Page 2 of 2 FirstFirst 1 2
Results 51 to 57 of 57
Like Tree24Likes
Thread: Another tamper that looks interesting or is it?
  1. #51
    Senior Member Logga's Avatar
    Mar 2010
    Napier, New Zealand
    304
    Pretty broad statement Logga, I don't find leveling the dose challenging in the least, it's a skill most people acquire very quickly.
    Just trying an edit!
    You must of read the piece when I was trying to edit my first post, I copied and pasted the whole of the link, as you read the first part of the link it says what you thought I said.
  2. #52
    Aug 2015
    Perth WA
    461
    If you tamp freehand and want to know how level your bed is....
    ....leave the tamper in there and look/feel the height it protrudes above the basket is consistent all the way around. It isn't that hard......
    Dimal likes this.
  3. #53
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,664
    Quote Originally Posted by MrFreddofrog View Post
    Yes that's the ideal way to do it. What I'm saying is I've had tamper/basket combinations where this wasn't possible. Also you'll find that unless you get down and really eyeball it you won't get it perfectly level each time using this method.
    Logga and matth3wh like this.
  4. #54
    Aug 2015
    Perth WA
    461
    No not PERFECTLY level but I'd hazard a guess there would be very few people on this planet who could taste the difference.
    trentski and Yelta like this.
  5. #55
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,390
    Mr FF has nailed it,
    "just spread your fingers around the edge of the basket/tamper while pressing down to gauge it's level? That's all I do. Seems to work fine."
    Works a treat.
    MrJack likes this.
  6. #56
    Senior Member LFM60's Avatar
    Oct 2016
    328
    The coffee shops I've visited all seem to use this method pictured. (like a bench drill )
    Wouldn't it take the guesswork out of tamping? It should be consistent.
  7. #57
    Sep 2013
    1,664
    True, half a mm each way isn't going to make any difference, especially when you consider that it's unlikely that any other part of the equation is perfect. So as long as you can work consistently within small tolerances you'll be good as gold.
    Dimal, trentski and LFM60 like this.
