Results 1 to 8 of 8
Thread: Upgrading my Silvia V2, to bring it to V5 standards. Thoughts?
    Dec 2007
    48
    In a week, it's my Silvia's 10th birthday. I would like to reward her by updating her to match the current V5. This would involve:
    * New steam wand assembly (V3) $110
    * Steam knob (V3), optional. I prefer the V2 knob
    * V4 has a new boiler, but I believe the only benefit to it is that it introduces a removably heating element, unlike the integrated element of the V2. No improvements in performance. Only worth upgrading when my V2 element dies. No reason to upgrade it before then. $200
    * Boiler Insulation (V5). Already have. $0
    * New chassis to replace my rust bucket $140
    Total cost: 250 now, $450 once the element dies.
    So- Have I included all changes that's happened between the V2 and V5? Is it worth putting the money into the old girl, or fdo I just accept that she's slowly on the decline?
    I've been off the coffee scene for a long time, so I'm not up to date with how much things are worth, and whether the Silvia is still considered to be a decent machine
    Aug 2017
    18
    If we're talking cheap upgrades (I've also got a V2), a vst basket will make a world of difference, as will a fitted tamp if you haven't done so already.
    Dec 2007
    48
    Already got a VST, naked portafilter and Reg Barber tamper. I'm not asking about what upgrades to make but just whether it's sensible to upgrade V2 components to V5- and whether I identified all of the changes over the years. There's not a great deal of info on what changed with each generation
    I've got no idea what the used marked to a V5 is these days, and I've got no idea whether I'll be sitting on a ticking time bomb even after upgrading the boiler and steam valve. I'd hate to spend a while bunch of money, only to learn that old Silvias are full of components that tend to fail
    Dec 2006
    Perth WA
    559
    Tricky question.
    At a certain point changes make little difference. Is your dear Silvia making good coffee for you. Will a new steam wand make a difference. Interest to know why the chassis is rusted out? $200 is not excessive but a replacement boiler plus other items would add up to half the cost of a new one. Bit like a old car, it shifts from functional to a hobby.
    Not being negative these are just my thoughts. I sold my 2005 Silvia last year, she was still going well. I put new feet on her and cleaned up the chassis. The boiler was the original one.
    Aug 2017
    18
    I'm still skeptical. If you use the steam arm then upgrade that. I don't see the newer boiler making much of a difference. Depending on how bad the rust on the chassis is you might be able to just sand it back and paint the one you already have. A knobs a knob for the most part, I like the newer one better but if you don't then as I see it, there's no real point in upgrading. As far as insulating the boiler I think the bimetallic thermostats they use are more of a problem than heat loss from the boiler.
    Just my two cents.
    Senior Member artman's Avatar
    Jun 2006
    2,117
    As above. If you find the non ball jointed steam arm annoying then upgrade it. I would wait til element fails before swapping the boiler.
    Fix the rust so it doesn't continue to degrade (or swap for new if too far gone) and get a pid kit. That will give you most potential for shot improvement.
    They are a simple machine. If something fails, replace it then. Unless you just want to tinker and explore?
    Jun 2006
    BRISBANE
    1,924
    There is an excellent sealing product called Xtroll Rust Conquerer UV. I highly recommend that if you rub it back. Cheers
    Dec 2007
    48
    Thank you all very much for your opinions. I'm putting a PID high on the priority list now. Unfortunately the chassis is too far gone for a repair though
    Any idea if the Auber PID kit "pre infusion" function would work with a rotary pump? I'll be sticking a rotary pump in soon because I have one laying about the house. not plumbed-in
