Results 1 to 29 of 29
Like Tree36Likes
  • 1 Post By WhatEverBeansNecessary
  • 2 Post By LeroyC
  • 1 Post By rawill
  • 2 Post By Barry O'Speedwagon
  • 1 Post By empty123
  • 1 Post By BLW
  • 1 Post By Barry O'Speedwagon
  • 5 Post By Chris
  • 1 Post By rawill
  • 1 Post By ozscott
  • 3 Post By applor
  • 1 Post By rawill
  • 2 Post By BLW
  • 4 Post By Dimal
  • 1 Post By rawill
  • 2 Post By BLW
  • 3 Post By rawill
  • 1 Post By BLW
  • 3 Post By rawill
Thread: Have prosumer machines up to $1.5k better build quality than Breville/Sunbeams?
    BLW
    BLW is offline
    Oct 2017
    35
    Prosumer machines (<$1.5k) vs Breville/Sunbeam: Way better build quality?
    Iím currently searching for a replacement for my EM7000 which broke after 3 years (I read some might last 8y). As I fortunately put extended warrenty on it, I received my money back, so I basically had a great machine for that time with no cost other than the insurance.
    Apart from the build quality, the EM7000 made pretty good shots with freshly ground beans (Smart grinder+mod) and the steam wand worked fine too after a few days/weeks getting used to it. The machine also heats up quickly and is pretty much fool proof in some regards: If you run out of water it alarms you and if left on all day, it goes into standby.
    I guess many others have been at this point choosing between another Sunbeam/Breville (+extended warrenty!!!) or entering the world of prosumer machines.
    • If you spend up to $1.5k, does the build quality improve a fair bit over a EM7000 (>$500) or BES920 (<$1k) with the machines lasting longer? I assume the shot/steam quality should be at least the same.
    • At what price point can you be more certain to make a long term investment (up to $1.5k, or above the $2-3k mark)?
    What Iím looking for:
    • My budget is as low as possible for a good machine ($500 is what I paid, $1k is approaching the limit, $1.5k has to last). 2nd hand is an option too if the build quality is made to last - I have no clue how to assess this though (no Sunbeam/Breville equivalent).
    • Easy to use: No chance for the boiler to burn out if you forget to flush it, add enough water to the tank or make sure thereís no leakage from the steam wand (you know if you have kids in the house).
    • Quick heat up time (< 10-20 mins). We drink 2 lattes in the morning rush and an occasional espresso in the afternoon. Add several milky drinks when visitors come around at short notice.
    Current searches point towards: HX (Oscar II) or double boiler (Lelit P60) machines seem to tick the boxes. The new Lelit Victoria single boiler looks quite nice too.
    Are Lelit or Nuova machines going strong after say 10 years (as opposed to the average 3-8 years of a Sunbeam/Breville)?
    What other machines would fit my requirements?
    Thank you very much for your experiences and any advice!
    Bernhard.
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    431
    Once you start going away from the "appliance manufacturers" eg breville/Sunbeam etc and head toward the espresso manufacturer specialist you will notice a huge improvement in quality. Naturally that comes with a higher price tag.
    The biggest thing about keeping any machine running for a decade is maintenance. Keep on top of little things like cleaning, seals etc.
    Personally I wouldn't skip over 2nd hand machines. Most of the machines for sale here will be kept by like minded people who want to make sure it lasts.
    Also don't forget to factor in a grinder for the budget. It really is the most important piece of kit.
    BLW likes this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,889
    The two machines you mentioned are probably the only ones in your price range for a new machine as they both sit around that $1500 mark. Your Smart Grinder will do the job for now so at least you can just concentrate on a new machine, but you might find yourself wanting or needing to replace it at some point.
    Iíve seen inside a NS Musica and it was very neat and well put together with some nice features. Iím assuming the Oscar II isnít too far behind it in that regard. The Lelit is probably slightly more sturdy, but only someone that sells both (like Jetblack) will know for sure. And yeah they are definitely a step up from the Brevilles and Sunbeams, but $3k+ machines from the likes of ECM, Rocket and Bezzera are on a totally different level so you may want to keep your eyes open for a 2nd hand one. $1500 wonít buy you any of these that are only 2-3yrs old, but might get you something slightly older. And if you buy it on CS youíre more likely to get a machine thatís been well cared for (although thatís never guaranteed).
    Just a final note. Any level of machine can be killed in a short period of time without proper care and maintenance. So regardless of what you get make sure this part of ownership is on point.
    BLW
    BLW is offline
    Oct 2017
    35
    Thanks.
    As for maintenance, I do backflush (with and w/o chemicals) but rarely descale as we have an in-sink purifyer. Do you get your machines professionally serviced every so often?
    I'm good in taking things apart, but putting it back together...
    Rbn
    Nov 2010
    Southland NZ
    441
    I read somewhere on here of someone who had an in-sink purifyer who still got scale inside his machine.
    BLW likes this.
    Dec 2011
    PRL
    2,380
    Jetblack have a Bezerra BZ99 going for $1650. Pretty solid.
    Jan 1970
    52
    I have the same questions myself OP. The only difference is Iím still making do with my modified EM5900 and Gaggia MDF but they will probably give up the ghost soon (more likely the Sunbeam). I will be watching this thread keenly.
    Are NS Oscar (I) and Isomac Zaffiro Due poor contenders in terms of build quality/capability, I wonder? The Oscar can be had for 795 and the Zaffiro Due for about 1,570.
    BLW likes this.
    BLW
    BLW is offline
    Oct 2017
    35
    I saw the Oscar too, but just couldn't get used to the red colour after watching multiple youtube videos. Red is the only one I found for that price (795).
    The Isomac Zafiro is as far as I understand not a HX machine (boiler can run dry?) and takes around 40 mins to heat up.
    Barry, I saw the BZ99 too, but it doesn't appeal to me aesthetically. For me, the looks are part of the joy I got from making the coffee. I do like the BZ07 or BZ10 though.
    I was wondering how other E61s are heating up but didn't get much into that yet. That's the 2nd hand querry I'm still trying to figure out. If there were 2nd hand machines coming down to that prize, what could it be that meets my criteria?
    (Edit: Comments on Bezzera)
    Casa Espresso likes this.
    Dec 2011
    PRL
    2,380
    Quote Originally Posted by BLW View Post
    Which of your prices are you talking about?
    For $1500 for 2nd hand machine, there'd be a bunch of options from VBM/Diadema/Bezerra that would only be a couple of years old. Pick one that you can get serviced locally.
    Less than 20 minutes heating time is pushing it. My Diadema Reale can be made ready to go in 25 mins (or last time I used it it did), provided that you pull some water through the group once the boiler is up to pressure. But.....get a timer and the morning problem doesn't exist.
    If heat up time is super important, I'd stick to the Breville DB.
    BLW likes this.
    BLW
    BLW is offline
    Oct 2017
    35
    Quote Originally Posted by Barry O'Speedwagon View Post
    The 2nd hand price was indeed the $1.5k.
    For a Diadema Reale, I could wait a bit longer for it to heat up. It looks absolutely stunning! However, it'd be more often than not that I won't get past turning it on and having to leave without having a coffee.
    I would also like to be able to make coffee for guests who arrive on short notice. With the Sunbeam, it took a bit over 10 minutes until I got the drinks ready. I doubt there will be many takers if they'd have to wait for 30-45 minutes.
    Funny that a <15 minute heat up time puts me back to Breville/Sunbeam, even when considering a $1500 2nd hand machine.
    Jul 2012
    130
    It is worth thinking about how coffee plays a part in your life. I've been through several prosumer and semi pro machines over the years and arrived back at Breville for a couple of reasons. eg I'm not the only one who makes coffee in the house. The hoard want to come in, turn the machine on and press a button. I found the odd little quirks in some of the other machines whilst all part of the fun for the enthusiast were lost on those not so interested. The heat up time was also a big thing and the fact the machine will turn itself on were big factors.
    As a machine theres just enough scope for me to play. Do I get the greatest coffee in the world, probably not. Do I get coffee that exceeds any local outlet, yes. Do I get earache, no! Like I say, just consider what you actually want the machine to do on a daily basis in your life.
    DamianS, rawill, zeezaw and 2 others like this.
    BLW
    BLW is offline
    Oct 2017
    35
    Quote Originally Posted by Chris View Post
    Those are very good points and it sounds like you are in a similar situation.
    It's great fun if you can play around with your hobby machine and see how your shots and milk steaming skills improve. However, if you have to factor others in - be it for operational or time reasons - the coffee machine should also be able to accomodate that for me. Take time to play around and set it all up on my own, but then get the drinks out on time when needed - and let your spouse with a lettle experience be able to use it too.
    Rbn
    Nov 2010
    Southland NZ
    441
    Excellent point, while I am the only one who does it in our house, when son or daughter arrive they use it, as my machine is the same as theirs. EM6910.
    And your point about making better coffee than the local coffee shop, for sure!
    And if you want to play there is always the naked P/F Vst or similar baskets, and if you get those nailed, you sure will be better than many local cafes.
    BLW likes this.
    Apr 2017
    Adelaide
    431
    If you are worried about heat up times. Put it on a timer for well before you get up for work and keep it on for an hour or two longer than you would normally leave.
    I have done the same with my machine and set it to heat up at 5:30 and switch off at 9am. Then on the weekends 7am to about 1pm.
    Jun 2006
    BRISBANE
    1,925
    Bernard how handy are you and are you willing to so some low cost repair and tuning of a second hand machine?
    BLW likes this.
    BLW
    BLW is offline
    Oct 2017
    35
    Quote Originally Posted by ozscott View Post
    That's a good question. I have done some easy fixes around the house (change light fittings, tabs, build a swing set etc.), but have no experience with repairing an espresso machine or electrical equipment. I would probably not be able to identify the fault either. However, if it's a simple undo a few screws and wires (with good instructions), I should be fine. When it comes to complex circuits or addings something like a PID, I would have to bring it to my local workshop (which will cost a fair bit I guess).
    So, 2nd hand machines while costing less might end up dearer in the end. Therefore, I have no clue how to identify a 2nd hand bargain, unless it comes from a workshop with some 3 months warranty.
    Feb 2010
    88
    I went from a Sunbeam 6910 up to a second hand 2008 HX VBM super which are usually 1100-1300 and I haven't looked back. As for warm up time, we use a timer. Problem solved.
    My wife was reluctant to touch such a shiny/expensive machine but now she happily does her own excellent coffees and loves it. It's easy to use.
    Dimal, rawill and BLW like this.
    Rbn
    Nov 2010
    Southland NZ
    441
    My first search for one of these came up at NZ $2248.00. I would need very very good coffee to upgrade from an EM 6910/7000.
    BLW likes this.
    BLW
    BLW is offline
    Oct 2017
    35
    Quote Originally Posted by rawill View Post
    I ended up buying a new Bezzera BZ10 (AUD1770). I was ready to spend the price of 2 new EM7100s at the best price I found (2x $680, H/N & JM buy them for $600, so it won't get much better without some store wide bonus discount codes).
    It took me quite some time to decide to spend that much money. On the one hand, my EM7000 lasted only 3 years and if I hadn't gone for an extended warranty, that would have been a lot of money for really good coffee for a short time. The BZ10 hopefully outlasts the EM7000 by miles. However, it seems that you have to get it serviced for simple things like descaling - apparently not as for HX machines compared to the ease of the EM7000 where you just have to mix some descale powder into the water tank, flush, wait and flush...
    I also find the EM7000 a bit easier to handle. First, it doesn't get as hot as the stainless steel machines. Second, you can adjust the brew head heat. For some reason I can't get my coffee to taste the same or better and always get some strong bitter flavours (heated brew head too hot? Tank pressure is at 1-1.2 bar where it should be). I adjusted the grind size form reasonable coarse to finest (SmartGrinder+), adjusted coffee amounts, tamped at different strength, ... I guess I'll figure it out soon.
    Nevertheless, I'm very happy with my purchase and I love to experiment and understand the ins and outs of my new (stunningly beautiful) toy, especially if I'll have it for a very long time.
    Dimal and rawill like this.
    15,822
    I'd suggest discussing this with the vendor from whom you purchased the equipment...
    BLW
    BLW is offline
    Oct 2017
    35
    I did with the importer (was looking at getting a different/spare steam tip from them). They said I should stop reading coffee forums and enjoy what I can make (the pressure stats are as they should be btw).
    With experience, it'll all fall into place. Reading about what can cause bitterness besides what I tried points towards a high brew head temp - No clue how to measure that at all easily and I'm not sure if I even get flash boiling at the head (steam rises when I let water run out of the head, but boiling water looks different).
    There's no retailer for that sort of machine anywhere close by - so I had to order online. Taste is also almost impossible to explain to someone over the phone/online if they can't taste it for themselves. "Bitterness" to me might be something else to a coffee expert.
    15,822
    The Group Temperature on the BZ-10 is adjustable I believe.
    If so, give it a try at the lowest temperature available and then creep up from there to just this side of bitterness.
    Another thing you can try and to give you a starting point, start with a dose weight that the basket is nominated to contain; 16g for example.
    Then, adjust the grind size such that you choke the machine. Once this is accomplished, gradually coarsen the grind until such time as you achieve the requisite volume in the cup and the taste meets with your approval. Practice doing this until it becomes almost automatic and afterwards, if you want to, start playing around with the dose/grind to see how this effects the outcome in the cup.
    It's all about experimenting and changing only one variable at a time until you're happy with the end result...
    Rbn
    Nov 2010
    Southland NZ
    441
    Sure right about that!
    But my experience of a 6910,is exactly the opposite, as I have often said.
    Over 10,000 shots, on a machine built in late 2007.
    Spend has been minimal, 2 thermal fuses, 1 magnetic water level sensor, a steam thermoblock at about 7000 shots, it had never been descaled by the previous owner that I got it from at that point.
    And I have just replaced the collar.
    So about a $200.00 spend for me, on the last 3000 shots.
    Not bad I reckon, I am hoping my new to me 7000 will last as long with the same or less maintenance.
    It is near new, hardly used, and I paid $205.00 NZ.
    BLW likes this.
  24. #24
    BLW
    BLW is offline
    Oct 2017
    35
    If you've got the background of repairing those machines yourself and know where to get the spare parts from cheaply (I'm not sure how easy Sunbeam sends out parts to private owners), you got a good way to enjoy coffee without spending a lot indeed.
    I myself would probably break more of the plastic parts in a Sunbeam when trying to fix it and would have to hand it over to a workshop in the end. It's quite expensive that way.
    There are lots of schemes out there for the Bezzera and the solid build might help me to do some maintenance myself once the warranty has passed.
  25. #25
    Rbn
    Nov 2010
    Southland NZ
    441
    Well yes and no. Yes I do do my own repairs, so eliminate the labout cost.
    Steam thermoblock was used, but new! if you understand me. NZ$40.00
    Bought from the local repair shop when I asked them to diagnose what was wrong with my steam thermoblocK.
    It was totally blocked, knowing what I know now, I should have tried to clear it.
    Bought the magnetic water level sensor online from a place in Aust.
    Bought the collar and various group head seals from the local repair shop, who source them from Sunbeam.
    Collar NZ$75.00
    New collar screws/bolts, local bolt supplier $5.00, not torx, cap screws, all fine.
    The old ones were seized in, and sheared off.
    Bought a spare set for another 6910 I am about to pull apart.
    But you see I like tinkering around with all kinds of stuff.
  26. #26
    Rbn
    Nov 2010
    Southland NZ
    441
    Haha, you remind me of the local garage owner where I work sometimes to help him out.
    He says, Charge out rates are:
    Normally $90.00 ph
    If you have tried to fix it and failed $105.00 ph
    If you have tried to fix it and broken it $125.00 ph
    Dimal, level3ninja and BLW like this.
  27. #27
    BLW
    BLW is offline
    Oct 2017
    35
    Collar NZ$75.00
    Yep, looks almost like you've got a coffee machine to have something to fix
    From your reply it seems that you didn't run into many electronical problems. My EM7000 started to dispense water through the group head instead of the water spout, which doesn't make sense how that could happen. Descaled, backwashed with machine cleaner; no difference.
    Identifying the problem is the first issue I would have with a DIY approach. A leaking group head seal or steam wand - I can replace that. A thermoblack though where you need to solder bits together? Go straight and pay the $90 ph.
    It adds up quickly though, especially if you have to send it to someone out of town/state too. A friend of mine tried to get her Jura fixed and most commercial machine repairers close by refused to do it as it's too much fiddeling around with all the pieces. Had to drop it off 400ks away and added some holiday ontop in the region. You wouldn't want to do that very often.
    My hope is that prosumer machines like the BZ10 can be easliy fixed locally as they seem to be fairly straight forward build - similar to a commercial machine. maybe some parts look like I can do myself if there's some walktrhough on the net for a similar machine.
    Fingers crossed, I won't have to worry about that for a long time, but it is something that I considered too when I made my purchase.
    rawill likes this.
  28. #28
    Jul 2017
    30
    I remember a saying "buy one and buy well." It was in the context of tools eg, Bosch v Chinese no name but its a good one for coffee gear as well. I can't imagine ever going back to a Sunbeam now with all that plastic and sh$@ steam
  29. #29
    Rbn
    Nov 2010
    Southland NZ
    441
    100% correct, only the thermal fuse.
    However, I have a Renault Laguna, ask me about that, it is one of the best but most troublesome cars i have ever owned, and I have owned over 40!
    My Saabs have given no issues, and I have 4 of them, have owned 7 in all.
    So it is not only coffee machines I tinker with, my road cars and my racing car keep me amused!
