Results 1 to 37 of 37
Like Tree10Likes
  • 2 Post By TC
  • 1 Post By Yelta
  • 2 Post By Alan1
  • 1 Post By Dimal
  • 1 Post By trentski
  • 2 Post By Lyrebird
  • 1 Post By noidle22
Thread: How to descale a HX machine properly
    14,666
    This post in response to http://coffeesnobs.com.au/YaBB.pl?num=1274612190
    The topic comes up pretty often, so it has been made a sticky item.
    Hi Sammus,
    Its not that tough and Id be thrilled if I saw more machines in good condition rather than being full of barnacles. Its not a job I enjoy. ::)
    I use Bombora activated descaler and one batch will normally do 2 descales for mild to moderate scale. Its cheap and effective. For bad scale, I use the lot (100g).
    There is danger here as you will be working with a powered on machine and the job must be undertaken with extreme care. If you are not competent and dont hold the appropriate qualifications, leave it for a technician. 240V and water are not happy partners.
    To descale a HX machine:
    [list][*]First, with the machine switched off and cold, remove the mushroom (large hex nut on top of group) and examine for scale. If you dont see significant scale, you can stop here.[*]Disassemble the machine sufficiently to allow access to the boiler water level probe[*]Switch the machine on and allow it to come to working pressure. Start with a boiler as close to empty as possible. This is achieved by allowing the machine to come to pressure, switching it off and then opening the hot water wand. Boiler pressure will do the rest.[*]Mix the descaler (not store purchased citric acid) according to the instructions[*]Switch the machine on and allow the boiler to fill with descaler and the machine to come to pressure[*]Key bit. Open the steam wand, remove the wire from the boiler probe and allow the machine to drink until descaler appears out of the wand and then replace the boiler probe wire. I often flick the power off then as you want to keep things dry in there. Close the wand off.[*]NB. With a full boiler, some descaler may leave through the anti vac valve. If required, I open the steam wand for a bit and use towels if required to keep things dry.[*]Allow 15 min and then run a little descaler through group and both wands..[*]Repeat every 15 min until all the descaler is gone...Every time the machine drinks again, do the boiler probe bit again...[*]One the descaler is all used, repeat with water from the beginning to rinse the boiler- but the 15 min bit can be omitted. I do this at least 3 times for 3 complete boiler flushes.
    Its a fiddly job, and if youre not confident around electrikery, its not for you. AM has the emote to show you why....
    We charge $150 + parts- because to do the job properly, it takes 2-3 hours.....Other service agents will do it as part of a service and charge pretty much nothing. They just throw some descaler in the tank and rinse the boiler. That approach wont work for HX machines as the boiler is only ever 1/2 full. It is however fine for single boiler machines- like a Silvia for example. Multi boiler machines are treated like a HX machine, but then the brew boiler may need to be flushed more or completely drained to clear it of descaler.
    All of this will probably still be insufficient for really severe scale- the only option being complete disassembly.
    Hope that helps.
    Ron_Chambers and Yelta like this.
    Feb 2010
    10
    Hi Sammus,
    • First, with the machine switched off and cold, remove the mushroom (large hex nut on top of group) and examine for scale. If you dont see significant scale, you can stop here.
    • Disassemble the machine sufficiently to allow access to the boiler water level probe
    • Switch the machine on and allow it to come to working pressure. Start with a boiler as close to empty as possible. This is achieved by allowing the machine to come to pressure, switching it off and then opening the hot water wand. Boiler pressure will do the rest.
    • Mix the descaler (not store purchased citric acid) according to the instructions
    • Switch the machine on and allow the boiler to fill with descaler and the machine to come to pressure
    • Key bit. Open the steam wand, remove the wire from the boiler probe and allow the machine to drink until descaler appears out of the wand and then replace the boiler probe wire. I often flick the power off then as you want to keep things dry in there. Close the wand off.
    • NB. With a full boiler, some descaler may leave through the anti vac valve. If required, I open the steam wand for a bit and use towels if required to keep things dry.
    • Allow 15 min and then run a little descaler through group and both wands..
    • Repeat every 15 min until all the descaler is gone...Every time the machine drinks again, do the boiler probe bit again...
    • One the descaler is all used, repeat with water from the beginning to rinse the boiler- but the 15 min bit can be omitted. I do this at least 3 times for 3 complete boiler flushes.
    Hope that helps.
    I'll be attempting this soon, and have tried to make Chris's useful article easier to read.
    I will try to add some photos of the process.
    Kev.
    Junior Member Squidhead's Avatar
    Mar 2013
    Adelaide
    6
    Here is an instructional video from the girls at Seattle Coffee Gear:
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,241
    Excellent post Chris, writing understandable work instructions is not an easy task, full marks to you for this effort.
    Jun 2009
    Moonta SA.
    7,241
    Quote Originally Posted by Squidhead View Post
    As good as Chris's work instruction was this is the opposite.
    These two gigglers should stick to subject matter they understand.
    cafelazio likes this.
    Feb 2013
    280
    But they're good fun to watch. Admit it, you'd like to know what the cameragirl looks like too right?
    Does the top half of a HX boiler get much scale if the boilers are only ever half full?
    Jun 2009
    Moonta SA.
    7,241
    Quote Originally Posted by simonko View Post
    I have no idea, perhaps Chris can enlighten us.
    Mar 2013
    Adelaide
    6
    There is a video somewhere whereby you roll the Giotto 45 degrees over to one side. This will signal the machine to over fill the boiler and permit the descaling fluid to reach the top area.
    Feb 2013
    280
    Interesting you mention this. It's why I was interested how quickly scale builds up in the upper areas of the boiler and steam wand channels, thinking that steam would have most (all?) of the scale-producing nasties distilled out.
    Could one get away with an 'open-machine' descale every coupla' years, using the tilt method for the regular descale?
    Aug 2011
    Cranbourne, Victoria, Australia, Australia
    168
    Hi All,
    Thought I'd mention that yesterday I got around to using Chris' correct method to descale a heat exchanger. I was a little worried about what was going to come out, considering that (a) I'd only ever done the basic descale version (where you don't unplug the level-probe); and (b) the last time I descaled I was alarmed at the deepness of the green that came out of the boiler and the milkiness that came out of the group :S
    Well! I was relieved to see that colour was no where near as deep as it was last time, even though it was the first time cleaning the top half of the boiler.
    Thanks for the instructions Chris! And if anyone wants a decent instructional using this method...:
    How to descale a heat exchanger espresso machine - YouTube
    Oh! And one more thing, I noticed that when a little bit of the descale solution came out of the anti-vac valve, it really made the copper all shiny on the outside again!!
    -Aaron
    Member astr0b0y's Avatar
    Jul 2013
    60
    Great set of instructions, thanks Chris. Any chance of something similar for a dual boiler?
    Nov 2013
    6
    Hi everyone,
    About 2 months ago I bought a 2 year old (heavily used) Bezzera B2009 Compact.
    Retro 2 Group Compact - Bezzera - Commercial Espresso Machines - Espresso Machines
    Opened it for the first time about 2 weeks ago and noticed some scale on top of the boiler.
    My question is if I should descale it using directions mentioned in various threads on this forum. At the place where I bought it, sales person said not to descale it but rather bring it in and they would take it apart and clean the scaled bits one by one.This would obviously cost me more money as it is their goal to have return and repeat customers. To what extent should I listen to this person and how complicated and risky of a job would it be if I decided to do this myself as it is a HX machine and I have never done it with any other machine.
    10,496
    As you've admitted to zero experience, it comes down to how handy you are and your confidence.
    I'm handy but prefer to have my machine professionally serviced.
    Each to their own.
    Apr 2010
    558
    I like to descale my Giotto PP myself, I actually enjoy it, except the flushing the boiler bit at the end, I find that part a bit tedious.
    So, I was thinking the other day, what if I took off the anti-vac and screwed in a water pipe straight from the tap. Then, with the steam and water wands both open, and the water pressure kept fairly low, I could flush several litres through the boiler in minutes.
    I've tried to think what could go wrong:
    It's unfiltered tap water, but once the boiler has been flushed I'd empty it, so the remaining unfiltered water would be minimal.
    If I pumped too much water in, could it go back out through the OPV and through the Ukla, which might cause a leak? But I can't see this happening with the boiler full of cold water when 1.2 bar of boiling water doesn't cause a 'backflow' problem.
    Am I missing any other dangers here?
    Jonathon
    14,666
    Hi Jonathon,
    We reverse flush them these days- makes the rinse much more thorough. We doctored up some custom fittings to make the flush quick, safe and easy. A little care and you will be fine..
    Regardless, best not to descale unless there is good reason to do it. Throw acid at copper indefinitely and you end up with a boiler and brittle, dead plumbing
    Apr 2010
    558
    Thanks Chris. I needed to do a descale as a little lack of care with filtration (by 'er indoors) showed up with a bit of scale on the mushroom. But I'm not likely to need to do it again for a while.
    14,666
    Quote Originally Posted by Jonathon View Post
    If it looks like this (3+mm thick stalagmites in places), then you need to descale. A few bits here and there makes me inclined to exercise caution. I gave this one an 8/10 and this happened in 3 years.
    Good filtration will keep you to a 1 or 2 in the same period for a descale at intervals of at least a few years.
    Apr 2010
    558
    Hmm, maybe I jumped the gun a little. I'd say my mushroom was 70% clear, just spots of scale dotted around on it, after about 18 months using Brita jug filtered water....I need to get around to installing a C150 or similar but as you know, Northcote water is usually fairly soft.
    Sep 2008
    32
    How do you get descale broth in the boiler for a plumbed in machine. Mine has an external pump. I believe it needs water pressure to stay primed. Or, is there a special technique for drawing from a bucket?
    Cheers, Greg
    Nov 2014
    4
    Great write up, I'll be descaling my machine properly this weekend!
    May 2014
    4
    Just thought I'd add: at the boiler rinsing stage I hooked up a bike floor pump to the steam wand outlet to provide the pressure to empty the boiler. Way faster and more efficient than waiting for the boiler to heat up and be emptied several times...
    Dimal and Jackster like this.
    Jun 2011
    Adelaide
    25
    Probe wire mod
    It's a lot less fiddly disconnecting the boiler probe without taking the machine apart, I descale my VBM Jnr every 8 months this saves a lot of time.
  23. #23
    Nov 2008
    56
    Just a warning to people with a Wega Mininova. The hot water has its own heat exchanger and it makes the instructions a bit different from above. You can flush water through the steam boiler (steam wand) and flush both heat exchangers (brew head and hot water).
  24. #24
    Oct 2016
    11
    another one for WLL
  25. #25
    Dec 2016
    1
    Hi folk, new member here.
    We recently purchased a secondhand Expobar Megacrem 2 group high cup machine. Of course the place that sold it too us told us it was "in great condition" yadda yadda.
    We're getting some white particulate matter coming out of the hot water outlet, so now I'm wondering if I should descale it. Done a little bit of research and I'm figuring I can disconnect the water inline hose from the mains water, make a reservoir out of a bucket and some pipe fittings and flush some descaling agent through it.
    What do I need to be aware of here? Do I need to disconnect a water level probe on the boiler to make sure the descaling agent reaches the top of the boiler? Am I going about this the right way? Should I be doing a more involved dismantling and cleaning if I want to do the job properly?
    I'm confident around 240v electricity, and am a pretty handy fellow. Any help would be greatly appreciated, and if anyone knows where I can get my hands on a service manual for this puppy that would amazing!
    Thanks!
  26. #26
    Dec 2007
    70
    Why not store bought citric acid? Do you mean the descalers based on citric acid (I think Sunbeam uses that) - or the citric acid powder you can buy in supermarkets around the spices section? I have used the powder to descale kettles and it seems to work well without leaving much taste.
    I have quickly searched the forum without seeing other people saying why it would be bad for an HX machine.
  27. #27
    17,401
    G'day mate....
    Yes, Citric Acid does work to a point.
    It also leaches tiny amounts of copper from the brass (and copper pipes) in situ, when chlorinated water is used (tap water) which leaves the peculiar pinkish copper appearance afterwards. Only atomic levels of copper is displaced and not really a concern.
    While not a problem in itself, there are better products around that do a more efficacious job on the scale deposits and avoid the situation of loosening chunks of scale that may end up in other parts of the hydraulic circuit causing future problems and much heartache...
    MarkMarynaBris likes this.
  28. #28
    Nov 2009
    Altona, Melbourne
    1,584
    What Mal said. Mainly that the citric acid tends to dislodge chunks of dcal that the cause problems by blocking things.
    Maybe the reaction with the copper causes that behaviour I don't know, but that is less of an issue with commercial purpose developed descalers.
  29. #29
    Feb 2013
    3
    Hey all.
    I just tried descaling a p500 as per this video (https://youtu.be/yEGfyJkWSqU). The steam wand, however, still smells of descaler (everywhere else the water smells fine).
    Is there anything omitted from that video?
  30. #30
    Jun 2018
    625
    G'day mate....
    Citric applied to brass will preferentially dissolve the zinc, a process known (logically) as dezincification. Copper dissolves much more slowly so the surface layer becomes copper rich, hence the pink colour.
    Dimal and MrJack like this.
  31. #31
    Sep 2012
    76
    So i just pulled apart my Giotto cos I found some scale on the mushroom. So far i’ve removed all the pipes and disassembled the group head. There’s a bit of scale ,really not that bad. So was wondering what descaler i could use to soak the parts in a bucket? a citric based one be ok? TIA
  32. #32
    Jun 2018
    625
    Citric is fine but slow. The solubility of calcium citrate is actually quite low so the solution will saturate. Since citric is like $5 per kilo it is not worth your time to stuff around, just make enough citric to do several soaks and change the solution every hour.
    Acetic acid (vinegar) is a bit more effective but also more aggressive on the parts. Amidosulphonic acid (Sulphamic acid) is excellent but hard to buy in domestic quantities. Hydrochloric acid is the most effective of all but it will attack the parts very quickly unless you are very careful.
  33. #33
    Mar 2012
    Bathurst
    1,204
    I use straight citric acid when soaking parts. For E61 group heads and their associated plumbing, I leave it in for 24-36 hours then check.
    I find that after this time pretty much all of the scale is gone. If there were any spots that were particularly thick, it may have not eaten all the way through yet. In this case I just lightly brush away any excess that it easily removed then let soak for another few hours.
    Providing time is not a concern, I find this method easy and effective.
    matth3wh likes this.
  34. #34
    Sep 2012
    76
    Thanks for your info guys, much appreciated
  35. #35
    17,401
    I think that some of the commercial products available these days use a healthy proportion of Phosphoric Acid in combination with other chemicals (I don't know which). Used a commercial version of Bombora's Triple Action Descaler many moons ago, which uses this particular acid, to clean up an old Bezzera HX boiler. The end result was very good indeed, and fast - All internal surfaces came up as pristine afterwards...
    Dec 2007
    70
    I’d hesitate on using vinegar for a couple of reasons - for one the taste, but also as mentioned above, it is aggressive to metal. Check some of the YouTube videos on rust removal where this is tested.
    I use hydrochloric to clean the calcium off the chlorinator in my pool. A 10% solution creates a lot of fizz and gets rid of the deposits very smartly, but I would hate to think what it would do to a nice coffee machine. Last resort stuff for a machine that is almost completely blocked.
  37. #37
    Oct 2009
    Geelong
    1,164
    Thought I'd post this here.
    I just did my first descale of my Profitec Pro 500. I didn't take it apart or anything, but just did the method in the manual (dissolving descaler in, running it through group head, back flush, empty out boiler through hot water tap, wash water tank and refill with fresh water, empty boiler and refill 3-5 times to clear out descale solution).
    Am now up to my 13th time of emptying and refilling the boiler, and the water still had a slight smell. It is getting better, but it is strongest smelling out of the steam wand :s. Not sure what to do, should I not worry about it?
    I've been adding water from the hot water tap to a cup and adding some bi-carb to see if it fizzes up, and it still is fizzing up a slight bit (which shows there's still a bit of solution in there...).
    It doesn't say you shouldn't ingest the descale liquid, just to keep it out of your eyes hehe...
    Its ingredients are citric acid 10-30%, tartaric acid 1-10%, anionic surfactants <5%.
    Wondering if I should just keep draining the boiler and refilling with fresh water from this point until the smell goes (have put a lot of water through already now...) or just not worry...
  1. Visacrem 2 Group Lever Espresso Machine ( descale)
    By dazzadaz in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th September 2012, 04:17 AM
  2. How do you clean your Sunbeam machine properly?
    By Mallowkid in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st July 2011, 05:58 PM
  3. Coffee machine not working properly?
    By scottishrambo in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 19th January 2009, 02:12 PM
