Results 1 to 27 of 27
Like Tree16Likes
  • 1 Post By simonsk8r
  • 6 Post By Javaphile
  • 2 Post By Javaphile
  • 1 Post By Jackster
  • 1 Post By Stu76
  • 1 Post By Lootee
  • 1 Post By woodhouse
  • 2 Post By Yelta
  • 1 Post By Arcade
Thread: Scales - advice on what to get and use
    Jul 2014
    15
    I've never used scales before (to make coffee). I realise I should.
    What do people recommend?
    And how are they used in general? I use an espresso machine and figure I would use a set both to:
    • weigh the dose
    • weigh the coffee in the cup as it's extracted
    Is this the correct approach?
    Sep 2011
    105
    I use a set of acaia lunar scales. They are compact in size and suit my method.
    My method is
    1. Weigh the grind into a small cup and then the pour cup into portafilter
    - I do this because the lunar is small and my portafilter doesnít quickly and easily sit on the lunar.
    2. Make the coffee and weigh the fluid output in the cup.
    The acaia has a bunch of other features that I just donít use at all, ever.
    I bought some cheap eBay jewellery ones initially but they were terrible.
    So I think you have the right approach to it, itís just the fun bit of deciding which one you want.
    Dec 2011
    PRL
    2,476
    I use a v. similar method to spin_addict but haven't had much trouble using some cheap scales off ebay ('Salter' or copies thereof). Luck of the draw I guess. I do own some Hario scales designed for pourover as well, but just use them for the timer (yeh....I know I could buy a timer, BCBA).
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,140
    Been using a cheap set (less than $10) of electronic sales 200 gram max, 0.01 accuracy (Ebay) for many years, never had a problem.
    I only weigh dose, not shot.
    Dec 2011
    PRL
    2,476
    Yeh, I weigh the shot 'every now and then', largely when changing beans.
    Oct 2009
    Geelong
    920
    Yep scales are a great idea, and it really doesn't add much time to the routine, if anything it subtracts frustration by getting more consistent results .
    But I would suggest getting a decent set of scales to be honest (at least $30+)... I recently found out that the scales I was using for a few years was being horribly inconsistent when weighing doses. I noticed one day that "Hmmm... why does it look lower in the basket when I've dosed the same amount...?" It was because it varied the amount each time. I suspected it was off, so I ordered new scales, used them side by side and confirmed it. Sometimes it was off by 0.4 grams, other times 1.8 grams! So a note to all, make sure your scales are consistent!
    And yeah I weight for every dose and weigh every espresso. I usually don't have the scales under the cup as it's being poured (but weigh it after the pour) as it takes my attention away from watching the pour itself and when to cut it (unless I'm pulling a ristretto then I'll have it under for a bit of feedback)
    noonar likes this.
    Sep 2009
    274
    Scale Accuracy - Weight your fav Tamper, then take it with you to the Fruit n Veg / Butcher shop and use their digital scales.
    Compare the weights. Unless of course if you have an Acaia which comes with 100g test weight.
    Dec 2004
    Earth!
    15,041
    Or use some freshly minted coins as they are typically pretty precisely measured. Plus you can use them in combinations that will very closely match the mass of beans you are using.
    Also be aware that while the scale may not be dead on accurate, if it's a halfway decent scale it should be consistently off by the same amount.
    Java "Precision is nice" phile
    Andy, artman, Dimal and 3 others like this.
    Toys! I must have new toys!!!
    Nov 2017
    40
    Quote Originally Posted by Javaphile View Post
    You mean the scale may not have accuracy but precision or repeatability.
    Oct 2009
    Geelong
    920
    That's the thing, mine was accurate when weighing the portafilter, then I would tare it, but subsequent dosing amounts would vary, so it just wasn't even consistently off by a certain amount which was bizarre.. And they were actually a decent set strangely enough.
    It only really did that however with dosing into the portafilter basket, but when weighing the (liquid) shot afterwards it showed the same amount on both scales.. weird... I have a feeling it was the higher weight of the portafilter it had trouble taring with (portafilter weighed 501ish grams, where's the espresso cup was 100ish or so grams...).
    Jun 2009
    Moonta SA.
    6,140
    As JP says, "precision is nice" repeat-ability is important, the scale may be off, however as long as the error is consistent it presents no problem, we're weighing coffee not gems.
    Fortunately I have a gem scale complete with a set of carat/milligram weights, I check the coffee scale every now and again, pretty well spot on, never seems to vary.
    Dec 2004
    Earth!
    15,041
    Quote Originally Posted by simonsk8r View Post
    Many (Most?) of the scale models we're talking about have a 500g max limit so odds are you're right in that it's the mass of the portafilter that's your issue.
    Java "Measure what?" phile
    Dimal and Barry O'Speedwagon like this.
    Oct 2009
    Geelong
    920
    Yeah true, but strangely this one had 2kg max capacity.. very strange haha, must just not have had great accuracy at that weight or something... but all solved with the new one I've got
    Nov 2017
    Maddington, Perth. Wa
    523
    I have a cheap ebay 5kg one. It was inconsistent, but this was because the battery cover was hanging down lower than the feet. So it was a bit wobbly. A bit taller feet and its better though.
    Id suggest a size that allows the pf to sit on it.
    My pf is 501g too...imagine that!
    simonsk8r likes this.
    Jul 2016
    Perth, WA
    38
    I use a Brewista to weigh dose into PF and cup. I use some cheap Decor 70ml salad dressing tubs for the ground coffee as they fit a 58mm PF neatly. I like the Brewista as it is rechargeable, waterproof and has a few different timing modes to suit different brew methods. And it was heaps cheaper than the Acaia!
    Dazzy likes this.
    16,203
    Far better to use a scale that maxes out at around 10 - 20 times or less, of the specific weight you're trying to measure.
    That is, the weight of the coffee, say 25g for a big double or average triple, multiplied by 10 which comes to 250 - 500g.
    Most digital scales within that range will provide decent enough repeatability and consistency to use as a dosing or a shot density scale. When you add significantly more mass such as a Group Handle or a Latte Cup, for example, then the mass of the coffee is so small by comparison, that you would need extremely sensitive resolution (and expensive) scales in order to get reliable results.
    Nov 2017
    40
    Most scales people are talking about are either toyish or mutton dressed as lamb like Acacia. There are things in the industry known as minimum weight, linearity, hysteresis, and eccentricity but you get what you pay for generally.
    Dimal likes this.
    Senior Member woodhouse's Avatar
    Dec 2016
    199
    I highly rec the brewista smart scale ii. Rechargeable, timer, different modes for brewing, and compact. Also has a very quick weight refresh rate which definitely puts it over the top of the cheaper timer scales.
    noonar likes this.
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    379
    When my 10 dollar scale karked it, I got the Brewista v2? on a %20 discount day. No complaints aside from fat finger syndrome when hitting the timer button. Agree with woodhouse.
    Nov 2015
    Clayton near Monash Medical Centre luckily
    47
    Hi all, my experience echos Noonars and probably several other CSers. My unimportant observations, buttons are too small too close together and the silicone? protective cover is too big and shifts forward to cramp the buttons. The scales are accurate, consistently, a full charge of battery lasts quite a while. Overall IMHO a very good product. Chippy
    16,203
    Quote Originally Posted by Lootee View Post
    Indeed...
    Jun 2009
    Moonta SA.
    6,140
    Here's something to make our younger members smile.
    In my early days of weighing doses I used (and still own) a gem balance very similar to the one below, a legacy of my previous life as an opal miner.
    Accuracy is spot on, with care precision is as good as, if not better than that obtained with a modern electronic scale, they are accurate down to 100th of a carat, that's 2 milligrams, breeze is of course the enemy of accuracy with these, no air conditioning whilst in use.
    One carat is equal to 200 milligrams, or 0.2 grams.
    One point is equal to 1/100th of a carat. So, it follows that one point equals 2 milligrams, or 0.002 grams.
    Its the weights from this set I use to check my electronic balance.
    Dimal and 338 like this.
  23. #23
    Oct 2009
    Geelong
    920
    ... that... is... so... COOL!!!
  24. #24
    Dec 2011
    PRL
    2,476
    A much more precise version of my grandfather's postal scales and weights that I used amuse myself with when going to work with him in the 70s.
  25. #25
    Sep 2017
    111
    Quote Originally Posted by woodhouse View Post
    I second this, mine has been great. Lots of different modes depending how you want to measure your pour. I have mine to only start the timer when it detects the coffee fluid going in, which then triggers the weight and you can watch them side by side. Also has a nice rubber top part which is easy to clean and rugged. Rechargeable, although I've had mine for about 3months now and haven't had to charge it yet.
  26. #26
    Senior Member Arcade's Avatar
    Dec 2013
    140
    I still use balance scales for dosing. Turns out that my test tubes weigh 33g, and I dose 17g of coffee so I only need a single 50g weight to balance!
    Rockford likes this.
  27. #27
    Sep 2017
    111
    Quote Originally Posted by Arcade View Post
    That's how I imagine someone would measure their coffee with that $280/kg beans Andy had.
Tags for this Thread
