Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By CafeLotta
Thread: Lelit mara - beeping noise- help!!
    Mar 2014
    13
    Just got my new lelut mara, turned it on, followed the test this and that per insteuction, waiting to heat up, water tank is full and suddenly starts beeping!! Turn on and off, beeping again .
    Suggestions?
    Mar 2017
    Lisbon
    71
    Have you read the manual? Usually there's a troubleshooting section towards the end.
    Mar 2014
    13
    Quote Originally Posted by zeezaw View Post
    U would think so!!!
    Nothing about it, very little online too... something about water sensor , not sure how to reset...
    I've realised that it started when i was pouring water into tank without removing it
    Mar 2014
    13
    Update:
    i half emptied the water tank and this seems to have solved the problem, machine has stopped beeping, the pump has kicked in and the heating ligh is on.. i have not done a shot yet !
    This cant be normal, ill be in touch with jetbeanesspresso tomorrow to find out whats next and whether there are special tricks with refilling the water tank the right way ... dissapoonting
    Jun 2012
    Melbourne, Vic, Aust.
    538
    Quote Originally Posted by kassa View Post
    Suggestions?
    Its not stuck in reverse is it?
    Really sorry! Couldn't help myself.
    338 likes this.
