Results 1 to 6 of 6
Thread: Does 18g Basket mean you SHOULD be using 18g of beans?
    Apr 2011
    27
    Title says it all really.
    I have a VST 18g (and love it), however I actually bothered weighing how much beans I was using per shot and it was closer to 20.5g. I just fill basket, lightly tap to settle grounds, flatten it off with my finger to all edges (not applying any down pressure, simply pushing the beans around), and tamp.
    I'm a fan of the 'if it ain't broke, don't fix it', and I have no problems with my shots, the pucks look just peachy, however technically, should I be adjusting my grind and using less beans per shot? If so.. huzzah, more coffee per kg!
    ~M
    Feb 2012
    Central Coast NSW
    629
    You might consider just reading this thread.
    http://coffeesnobs.com.au/brewing-eq...been-like.html
    Apr 2011
    27
    just had a read -- glad to see it's normal!
    thanks, interesting thread.
    ~M
    Apr 2012
    1
    what do you guys generally use to measure the weight? I have a set of digital scales, but its only accurate to 2g, so not all that useful. Cheap is good too
    Coffee Newbie okitoki's Avatar
    May 2013
    Perth. WA
    454
    Go to ebay and can fine small cheap ones.
    Mar 2012
    Gippsland, Vic
    145
    These cost about $7 delivered. It takes 2xAA batteries.
  1. Talk Coffee Precision basket vs VST basket
    By summercrema in forum General Coffee Related...
    Last Post: 28th June 2013, 06:40 AM
  2. Beans Beans Beans French Press, Filter or Espresso
    By summercrema in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th January 2011, 08:56 PM
  3. Grams of beans in a synesso basket
    By BaryBC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th October 2009, 07:31 AM
  4. Profile of an LM basket compared to another basket
    By speleomike in forum Brewing Equipment (non-machine specific)
    Last Post: 27th June 2008, 01:00 PM
