Page 2 of 2 FirstFirst 12
Results 51 to 77 of 77
Like Tree4Likes
Thread: Boiler insulation & noise dampening
  1. #51
    Dec 2004
    Earth!
    15,037
    Re: Boiler insulation & noise dampening
    I think we need to source some of this stuff for insulating our boilers!
    http://www.mauricewardstarlite.blogspot.com/
    http://www.youtube.com/watch?v=W4nnLP--uTI
    Java "I want some!" phile
  2. #52
    16,199
    Wow! :o
    Thats magic stuff Java... Where can we get it from?
    Dec 2004
    Earth!
    15,037
    No idea Mal. Its been known now for well over 20 years and still has no public market that I can find. I suspect the military/government has taken it over and made it their own. Its far too handy and desirable a material not to have been marketed.
    Java "Inquiring minds want to know!" phile
  4. #54
    Jun 2010
    217
    This article explains very well the story of starlite.
    http://www.telegraph.co.uk/technology/5158972/Starlite-the-nuclear-blast-defying-plastic-that-could-change-the-world.html
    heres a interesting fact about its insulation properties
    Starlite has a Q-value [an energy absorption rating] of 2,470. The space shuttle tiles have a Q-value of 1. Not only that, but because Starlite is so lightweight – 1mm thick, compared to 75mm for the space tiles – its actually 2,470 x 75 times better.
  5. #55
    Dec 2004
    Earth!
    15,037
    A month or so of noise over it 2 years ago and then once again silence. I can think of so many uses just around the home for this its crazy. Talk about a revolution in insulating.
    Java "Wow!" phile
  6. #56
    Nov 2009
    37
    Hi guys,
    I have some of the sund deading stuff thats been touted around this site.
    I have had a look at it and it looks like a sheet of aliminium foil with a thick bitumen backing.
    The bitumen stuff stinks to high heaven when you have close mell of it.
    I am just worried that the high tempertures on the machine might make it realise a terrible smell in the kitchen. My wife is pregnant at the moment, so I dont want to risk it.
    Has anyone had an experince of a bad smell coming from the machine after installing the sound deadening material?
    Rob
  7. #57
    16,199
    Quote Originally Posted by 7A4B4B575E3B0 link=1258726137/55#55 date=1309400781
    No mate, not the slightest whiff... ;)
    If you take up on the partner topic of this thread, insulating your boiler will reduce the internal air temperature significantly and reduce the possibility (if it really exists) even further... 8-)
    Jul 2007
    2,280
    Hi Rob,
    The sound deadening material I used had no smell cold and no smell hot.
  9. #59
    Feb 2012
    Perth
    46
    Sorry for opening an old post
    Im thinking about using dynamat on the inside of the shell of my machine like lots of cs but from reading the thread and a bit of research I cant seem to find out if more is better? Or are small squares normally used due to cost
    thanks
  10. #60
    May 2011
    111
    Insulated my Giotto PP last week using insul-brite.
    Like Greg I opted for this to allow me to work around all of the connections and achieve a low mess outcome.
    I used 2 and 4 layers (2 in the front of the boiler where it was tight getting it down between the front panel), and insulated the ends as well.
    Cycle times improved (forgot to measure before sorry), and noise is damped considerably being lower in tone and volume with less ringing and vibration.
    I have not added dynamat but consider a heavy substrate like that would be excellent for absorbing direct sound energy and energy transmitted into the panels. Might be my next step :).
  11. #61
    May 2011
    111
    oops... forgot to mention another option..
    Take the top off, pump in expanding high temp insulating foam or fiberglass. Let it expand and set then trim off level to fit the top.
    Not great for maintenance and may put your espresso temp at the group out of wack but it would do the job well ;D
  12. #62
    Jul 2007
    2,280
    Quote Originally Posted by 3E39362B6E6A6A6E5F0 link=1258726137/58#58 date=1338013200
    thanks
    The instructions say that small amounts are enough to damp large areas. I figured if it worked for cars...
  13. #63
    Feb 2012
    Perth
    46
    thanks Greg, dynamat arrived in post today
  14. #64
    Apr 2012
    493
    Quote Originally Posted by 407562605068756A666B63070 link=1258726137/61#61 date=1338543727
    thanks
    This is correct, Dynamat doesnt work by blocking the sound, it works by increasing the mass of the panel to reduce transmitted vibrations, and also makes the mass distribution across the panel non-uniform which damps any potential resonances.
  15. #65
    Senior Member smokey's Avatar
    Oct 2013
    Canberra
    311
    Has anyone used bubble wrap for boiler heat insulation?
    Or as noise suppression of the water pump?
  16. #66
    14,665
    Bubble wrap has a melting point of about 2 deg C. Don't go there!
    chokkidog likes this.
  17. #67
    Apr 2008
    Victoria, Australia
    2,076
    Quote Originally Posted by smokey View Post
    ........... and lived, to tell the tale? ;-)
    Smokey...... don't play with fire!!! :-D
    Dragunov21 likes this.
  18. #68
    kbc
    kbc is offline
    Apr 2008
    2,962
    Expanding foam could make a big mess. Don't go there.....
  19. #69
    Senior Member Luke_G's Avatar
    Aug 2008
    Northen Rivers
    659
    Did my DC Mini today.
    I picked up 4 square feet of Stinger branded sound dampening adhesive from Autobarn for $50.
    I have not completely finished cause i wanted to drink coffee though so i just undid the 6 screws on the sides and lifted the outer case off and completely covered the panel from the bottom and left around 6cm from the top. I also covered the underside of the metal panel that sits between the boiler and the cup tray.
    The result is a much sturdier sounding machine and less of that tinny vibration sound. The sound it makes now is that low pitched sound that the vibe pump used to make just as it ran out of water. Slightly disturbing for the first 5 seconds but much appreciated by the ears now
    The next time i will put some around the pump area to see if i can reduce the volume more.
    I will also make sure i take a couple of pictures while i am at it.
    Dimal likes this.
  20. #70
    Senior Member artman's Avatar
    Jun 2006
    2,288
    I got some of the Stinger Expert Roadkill deadener. I applied it to my Bezzera Domus Galatea, it made a marked difference to the sound of the machine. There is a buzzing somewhere inside that I could not locate to isolate, maybe its just a slightly noisy pump, but it was certainly worth the effort. I applied it to side and rear outer panels, the vertical panel between the tank and boiler, along with any other metal sheeting that resonated when tapped with a finger. I found the source of a somewhat random horrible loud noise in the process. I inserted an in tank water softener, and this was at times vibrating against the side/base of the water tank, the tank was acting like a drum!
    Jun 2006
    BRISBANE
    1,939
    In 2009 i lagged my Faema Due boiler with Armoflex HT - closed cell foam about half an inch chick. Resulted in pressurestat triggering about once every 4 mins as opposed to every two mins. Checked 'under da hood' the other day and some of it has gone hard where the really high temp areas are but still doing its job.
    Oct 2014
    10
    Hello,
    Do you know who sell the insulation foam in Australia? Needed some for my home lever machine. Thanks
  23. #73
    TOK
    TOK is offline
    Apr 2013
    697
    Just be aware that insulating an espresso machine boiler is not the simple nirvana that some seem to think.
    When you insulate something that wasn't insulated to start with, you change the designed heating cycle dynamic. Depending on the internal design of your particular model, insulating the boiler may be helpful in some way, and then again it may not. For example, insulation in some machines causes them to overshoot the designed temperature cut off point by a significant margin, causing whatever related problems that it will, and necessitating other internal changes / modifications to try and work that back down to an acceptable situation.
    That is, beware that every action has a reaction, and its not the same for all different models. Determine first what you are trying to achieve by insulating, weigh up whether its really "worth it" just because its a subject that is occasionally discussed in forums, and be prepared that the behaviour of the machine may change in some way.
    Dimal likes this.
  24. #74
    Jan 2014
    11
    Boiler Insulation - Armaflex or equivalent
    Does anyone know of a convenient source for some boiler insulation - I have looked around but unless I want a full role of it then it is difficult to find. I only need to insulate one 5 Litre boiler.
    I did some searching and it seems Armaflex was recommended - anybody have any other recommendations that are easily sourced?
    Its for a Aurora Lever.
    Dec 2004
    Earth!
    15,037
    Toys! I must have new toys!!!
  26. #76
    Jan 2014
    11
    Thanks - I finally tracked down some from an A/C Supply shop.
    May 2014
    50
    I used Dynamat for my Bezzera Magica, and am overwhelmed with the difference. Before I use to get some rattles which to me made the machine sound cheap, now all of that is gone,. I can still hear the pump and have a little rattle from the top plate (which cant be insulated as its the cup warmer - I was able to insulate half), but it has made a great improvement. I would like to do the boiler but have not been able to find something suitable. The dynamat is not suitable for the boiler, as it gets to hot and will cause the sticky glue to heat up and not adhere.
    I used a whole packet, I did every wall inside my machine, covered about 8-% of each side, I used some on the the cup warmer (back half which has no holes) and also placed a sheet on the bottom of the machine. I was not game to completely strip my machine but it would have been good to do to cover the motor. I also put some under the cup tray. Any little vibration is gone now.
    I am happy with the result.
    Im now deciding if I should do my grinder, surely it can quietened a bit internally to dampen the noise?
    has anyone done there grinder yet?
  1. Boiler Insulation - has anyone tried this?
    By michel_c in forum Brewing Equipment (non-machine specific)
    Last Post: 19th December 2008, 08:43 PM
  2. Boiler Insulation
    By Dimal in forum Brewing Equipment (non-machine specific)
    Last Post: 13th July 2007, 05:54 PM
