Results 1 to 13 of 13
Thread: La Pavoni Europiccola snap ring rust issue
    Jan 2017
    6
    Hi
    I have a pre millennium Europiccola and have taken the group head apart to replace the seals. All was going fine, I was able to remove the piston and shower screen from the group.
    When I got to the section in the group where the piston seal is, the snap ring which holds in the four hole washer and the piston gasket was rusted.
    The two ring sections at the end of the snap ring just broke off with no effort.
    The rest of the snap ring is still there in the grove. I manged to get the four hole washer and the rubber gasket behind the washer out, but have no idea how I am now going to deal with this snap ring.
    Any ideas would be great.
    thanks
    Feb 2011
    326
    It's a common issue. The fix is to replace it with a stainless C clip that doesn't rust
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    385
    Pics might help a little to get a diagnosis from the la Pav experts here, but I suspect Sam is right. Dig it out and then replace with a stainless equivalent ideally or get a like for like from a parts mob.
    Alternatively you can take it in to get it done, will likely end up costing a few $$ though.
    Jan 2017
    6
    Quote Originally Posted by samuellaw178 View Post
    Yes I want to replace it for sure... I have the parts ready to go..
    I just don't know how I am going to get the old one out, now that the ends of the ring have broken off and only the center bit remains in the grove.
    There is no way to compress the ring to get it out. The grove is very thin so getting something in there to pull it out is not easy.
    I'll try getting a pic tool or something.
    I'll try and take a pic.
    thanks
    Feb 2011
    326
    Ah, I see the problem. I had assumed the snap ring is out because you managed to get the 4-hole washer. A picture will definitely help, it really depends how much of the snap ring is left intact. Can be quite challenging if you have the ends broken and the body sits flush in the groove....
    I am curious though how were you able to get the washer out without the snap ring out?
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,789
    Quote Originally Posted by databear View Post
    thanks
    Wonder if an old dental pick may do the job?
    Nov 2013
    Casula, NSW
    591
    Sounds like you'll have to get a grip on what's left of it somehow and twist it out of the groove
    Jan 2017
    6
    i got the washer out first. Bent it up from behind, then was able to get it past the snap ring.
    Then the gasket was easy to get out past the snap ring as well.
    Jan 2017
    6
    the new clip is below the broken off bits to show how much is left in the groove.
    Here is the group head with the left over clip just visible.
    Feb 2016
    150
    If the ends have rusted, the rest of the ring may have as well. This can make it easier to extract if it breaks apart. Options include a dental pick to get behind the ends and try levering it out, or creating enough of a dent in the ends to get purchase with the circlip pliers. If really keen and cocky, you could use a Dremel cutting disc...but I wouldn't!
    Jan 2017
    6
    Quote Originally Posted by timmyjj21 View Post
    thanks timmy
    the rest of the clip does not look rusted at all.. ;(
    I've tried a pick tool but no luck so far.
    I don't like the idea of Dremel cutting disc.
    I wonder if I can file it down in the centre and then try and bend it....
    Jan 2017
    6
    I manged to break the remain piece in two with a pic tool. All seal in group head now replaced... yeah... works like it should....
    Now when a pull a shot or is it push with this machine.. ;0
    I get creaking sounds. I think im lacking lube somewhere...
    I lubed the piston, and both the pins that hold the handle in place... not sure where the creaking is coming from...
    might have to take it apart again and have a look.
    Feb 2016
    150
    Check the the piston seals are facing away from each other, so one seals for the up stroke and the other for the down. I pack the lube in between the 2 piston seals. Also lube the piston shaft so it slides well through your new seal. This is my pick for the likely source. Also check that the piston sleeve is smooth and no sediment or scale build up is present as the new piston seals might grip a little more?
