Page 3 of 3 FirstFirst 123
Results 101 to 139 of 139
Like Tree15Likes
Thread: Greg Pullman's portafilter pressure gauge on the road
  1. #101
    Feb 2015
    26
    Paid, please add me to the list & thanks for providing such a handy service!
  2. #102
    Feb 2015
    26
    Quote Originally Posted by voicecoils View Post
    Gauge received, thanks to the last user who sent it nicely packaged and with tracking. Tested it today and it's showing my V2 Silvia at 10-11 bar which is about what I expected having read they were typically set high. Will pickup a OPV teflon gasket next week which is made to drop the pressure to ~9bar, test and send on to the next person or back to Greg if all goes well.
    Last edited by Javaphile; 12th September 2015 at 05:22 PM. Reason: Remove unneeded/bad code
  3. #103
    Feb 2015
    26
    Gauge is with me in Sydney now. Anyone else want it next?
    Turned out my Silvia has an adjustable OPV so no washer needed. Much force was needed to crack open the locking nut but once loosened I was able to drop pressure down to 9 bar on the gauge. I did find the needle valve in the pressure gauge setup a little tricky to calibrate & get the flow rate to repeatably drip at 1mL/sec. I was also surprised that pressure didn't seem to change dramatically with the flow rate too low (~0.5mL/sec) or too high (~1.5mL/sec) while I was trying to dial in the flow rate.
  4. #104
    Feb 2014
    Sydney, Australia
    17
    Hi guys,
    Just paid my dues to Greg's account so add me to the list. I did this last year but have moved my Silvia to a new homeand cleaned her and can't pull a good coffee since. I've tried everything but a check of the pressure will confirm all is OK. It's such an easy test that it's orth the money. Cheers...
    Zarbs
  5. #105
    Feb 2015
    26
    Gauge is back with Greg the OP. I sent it back to him a few weeks ago after the thread here went a bit quiet.
    Great tool, I recommend taking a turn trying it out!
  6. #106
    Feb 2014
    Sydney, Australia
    17
    Rechecked my pressure and had to tweak the bleed and then make a fine adjustment to my valve. All fine again now. I can recommend this setup for testing your pour pressures. Gauge is back with Greg now if you want to partake of this great service. Cheers...
  7. #107
    May 2013
    19
    Just paid Greg for the hire of the Portafilter.
  8. #108
    Oct 2014
    26
    Just sent the money through for the gauge hire.
  9. #109
    Oct 2014
    26
    Does anyone want the gauge or shall I send it back to Greg?
  10. #110
    Mar 2005
    2,165
    Gauge is coming back to me now, feel free to post in the thread when you want it next.
    Beanz. likes this.
  11. #111
    Feb 2015
    26
    Quote Originally Posted by gregpullman View Post
    I'm back with a new (for me!) coffee machine so I've sent payment to borrow the gauge again.
    Cheers!
  12. #112
    Sep 2014
    161
    Paid, please add me to the list. I'm trying the 6 bar approach promoted by Matt Perger. I want to see whether the pressure set at the rotary pump corresponds to the pressure at the portafilter. I have a Vibiemme Replica single group. Many thanks.
  13. #113
    Jul 2015
    11
    Paid - please add me to the list. I want to check whether my Breville Oracle pump is working as it should (I suspect it is not putting out enough pressure)
  14. #114
    15,796
    Quote Originally Posted by JohnF View Post
    Do the Group Handles of the Oracle use the standard 3/8" BSP thread John?
    Otherwise, the Gauge may not be able to fit directly; an intermediate thread adapter may have to be sourced before the Gauge gets to you...
    Sep 2014
    161
    Hi John, I don't believe the portafilter pressure gauge will fit on your Breville. And you can't remove the spouts under the Breville portafilter to directly connect the pressure gauge to the Breville.
    I'm testing the pressure on a Vibiemme Replica. I also have a Breville BES920, so I'll check whether the portafilter pressure gauge fits this machine
  16. #116
    Jul 2015
    11
    Good point - might have to buy a second group handle (I was considering having two anyway, as we use it in an office).
  17. #117
    Sep 2014
    161
    Hi John I'm ready to send the pressure gauge. However, you'll need a portafilter that uses the standard 3/8" BSP thread. I don't believe you can get one for the BES920.
    So do you want me to ship the pressure gauge to you?
    Cheers, David
  18. #118
    Jul 2013
    122
    According to this WLL vid on youtube, the gauge should read 10bar to get 9bar at the grouphead as the excess 1 bar will be diverted to the reservoir? happy to be corrected if I misunderstood. getting a porta filter gauge myself to adjust the pressure on my BFC junior.
    https://www.youtube.com/watch?v=torXYzDE2y0
  19. #119
    Oct 2011
    1,347
    Quote Originally Posted by symphonie View Post
    Completely wrong, sorry. The pressure at the gauge will be equal to atmospheric pressure (0 barg) plus the pressure drop across the valve (usually adjusted to 9 bar). The pressure at the pump discharge will be the pressure at the gauge plus the pressure drop between the gauge and the pump ; which may be 1 bar, in some circumstances (which would result in 10 barg at the pump discharge).
    Pressure can't be diverted elsewhere (but flow can).
    Dimal and symphonie like this.
  20. #120
    Jul 2013
    122
    Thanks, If I use a portafilter gauge should it read exactly 9 bar to get the ideal brewing pressure?
  21. #121
    Oct 2011
    1,347
    Just saw the video. You didn't misinterpret it (it's just wrong).
    9 bar at the group is a guide only - the pressure will vary during an espresso pour, as the resistance and flowrate change.
    Greg Pullman's portafilter attemps to replicate flowing conditions, so that there is some pressure drop in between the OPV and the group.
    It is a better approximation of real conditions than a blind, but you are effectively calibrating the OPV/pump gauge for a single flowrate.
  22. #122
    15,796
    But, isn't that the intention?
    Identify a median flowrate and then adjust the OPV/Pump Bypass Valve to achieve this at the Group?
    Oct 2011
    1,347
    Yep.
    All I'm saying is that it won't maintain 9 barg at all flowrates - so there isn't really _an_ ideal brew pressure.
    Dimal likes this.
  24. #124
    Jan 2014
    Discovery Bay, Hong Kong
    251
    Does that mean that everything revolves around how well the coffee puck in the filter basket is prepared that will determine the actual brew pressure and flow rate?
    Dimal likes this.
  25. #125
    15,796
    Yep, it sure does...
    And with machines that lack an OPV or a Spring Lever machine, etc it's even more important...
    Jan 2014
    251
    I remember the advice given to me by the guy I bought my naked portafilter for my Gaggia Classic from. "If you do not like how the shot you pulled turns out, just do it again. Don't change the dose or the grind setting. There is a high chance it is just your fault." Best advice I got when I was a newbie to the world of home made espresso.
    Dimal and trentski like this.
  27. #127
    Jul 2016
    Inner West Sydney
    222
    Is this still doing the rounds?
  28. #128
    Mar 2005
    2,165
    Hi @Janus,
    Yep as long as someone needs it it's still available. Just follow the instructions in the first post and I'll send it out to you.
    matth3wh likes this.
  29. #129
    Jul 2016
    Inner West Sydney
    222
    Paid up, please add me to the queue.
  30. #130
    Mar 2005
    2,165
    Thanks Janus... if anyone else wants to use the gauge please check the instructions at the start of the thread. Janus should have it around the end of this week so I'd imagine it'll be available mid-September-ish.
    matth3wh and Janus like this.
  31. #131
    Jul 2016
    Inner West Sydney
    222
    Whoops figured it out.
  32. #132
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    829
    Thinking about joining the queue. I know MB21 was also considering it.
  33. #133
    Jul 2009
    Mid North Coast NSW
    829
    Righto, I've paid up... add me to the queue. I've sent a message to Janus.
    Matt
  34. #134
    Oct 2016
    Central Coast NSW
    199
    As matt said I'm keen just not ready yet
  35. #135
    Oct 2016
    Central Coast NSW
    199
    I've sent payment tonight so when Matt is finished (no hurry) i'll get the gauge when Matt is finished.
  36. #136
    Jul 2010
    13
    Please add me on the list, all paid up.
    Thanks Rob
  37. #137
    Jul 2010
    13
    All done with this now. If there is nobody on the list I'll send it back to Greg after the weekend.
  38. #138
    Dec 2006
    83
    Hi Greg. I have just paid you by internet banking $20.
    For anyone else who does not find it obvious, yes you have to remove the underscores as well.
    All the best,
  39. #139
    Dec 2006
    83
    Ready to post
    OK I am ready to post on or back to Greg.
    The female brass fitting that screws onto the group handle had split along a manufacturing seam and leaked badly so I had to source one. The new one has a bit thicker wall so I doubt it will happen again. The threads on the old fitting were pretty worn so not a bad thing that it is replaced. I have put in a new rubber washer that was missing but the new fitting is a little deeper than the old one. This means that the short length of threading on most group handles will probably not compress the washer and you will still have to rely on the plumber's tape to seal the threads. I have put in a new roll of tape.
    Thanks Greg for providing the service.
    Dimal and Quant like this.
