Page 4 of 4 FirstFirst ... 234
Results 151 to 180 of 180
Like Tree222Likes
Thread: ONA coffee distributor
  1. #151
    Apr 2013
    39
    I've the got the cheap version and have to say it's surprisingly well made given the price.
    My favourite use for it is covering the top of my grinder allowing me to put the hopper away each day
  2. #152
    Oct 2009
    Geelong
    697
    Quote Originally Posted by Robbo1111 View Post
    Hey Robbo1111, how do you find using the cheaper version for consistency of extractions? Do you feel it distributes pretty well?
  3. #153
    Jul 2012
    653
    I have an alibaba cheapo distribution tool that I found out about via a snobs thread a while back and its awesome. Grind into the pf basket, quick spin with the cheapo tool, tamp and go. Within a few seconds of pump starting the pour comes to a perfect cone with dark striping- and its repeatable. I am comfortable with my non tool based distribution but have to say that these days my workflow usually involves the tool because I can do it quicker and it does appear to be extremely consistent with a great result.
  4. #154
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    845
    Glad you're seeing consistent results Melbroaster as well as workflow improvement. Is it a chisel style or 3 vane (?) style ?
  5. #155
    Apr 2013
    39
    Quote Originally Posted by simonsk8r View Post
    seems to perform as advertised, I'm no expert but the naked pours look pretty good to me and I'm still using it everyday which says it all really
    matth3wh likes this.
  6. #156
    Jul 2012
    653
    Quote Originally Posted by matth3wh View Post
    3 vane. Only complaint is that because its a smooth and heavy metallic object always nervous I will drop it....
  7. #157
    Jul 2009
    Mid North Coast NSW
    845
    I've been interested to see how those new to the device take to it easily and adjust it in to workflow. It has been a good leveller.
    I'll be interested to see what comes out of the BH distribution testing...
  8. #158
    Oct 2009
    Geelong
    697
    @Melbroaster ah very cool, I'll have to look into that.
    @Robbo1111 hmm interesting.. Seems like it's still designed like the OCD then (except 3 vanes instead of 4), might have to get me one, can never have enough coffee gizmos XD
    @matth3wh I'm also interested in the results, I reckon it's awesome he's really putting it out there and doing solid testing
  9. #159
    Nov 2006
    NSW
    365
    I just ordered a cheapy off the bay, I'll see how it compares to the OCD v2
  10. #160
    Oct 2009
    Geelong
    697
    Quote Originally Posted by Jono_Willmer View Post
    Ah nice, would love to hear how your testing of it goes mate
    Jono_Willmer likes this.
  11. #161
    Jul 2012
    653
    Something I have noticed is that all of the tips about these tools recommend to set then so that they dont go down too far into the basket incase the tool partially tamps the grinds. I found with the tool set like this the pours didnt look or taste right and had visible channelling, but after adjusting so that around 1cm of the tool is in the basket it worked great. It certainly partially tamps and then leaves a level bed for final tamp
  12. #162
    Senior Member artman's Avatar
    Jun 2006
    2,216
    I got the eBay FCD (Faux Coffee Distributor) to try out. 3 vane with knurled sides for easy grip.
    Make the extractions more even. I have gotten the best extractions with this than I have before, mine were always starting off as a bit of a doughnut, this almost eliminates it.
    Very quick and easy to use and helps with consistency.
    Jono_Willmer and matth3wh like this.
  13. #163
    Oct 2009
    Geelong
    697
    Ah that's great to hear, am considering getting one, is that one of the $24 ones?
    Would you say the gist of it and how it primarily works is by moving/pushing the grounds around to fill in gaps, and do you find it slows down the flow, or same flow speed just more even extraction?
    Wondering if nutation achieves the same thing (albeit trickier to keep as consistent)...
  14. #164
    Jun 2006
    2,216
    Yep it was around that $.
    I would say it moves the grinds and distributes them (somewhat). I have not tried doing a deliberate lob sided dose and assess the effect.
    Looking at the relatively shallow vanes, I think there is a limit to how much spreading it does before it starts compacting the grinds. When I use it I dont press it down all the way then spin, I keep it elevated and slowly lower as I spin until it bottoms out. I do get a few grinds popping out of the PF onto the tamping mat during use.
    simonsk8r likes this.
  15. #165
    Nov 2013
    Casula, NSW
    609
    I have found with my FauxCD that it doesn't do a great job of redistributing. It does some but if you have a very lopsided mound it will do more tamping than distributing and you will probably still have a bit of a hole once it's done.
  16. #166
    Oct 2009
    Geelong
    697
    Ah interesting, I guess it's more of a case of distributing as best as possible initially while dosing, then using the tool to put in the finishing touches and help lock it all in properly perhaps?
  17. #167
    Jul 2009
    Mid North Coast NSW
    845
    Punched out 150 coffees this morning for Men's Shed Grande Opening and OCD v1 worked a treat.
    Wished I'd taken enough time to do another wipe of micro fibre cloth clockwise wipe trick to try preventing coffee sticking. Seemed pretty low waste.
    There wasn't too much coffee waste overall and a large percentage of that was particles flying off the PF mound during grind.
    People came back for more Toby's and then some Tanzanian SO. Nice even consistent pours.
  18. #168
    Jul 2009
    Mid North Coast NSW
    845
    A pic of the setup... men's shed handy work coffee station made of recovered timber.
    OCD in there with respect wrist band.
    Pallets around sides...
    Top...
    artman, Dimal, Mb21 and 1 others like this.
  19. #169
    Oct 2009
    Geelong
    697
    Ah sweet setup! I'd love to do barista work again at certain events, not so much busy cafe work again, but would be so much fun meeting people and helping out, and i definitely see myself in the coffee industry at some stage in some capacity, great idea, how long have you been doing that sort of thing Matt?
  20. #170
    338
    338 is online now
    Mar 2017
    385
    Nice bench Matt! You have to admire the craftsmanship
  21. #171
    Nov 2006
    NSW
    365
    Top...
    Those Eureka grinders are actually really good once they bed in.
  22. #172
    Oct 2009
    Geelong
    697
    Hey Jono, just wondering if you've had a chance to test out the cheapy and how you've found it? (I finally bit the bullet and ordered one to test out hehe)
  23. #173
    Nov 2006
    NSW
    365
    Well, I ordered one for my dad and I haven't used it yet, I was planning to do a side by side last weekend, but it didn't happen. My dad is loving it and uses it everyday now, he says he finds it helped him gain consistency and hasn't been getting any noticeable channeling since he started using it. Let me know what you think of yours. I'll be at my dads next week so I'll report back when we have used it together with the OCD.
  24. #174
    Oct 2009
    Geelong
    697
    Ah awesome to hear, will let you know for sure, I'm wondering if it does as well as WDT (which I've been having alot of success and consistency with). Shouldn't be too much longer until it's here
  25. #175
    Nov 2009
    Altona, Melbourne
    1,579
    Quote Originally Posted by Melbroaster View Post
    Have you tried without tamping? Make it a one step workflow?
  26. #176
    Oct 2015
    19
    Mine would always collect substantial amounts of coffee on the tool when I had it lowered, I've found there is a very fine line between too deep and no distribution happening.
  27. #177
    Oct 2009
    Geelong
    697
    Soooooo it finally arrived! (8 weeks later hehe.. there was a problem with the courier or something), it even came in an 'Espresso Parts' box. I only ordered it off the ewok-bay, but maybe EP were clearing them out and someone purchased them all to sell. (The tool doesn't seem to be on their website anymore)
    Looks like a really decent construction! Easy to adjust the level and also seems quite a range of depths you can go to. How EXCITING!!! Will give it a crack and report back, have no idea what level to start at but very cool
    Dimal, Jono_Willmer and Magic_Matt like this.
  28. #178
    Nov 2006
    NSW
    365
    Congrats they are pretty good for the money the thing i noticed the most between them was the size they seemed a little loose in the basket due to the diameter being slightly smaller. Maybe the puck didn't flatten out quite as easily either, but overall excellent.
  29. #179
    Oct 2009
    Geelong
    697
    Ah right, yeah it seems a little loose but am sure it should be fine. Will start maybe on the shallowest setting and progress from there (although the shallow setting doesn't seem like it would reach much into the puck hehe)
  30. #180
    Nov 2006
    NSW
    365
    I found you want the blades deep enough that they move all the surface flat, but not deep enough to start to create a tamping effect. The looseness isn't an issue as you spin it it moves out to the edges anyway. One thing i did find helped a lot was putting a rubber band on the edge to get a better grip. The wrist bands that charities sell are ideal.
