Page 2 of 3 FirstFirst 123 LastLast
Results 51 to 100 of 139
Like Tree15Likes
Thread: Greg Pullman's portafilter pressure gauge on the road
  1. #51
    May 2007
    431
    Received gauge today. I'll test it on the weekend.
  2. #52
    May 2007
    431
    Last night I tested my Vibiemme Domobar Junior with the gauge and found that it was a fraction over 9 bars. Only a minor adjustment was required. Today I poured one espresso and could not discern any difference in the taste or pour.
    Does anyone else want to use the gauge?
  3. #53
    Jul 2008
    42
    Yes, I would like to use the gauge, but I'll be away from May 9 to May 16. Should I wait until I get back before sending the request? It's not at all urgent, anyway.
  4. #54
    Mar 2005
    2,165
    Hi guys,
    The gauge is at the end of its travels. If anyone else wants it at the discounted price follow the instructions in the first post and you'll get it with minimal delay, otherwise it'll come back to me for a spit and polish until it's required again.
  5. #55
    Oct 2011
    1,347
    Email sent. Cheers Greg.
  6. #56
    Oct 2011
    1,347
    Fee transferred. Please add me to the queue
  7. #57
    Jan 2008
    5
    Money transferred, please add me to the list.
    Peter
  8. #58
    Oct 2011
    1,347
    Got the gauge yesterday. Hopefully will put it to use over the weekend.
  9. #59
    Jan 2008
    5
    Just reporting that I received the gauge, and have used it to fix the pressure on the Silvia. Does anyone else want it, before I send it back to Greg?
    A couple of comments re my experience with the gauge.
    I have a Silvia V1 from about 2002, and I was dismayed to discover when I hooked up the gauge that the portafilter has a notch in it. Hence no pressure to the gauge. Had me stumped for a while trying to find a way to seal it, then discovered that 2 wide rubber bands of the appropriate size wrapped around the basket under the rim did a perfect job of sealing it.
    On testing the pressure, I found that it was set to 12 bar as apparently most of the early machines were. This surprised me as well, as I had done the 'check pressure by bleeding water out the overflow pipe using the blind filter test' some years ago, and had determined (supposedly) that the pressure was correct at 9 bar. So either I stuffed up the test, or it is not very accurate.
    Anyway, I had one of the teflon gaskets from coffeeparts, put that in, and after tightening the OPV as hard as possible, got the pressure to exactly 9 bar.
    Well, now I feel like a complete idiot for not doing this years ago. The difference is remarkable. Oh well, better late than never I guess.
    Peter
  10. #60
    15,796
    Quote Originally Posted by PeterT View Post
    G'day Peter...
    Great result mate and it is really noticeable, as you say, to pull shots at the correct Brew Pressure. The alternative method you used is really only a ballpark 'stop-gap' measure until a proper pressure setup can be performed. Quick and dirty is the term used I believe...
    Mar 2005
    2,165
    Hi Peter,
    So true. The very first post I wrote about this when first advertising the gauge (long since deleted, it was under the Pullman sponsor section) discussed the inaccuracy of that method, which Mal has well described. Others have written similar things so I'm sure no IP is lost to mankind! It's good enough as a starting point to make sure you're not a 2 or 20 bar, but not accurate enough for most of us here. The gauge is well served for this purpose.
    Dimal likes this.
  12. #62
    Mar 2005
    2,165
    As PeterT says the gauge has finished its travels, if you want to use it at the discounted rate please follow the instructions. PeterT if there are no takers by the end of next week (Friday 27 June) please email me to arrange its return.
  13. #63
    Mar 2014
    19
    Hi Greg and PeterT
    paid up and ready to go. Please add me to the list
    Sam
  14. #64
    Mar 2014
    19
    Received - thanks Greg and PeterT.
    somewhat disappointingly revealed my V3 silvia is bang on 9bar!
    any other takers?
  15. #65
    May 2011
    111
    I'm keen but waiting on my e-mail back from Greg's address.
  16. #66
    Mar 2005
    2,165
    Hi mgrobins, I've emailed you to follow up on this, let me know how you go. surgeonsam please stand by.
  17. #67
    May 2011
    111
    Quote Originally Posted by gregpullman View Post
    Thanks for the e-mail Greg. I have deposited the funds.
  18. #68
    Junior Member mcetp001's Avatar
    Aug 2012
    Adelaide
    18
    I wish I knew about this before I bodged up a pressure gauge using a piece of flexible hose and a couple of hose clamps to connect he gauge to the portafilter spout...it was kind of successful...
  19. #69
    May 2011
    111
    My giotto was sitting at 950 so I dropped it down a bit to 900 and am yet to test it. It's still apart so I can add some spare dynamat to the side panels .
    Who is next for this? Greg is it coming back to you?
  20. #70
    Mar 2005
    2,165
    Surgeonsam has indicated he's sending it to you. I've just followed up with him but you may like to touch base with him if he hasn't been in touch with you already to see where it's up to.
  21. #71
    Mar 2014
    19
    Hi Greg, just pm'ed you
    sam
  22. #72
    Mar 2005
    2,165
    Sorry my bad. mgrobins hold onto it for now, --- is interested but waiting confirmation and payment, if that comes through it can go to him, otherwise I'll get it back. Thanks.
  23. #73
    Mar 2005
    2,165
    No-one else needs it now so last call for this round before it comes back to me.
  24. #74
    May 2011
    111
    Seems 50kPa made a fair difference in temps as my coffee tastes less acidic and the water isn't boiling off after the machine has been sitting a while and I pull the lever.
    The boiler gauge on my giotto says 1bar now down from 1.2. At 1.2 bar the group head gauge reads at 950kPa.
  25. #75
    Dec 2010
    395
    950kPa is 9.5 bar. This is pump pressure. Boiler gauge reflects boiler temperature and nothing else.
  26. #76
    May 2011
    111
    Yes I know the Giotto's gauge reflects that. Lower pressure stat setting = Lower boiler temp = lower Hx water temp (and thus lower brew temp) Correct?
    I was merely highlighting the relative change in the markers that I have available to monitor change - those being the boiler gauge and the group head gauge I loaned from Greg.
  27. #77
    Senior Member magnafunk's Avatar
    May 2014
    East Kimberley, WA
    504
    Just paid up and would like to hop on the queue,
    May 2011
    111
    I have it waiting to go once I get the word from Greg that payment has arrived. PM me your address too .
  29. #79
    May 2013
    19
    Have paid Greg, please add me to the queue. Thanks!!
  30. #80
    May 2014
    East Kimberley, WA
    504
    Well after a few hours messing around with my Gaggia TS, I have it at just over 9 bar and the shots are cracking. Something that had me vexed for a while was, I would switch the machine off at the wall, adjust the OPV and then switch on, replace the warm water in the PF and retest. I could only seem to get 2 bar or 12 and never anything in between. I realised that because you have to remove a hose to adjust the OPV on my machine, that it requires a long flush with no PF attached before reattaching the gauge and taking your measurements. Once I had this figured out, it took me 3 goes to get it spot on.
    So, now my Gaggia which I am selling is at perfect pressure but unfortunately, my Cimbali which I am keeping has no thread on it's portafilter so no way to attach the gauge :-( I am ready to pass it on to saywhat as soon as Greg gives me the go ahead.
  31. #81
    Mar 2005
    2,165
    Yep all paid up thanks Magnafunk, send it on!
  32. #82
    Mar 2005
    2,165
    Hi guys, saywhat will have the gauge for a little while longer but there's no-one after him so there should only be a short wait if you want to use it. Follow the instructions in the first post to get in line.
  33. #83
    Mar 2005
    2,165
    Hi guys,
    The gauge has reached the end of its travels so this is the last call for anyone who wants to check the pressure of their machine at the reduced CS bulk rate of $15. If you want to grab it at immediate notice follow the instructions in the first post. If no-one's posted here by the end of September it'll come back to me.
  34. #84
    Senior Member Lukemc's Avatar
    Oct 2012
    MILLBROOK VIC
    598
    Hi Greg and saywhat i put my payment through this afternoon
  35. #85
    Nov 2013
    Brisbane
    29
    Paid up, please send onward when ready.
  36. #86
    May 2013
    19
    Hi luke! Could you PM me your address?
  37. #87
    Aug 2014
    7
  38. #88
    May 2013
    19
    Pressure gauge posted to lukemc.
  39. #89
    Oct 2012
    MILLBROOK VIC
    598
    Hey mate, waiting for a pm with your address
    Quote Originally Posted by MrMcSteam View Post
  40. #90
    Nov 2013
    Brisbane
    29
    Quote Originally Posted by JimmyF View Post
    Hi Jimmy please PM me your address and I'll send the gauge Monday/Tuesday.
  41. #91
    Mar 2005
    2,165
    Hi guys,
    The gauge is again at the end of its travels. Please advise in the next few days if you'd like to use it to get your Christmas coffees at their best , otherwise it'll come back for a service until it's needed again.
    Aug 2012
    6
    All paid up, please add me to the list.
  43. #93
    Aug 2012
    18
    Is the gauge still traveling? Might be interested. Saves me making my own.
  44. #94
    Mar 2005
    2,165
    Yep it's still on the road, I believe it's on its way to GoatWhisperer. Follow the instructions in the first post of this thread to book your place in the queue.
  45. #95
    Aug 2012
    6
    Arrived today so will get to testing either tonight or tomorrow.
  46. #96
    Mar 2005
    2,165
    Does anyone else want to use this at the discounted rate before it comes back to me? If so please follow the instructions in the first post to book your place in the queue.
  47. #97
    Aug 2012
    18
    Yep will get onto it in the next couple of days!
  48. #98
    Aug 2012
    18
    Paid, the gauge will stay in tas for a little longer!
  49. #99
    Mar 2005
    2,165
    Does anyone else want to use the gauge once hallph has finished with it? If so please follow the instructions in the first post.
  50. #100
    Dec 2008
    148
    Just paid Greg, please add me to the list. (And thank you!!!)
