the programming for the descale leaves the steam boiler element on without any water in the boiler. This kills the element. Call Breville tomorrow. It will need to go in for repairs, or they will tell you how to fix it.
    matth3wh likes this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,389
    Bad luck, is it still under warranty?
    Jul 2012
    628
    If its a known issue probably no wiggle room for breville not to fix regardless of product warranty status
    Mar 2012
    Bathurst
    888
    Hopefully it's tripped the thermal fuse before the element has blown. That's what the fuse was designed to do.
    The 920's that I have repaired for this problem have only ever needed a new fuse. Unfortunately it's still a complete disassembly, boiler out job which is a massive pain.
    Nov 2013
    Casula, NSW
    581
    Mine had bits of the element (I assume, something that looked and smelled metallic) come out into the drip tray.
    Jul 2012
    122
    Did I read somewhere there's a new procedure for the descaling? Sure I saw mention in a long thread of failed steam heaters.
    Jul 2016
    Greenwood Perth
    25
    Consumer affairs says your contract is with the shop or dealer from whom you purchased it. Not Breville. Return it to the shop it's their responsibility.
    When I went to a Breville authorised repairer it took ten weeks to tell me the part was out of stock.
    The shop where I bought it got me a new machine.
    Jul 2016
    Greenwood Perth
    25
    Quote Originally Posted by Chris View Post
    Yes go to the Breville web site and look for the first software version.
    Dec 2017
    1
    Hi Guys, new to this forum...
    Saw this and seems we have to go quite a long way for someone to hit the nail on the head. noidle22 is correct with the diagnosis, I have the same machine, the Thermal Fuse is conveniently placed in the most inaccessible place, obviously attached to the main steam boiler, which involves a complete strip down! I have had this issue twice now, despite following the "older model" instructions on how to descale, and yes, just 3 months out of the warranty!!
    Whats confusing me is that the Thermal fuse was replaced before under warranty and again has gone, the TF is the correct one 167 degrees, 10 amp. The element is giving near 50 ohms, so thats OK. what really confusing me is that the boiler is fitted with a thermal cut-off sensor, which should also stop the current when the boiler reaches temperature, or am I missing something?
    the boiler operates at around 130 degrees Celsius apparently, therefore how does the thermal fuse blow? is it likely to be a faulty Thermal Cut-off sensor which is strapped to the cylinder? If this was defective the boiler would continue to call for heat wouldn't it?
    I thought of fitting a 150 degree resettable thermal switch instead of the thermal fuse such as this:
    eBay link removed as per Site Posting Policy
    This way if the boiler ever got above the 150 degrees, it would reset automatically once the temperature had been below that for 1 minute, enabling me to diagnose other possible issues without having to strip the entire machine down again just to replace the damn fuse.
    Any comments appreciated.
    Nov 2017
    69
    If the boiler is dry (or low on water). The thermal cutout will not read the temperature correctly, the element will continue to cook itself.
    Think of a kettle, it won't know when to turn off, if there is no water on the temp sensor
    Nov 2017
    69
    I haven't had one apart, so not really sure of how the thermal fuse works.
    It maybe that it melts after a time with the element on (over current), or it melts as its closer to the element and gets its temperature.
    Jul 2011
    Maddingley
    140
    I had the exact issue yesterday but have had it before where I got no steam and th dreaded 3 beeps. The first time it was like the boiler was dry but after a short time it started working again. Yesterday it was nothing...luck I drink espressos so I went about my business this morning making a coffee and checking the steam. After a while I started hearing the boiler start drinking more water. I thought that maybe my other boiler was shot too. I checked the steam again and what do you know, it is alive!! Good luck with your machine JimfromIreland.
