Page 2 of 2 FirstFirst 12
Results 51 to 73 of 73
Like Tree41Likes
Thread: Water filtering
  1. #51
    Mar 2017
    Perth, WA
    30
    System is installed and bypass set to 70%. Flow through filter tap is ok at first but reduces to a trickle within a few seconds. Did this happen to anyone else? Any clues as to how to fix it?
  2. #52
    Senior Member artman's Avatar
    Jun 2006
    2,318
    My strips are less yellow and I have left at factory setting. I also use an in tank softener cartridge in the tank on the suction hose. never had issues with scale and the kettle looks great.
    The flow isnt that great through the filter. I will time how long it takes to fill glass and let you know.
    cheers
    Coffeenooby likes this.
  3. #53
    Jun 2006
    2,318
    12 seconds to fill 330ml.
  4. #54
    Mar 2017
    Perth, WA
    30
    Thanks artman. Changed the setting to 10 and its flowing fast now. Don't know if that setting is correct though.
  5. #55
    Sep 2015
    Perth WA
    41
    Now having some health issues, I need quality drinking water at home. I am located inner city Perth and believe our water is better quality than the suburbs.
    I am looking for a under sink filter solution and need to cover these requirements:
    1. Maximum removal of chlorine, pesticides, other chemicals & impurities for drinking water.
    2. Make drinking water more alkaline.
    3. Provide quality water for my HX machine.
    I am not sure if a Brita C150 finest will meet my requirements as depending on the bypass setting, it bypasses filtering and thus won't meet number 1.
    I know it will easily meet number 3.
    I currently use bottled spring water in my HX which is a pain. Water filter suppliers can supply filters to meet 1 & 2.
    Any suggestions what I should do? Cost not an issue, but convenience is.
    Peter.
  6. #56
    Senior Member readeral's Avatar
    Jul 2015
    1,094
    Call Bombora and talk through your options.
    Dimal and Casa Espresso like this.
  7. #57
    Apr 2013
    51
    So with the Brita C150 can the filter simply be installed in-line with an existing cold water tap? I'm intending to stick one in the laundry sink cold water line, it rarely gets used so I figure I'd get the full 12 months out of the cartridge
  8. #58
    16,353
    You'd need to install a pressure limiting valve in series with the filter though, preferably downstream of an isolating valve.
    Feb 2013
    82
    Been looking on eBay and there are triple cartridge kits (sediment, carbon hardness) there with taps for under $150 (there's a 10% off deal). These are not junk. I have a dual cartridge version and it's been fine for 6 years. Just make sure it has a ceramic valve tap (I think they all might be now). These use a standard size 10" cartridge which can be very cheap, particularly if you buy them in bulk. The Brita only filters down to 10 micron. You can get cartridges down to 0.5 micron.
  10. #60
    Dec 2012
    Bridgetown Western Australia
    18
    Hi dodgy x, I have just taken your advice and grabbed the purity set from your store. Need to get away fro the hassle of filtering bottled water so I am looking forward to it arriving. cheers
    Magic_Matt and kbc like this.
  11. #61
    Dec 2012
    18
    Its a good move. I am at least using the 15l Neverfail bottles that you return and they refill, but it is an expensive PITA buying them and then running them through the Brita Maxtra filter jug
    Magic_Matt likes this.
  12. #62
    Jul 2016
    Greenwood Perth
    25
    I use a Brita jug and have tested the hardness of the filtered water. It removes most calcium with a newfilter which lasts 3 to 4 weeks with our use. We use thej jug for all drinking and for tea and coffee.
    The drawback I find with any filter like this is that the chlorine is removed which means the water tank or the bottom tank of an Aqua Pro will grow mould. I have experienced this with my Profitec 700 and with an Aqua Pro which we threw out.
    I keep the Brita jug in the fridge and make sure it is clean and free of mould when I put in a new filter.
    For info the Brita filters can be obtained from Germany or Ireland at a good price.
  13. #63
    Site Sponsor SpiceBean's Avatar
    Nov 2015
    Wentworth Falls
    46
    Hi Boggas,
    This is an interesting topic. I have been looking into this for a while now. From what I have gathered and also been taught in some recent barista training at one of Sydney's top specialty roasters is that Total Dissolved solids (TDS) should be around 150-200 (some might say 100-200). Also there are 2 very different motivations determining ideal TDS. The first motivation is to avoid calcification of your espresso machine, this drives us to use filters that remove calcium and magnesium lowering TDS. However if we make the water to soft like distilled water it will make the coffee taste bad, so its recommended to not use distilled where possible. The second motivation is to make your coffee taste the best, this might mean hardening your water slightly and increasing the calcification build up in your machine. So what to do about? First you can purchase TDS kits fairly cheaply and measure your water. Once you know what your water is then you can experiment by hardening it with magnesium and calcium (can purchase online). I recommend to experiment with brew gear like pour over, plunger, cold drip/brew to avoid potential build up in your machine. This way you can varify for yourself whether it makes a difference or not. In your case Boggas you said your watder is hard, so its easy for you make two brews, one with hard town water and one with distilled and a starting point, then taste for verification on flavour variations.
    Mike K
  14. #64
    Jul 2015
    1,094
    Quote Originally Posted by Johnd80 View Post
    A brita jug is a suitable short term solution, but a few things to consider:
    1. I was getting tiny bits of carbon floating in my water tank from the Brita jug filter. Even if being very careful to flush the filter as instructed, you'll still get carbon.
    2. Adding up the cost of buying filters every 4 weeks, buying a bigger plumbed Brita Purity option is essentially the same price once you've paid for the head unit and PLV.
    matth3wh likes this.
  15. #65
    Senior Member rusty888's Avatar
    Nov 2014
    199
    After getting my new machine this has come up. Im currently in my investment property for a year so cant and dont want to drill holes or plumb the machine in.
    I am looking at my options given that I will be running the water of the tank for the forseeable future.
    As I am in perth and the water is notoriously terrible, what options are there.
    1. Bottled water by the 10L (I read somewhere that spring water is not good though) Noticed a Pureau brand of water that has a lot of removing of the minerals as such. Is this composition good?
    Typical Analysis in milligrams per litre (p.p.m) mg/L
    Sodium 0mg/L
    Chlorides 0mg/L
    Calcium 0mg/L
    Potassium 0mg/L
    Bicarbonates 0mg/L
    Sulphates 0mg/L
    Nitrates 0mg/L
    Magnesium 0mg/L
    2. Fit a C150 finest to the laundry tap we hard use and go from there. I guess I will need a pressure limiting valve but asking one retailer they said that maybe the C150 finest wont be suitable for Perth water.
    Any advice would be greatly appreciated. I dont mind fitting a filter to the laundry tap as both my partner and I drink a lot of water and prefer filtered so will get good value from that and can ditch the brita jub which is PITA.
  16. #66
    May 2007
    Perth, Western Australia
    3,145
    Definitely need a water softening resin filter for Perth water.
  17. #67
    Nov 2014
    199
    Quote Originally Posted by greenman View Post
    Any direction of ones that could work.
  18. #68
    Jul 2008
    Gold Coast
    110
    This may be a silly question, but everything I read about the C150 seems to be focussed on vending machines and coffee machines. How is it for normal drinking water however? I mean, if Iím to get one Iíd like to use it to fill the tank in my machine, but also for my family to fill their water bottles at the start of the day, and to pour a fresh glass of clean water. I donít see anything regarding that.
  19. #69
    Nov 2017
    Maddington, Perth. Wa
    639
    I like the idea of plumbing the filter into the laundry. I was going to do it onto the outside tap- just out the side door.
    Also i was considering plumbing in my tanked machine with a 1/4 push fit float setup. Easy to set up...
    Also, im not sure perth has notoriously hard water now. We have a pretty big desalinator online now, so i think our water might be softer than before.
    Do we need to use the hardness strips, or can we use a tds pen style sampler?
  20. #70
    Feb 2014
    Adelaide, S.A.
    214
    Hi folks
    I reckon just plumb in an appropriate filter to your laundry tap or where ever and descale your machine when advised to....Change the filter/s when necessary and that's it..
    Having said that...PSI water filters in Tasmania are great..About ten years ago I fitted a 20" twin whole of house water filter set up plus a small 9"twin with UV setup from the rainwater tank and pumped it from the tank to the fridge and rainwater tap inside...They were very good... You need to order online...
    I had to get a plumber in to install a water pressure limiting valve after the water meter and before the 20" set up which cost about $100.00...A good investment to stop any surges or excess pressure blowing the filters...
    I'm about to install a similar regime in my current house...There is nothing like having the whole of the house water filtered..Many other benefits....
    Cheers.
    Last edited by Javaphile; 14th March 2018 at 12:04 PM. Reason: Commercial link(s) removed
  21. #71
    Sep 2013
    95
    My mate bought from psi like 5 years ago and was happy.
    I want to buy a 3 way mixer because I dont valve a hold in my sink for a normal filtered water tap.
    Any suggestions there ?
    I have nothing setup right now so wanting to buy a package of possible for under sink and a 3 way faucet. Seems that the coffee stores dont sell the faucets like this
  22. #72
    Sep 2013
    95
    So I just jumped on the band wagon and got a c50 and plumbed it myself.
    Just wanted to know if anyone in Sydney has the c50 or 150 and what your bypass setting is at ?
  23. #73
    Sep 2013
    95
    Ok so besides this thread being dead I'm updating it for future people to find and hopefully use.
    So the Quell C series used in Sydney will probably need a 70% bypass as that's what I've found after getting a very accurate test done by a friend of mine pool shop. They have an electronic water tester.
    The hardness read at 50ppm but the brita table uses DH. Found a table online and did the conversion to 2.8dh which isnt even on the table as it's so low so 70% is the closest to the lowest on the brita chart which was 4dh.
