Results 1 to 2 of 2
Thread: Sunbeam EM7000 Intermittent problem, the Thermoblock heat is remaining active
    Sep 2014
    18
    Hello
    Intermittent problem the Thermoblock heat is remaining onand not timing out i.e. going to sleep. Sometimes it does follow the sleep timeset.
    Any idea what the problem could be please
    Thanks for advice
    Aug 2013
    5
    Heya,
    Have the same problem, but fortunately, my steam isn't affected (c.f. your other post). My solution thus far is to simply make sure it's turned off at the power when I'm not using it. It doesn't seem to affect anything else, though I'm curious to know if the thermoblock and the steam issue happened at the same time, or one caused the other?
    Snobs, what do Sunbeam technicians charge for this fix? Is it worth fixing?
    S
