Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By level3ninja
  • 2 Post By DaveD
  • 1 Post By rawill
Thread: Using the Pullman 22-24 gr basket
    Member Charlie4coffee's Avatar
    Jul 2017
    37
    Hi everyone,
    After some time playing with the bottomless portafilter, I am searching for a way to use my Pullman 22-24 gr. basket with a double spouted portafilter.
    Especially for the mornings, when I am a bit in a rush so I can do two at the same time and just be done with it.
    Are there any portafilters that are deep enough to accommodate this? I have 2 different but the portafilter just won't lock in. This also happen with a "no brand" 21 grams basket. It is too deep.
    I already have a VST 18gr. and this fits, but the dose is not enough me and my other half
    Are there any possibilities out there or the maximum that can fit in an E61 portafilter is 18-20 grams?
    Charlie
    Rbn
    Nov 2010
    Southland NZ
    441
    No idea really, except to ask if you P/F has a plastic insert like some EM 6910 handles.
    If so I would throw the insert out, the new EM 6910 handles don't have them, and I just ordered one.
    The 19/22 Pullman baskets fit in my P/f with the plastic insert in.
    Jul 2017
    37
    Quote Originally Posted by rawill View Post
    Hi Rawill,
    what plastic insert do you mean?
    My portafilter is just all metal, except for the handle of course
    Sep 2007
    Northlandia
    1,357
    Hey Charlie, the best shot might be to measure the depth of your basket and post it so people can compare to their own basket or pf.
    What do you dose the Pullman at? I use a 20g IMS basket which fits my ECM spouted double portafilter and takes a dose of 22g comfortably with my setup. So that might be an option... or of course you could pour the shot into a jug and split by decanting into two cups after.
    Nov 2013
    Casula, NSW
    591
    Quote Originally Posted by Charlie4coffee View Post
    Hi Rawill,
    See inside the 6910 portafilter here:
    And once removed:
    rawill likes this.
    Jul 2017
    37
    And once removed:
    @ level3ninja: Oh thanks so much level3ninja, I have actually never seen that before!
    No mine is alreadyin a 'natural' state
    @Matt: Thanks Matt. I usually dose 24g only when we share. Once I had a shot of 24gr by myself and my eyeballs were about to shoot out!
    Thanks for reporting about the IMS, my VST 18gr barely takes 18, I find it collides with the shower screen and most time does the puck suction effect...a total mess!
    Yes, I could buy one of those spouted glasses and then split. I will take measurements and report back.
    Charlie
    Nov 2013
    West Footscray, Melbourne
    181
    Hi Charlie,
    Take a look at the Cafelat E61 portafilter. It seems to be deep enough to take a triple basket, and can also be converted from double spouted into a naked portafilter if you want. They used to be available in beanbay, but I'm not sure whether Andy is selling then anymore.
    Cheers, Dave
    matth3wh and Charlie4coffee like this.
    Rbn
    Nov 2010
    Southland NZ
    441
    Just got back, see you have an answer on the plastic bits!
    And lots of E61 Naked P/F available if you take a look around.
    I want to know if one of those will fit my EM 6910.
    Charlie4coffee likes this.
    Jul 2017
    37
    Thanks Everyone for the great suggestions! It seems the cafelat may be the only solution.
    The Pullman seems 20mm deep, here the image.
    Sorry for the general blurriness but it has been taken with a 1.8 lens while keeping the ruler upright and I couldn't bother focusing
    Nov 2013
    Casula, NSW
    591
    No they won't
    Senior Member artman's Avatar
    Jun 2006
    2,203
    My Synesso double ridgeless measures about 25mm high total, bottom to top of lip.
    The E61 Cafelat PF measures about 31mm internally from floor to top of lip. Heaps of room for it.
    An excellent quality PF that easily doubles as naked (the only way I use it).
    Only downside is that being relatively tall on some grinders grinds spill as you remove after dosing as some grinds stay inside the chute. This can be overcome by tapping to settle on the forks while grinding or dosing two smaller doses.
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    836
    Love these Cafelat PFs. Can't work out why they're not more commonly available in AU. Andy may still have some for you. If he doesn't then you can buy direct from the maker. Should fit the Pullman basket nicely.
    Jun 2006
    2,203
    From memory last time Andy updated re cafelat he said the items were removed for a stocktake.
    Jul 2009
    Mid North Coast NSW
    836
    Edit: re-reading emails- last I asked he had some on pallets but couldn't find the NS handled ones I was looking for.
    So you may be in luck as your E61 style may be in stock. It can't hurt to ask either way.
