Results 1 to 8 of 8
Thread: Rotary pump VS Vibration pump (expobar)
    Aug 2009
    469
    I was just wondering the difference, both technically and practically, between the same machine but with one fitted with a vibe pump and one with a rotary.
    Im looking at an expobar minore III and i would really prefer a plumbed in version. i noticed that the plumbed version has a rotary pump and the water tank version has a vibration pump... so which is better and why??
    Thanks in advance.
    Apr 2008
    Brisbane
    5,102
    Re: Rotary pump VS Vibration pump (expobar)
    Both pumps work well
    I also just upgraded to a plumbed in small commercial machine
    Reason is
    Its a lot quieter
    I feel the rotary pump delivers better water pressure regulation
    But as I said above the vibe pump will handle the task
    Jun 2008
    1,520
    I love rotary, fully plumbed. Like KK I have a small commercial HX 1grp in the kitchen.
    I have no idea if its "any better", but i like it.
    I hope never to have to go tanked again.
    But thats me, only my opinion
    there is a downside for renters, plumbing can be a pain if you cannot drill a hole or two etc
    Leeham
    Jan 2008
    1,756
    If its of any use......i wish mine was plumbed, i really do, But i wouldnt replace it to get a plumbed machine.....if that makes sense, if i had the choice again....at around the same price id do it ;)
    PS $1000 extra at time of purchase for the Giotto, so no, not a chance :(
    Aug 2009
    469
    cool thanks for the replies...
    getting it plumbed isnt an issue, and for the minoreIII i think its around 500 extra for the rotary plumbed so its stomachable...
    anyone know any practical advantages for a rotary pump?
    Oct 2007
    789
    never running our of water
    never filling a water tank
    peace and quiet
    never cleaning out the water tank
    plumb it out too and never really think about waste
    pip
    pip is offline
    May 2007
    37
    Hi Snobs,
    * * * * * * *the best thing about running plumbed in is that *replacing the inline filters for scale and general particulate matter is a really simple job . *Write the installation date on the filters , and change them at the recommended interval , and the Expobar will be happily watered ! (descaling boilers is never pretty!)
    Technically the rotary pump (std Procon that is most often used ) has a much greater flow rate - than the Ulka ,Eaton and Fluidtech vibration pumps ( thats *the extra energy input of the larger motor of the rotary pump reflected in delivery volume ) *
    pip.
    Jul 2008
    Port Fairy
    2,993
    Also with a rotary if you want or need to at any stage you can readjust the pressure reg and go to an underbench tank should you need too.
    Dont forget to allow for (generally 350kpa) inlet pressure reg before the pump and good filtration when working out costs. Along with the initial cost increases of the rotary there is $2-500 worth of other bits used depending on what you do.
  1. Whats happening with my Expobar minore 4? or Why is my vibration pump humming?!?
    By NakiChap in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th December 2012, 09:54 PM
  2. Should a vibration pump pressure be set higher than a rotary pump?
    By NakiChap in forum General Coffee Related...
    Last Post: 25th June 2012, 05:11 PM
  3. Vibe pump vs rotary pump - Rancilio S24
    By coffeelust in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th March 2010, 06:12 PM
  4. Silvia - Rotary Pump?
    By spencarr in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th January 2010, 03:15 AM
