Results 1 to 6 of 6
Thread: Rancilio Silvia Lugs too thick?
    Nov 2013
    Casula, NSW
    609
    My brother has a V2 Silvia he bought second hand a few years ago, and it came with a portafilter with part number 20-112-010. With or without a basket in the portafilter it is extremely hard to turn after insertion, to pull a shot he can only rotate it about 0.5-1cm at the group head and has to hold it in because it's fallen out and exploded coffee everywhere a couple of times.
    Is this the right portafilter for the V2? Can I just file the lugs down a bit?
    Also the basket is a 40-100-010, what is the recommended dose?
    Jan 2017
    44
    Could it be that the group gasket is too thick? Maybe they put the wrong one in?
    Try buying a cafelat silicone gasket (the green one is for Rancilio Silvia) and see how it goes.
    Nov 2013
    Casula, NSW
    609
    Worth a shot, thanks. Ordered!
    Aug 2008
    54
    Sounds more than likely something to do with incorrect thickness gasket or similar. Even without using the silicone ones , the standard ( correct ) rubber gasket should never make the group handle overly tight to pull around.
    Nov 2013
    Casula, NSW
    609
    One of the lugs seems straight, the other one doesn't. Both sides some wear through the chrome.
    Nov 2013
    Casula, NSW
    609
    Apparently the new gasket sorted everything out, cheers!
