Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Yelta
  • 1 Post By flynnaus
Thread: What's your post-holiday routine?
    Mar 2017
    Lisbon
    57
    The Bezzera manual recommends that after a week of inactivity you should run the machine for 12 hours and then drain the boiler. I had never come across this on forums before, do other manufacturers recommend the same?
    What's your routine?
    Mar 2017
    Lisbon
    57
    Here is a photo of the aforementioned instructions.img_20171108_165139.437 (1)-01.jpeg
    Dec 2009
    371
    I wonder what the concern is? Legionnaires?
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    388
    Quote Originally Posted by herzog View Post
    Doubtful it would be legionella bacteria as they are killed quickly above 80c and wouldn't survive even in a spogulated state at 100c+ making it extremely unlikely to grow in the boiler, even in some of the dead legs (like a hot water tap that is never used etc). If your water in your boiler has been allowed to get to boiling almost no bacteria (found in waterways) will survive.
    Seems strange to turn the machine on and then dump the boiler. I would have thought you would dump the boiler and away you go?
    Dec 2016
    Netherlands
    90
    I knew this question sounded familiar; I came across this issue on a German coffee forum, where somebody asked the same question. I have had my machine for 5 years and the manual did not have this kind of recommendation. Somebody mentioned the manual to his/her Strega (predumably of a later date) had the same instruction as a sort of appendix. It seems like a CYA statement to avoid any liability issues.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,794
    Quote Originally Posted by degaulle View Post
    May well be DeGaulle, probably not a bad practice if the machine has been standing for any length of time, water can/may pick up the taste of minerals in scale, doubt it would do much harm, but for the sake of a few minutes work why not.
    My Bezzera is 9 years old, just checked the manual, it doesn't contain this warning
    May 2008
    3,804
    If I am going away for a week or more, I usually drain the boiler before I go.
    Dec 2016
    Netherlands
    90
    I have been away for 10-12 days on occasion, but I havenít had any off-flavors because of it. The only time I had funny taste in the boiler water was right after I had changed an ion-Exchange cartridge. That prompted me to drain and refill a number of times. Flushing the cartridge that way made the
    off-flavors go away.
    Then again, I use the hot water tap daily, for rinsing the PF, tea-making as well as fixing the Mrs. an Americano.
    Jun 2009
    Moonta SA.
    5,794
    Quote Originally Posted by flynnaus View Post
    Interesting! have never bothered.
    Do you just run the tank dry or do you go in and remove the boiler drain plug or whatever?
    Like Degaulle I use the hot water daily so it does keep refreshing.
    zeezaw likes this.
    May 2008
    3,804
    I turn the machine off, slide it over next to the sink and open the hot water tap. I tilt it towards the hot water tap side to try to drain as much water as possible. I remember reading about this on CS as preparation for storage many years ago.
    zeezaw likes this.
