Results 1 to 10 of 10
Like Tree11Likes
  • 2 Post By Yelta
  • 1 Post By level3ninja
  • 3 Post By Dimal
  • 2 Post By readeral
  • 2 Post By Hoggers
  • 1 Post By Magic_Matt
Thread: Tamper question
    May 2016
    Abbotsbury
    72
    Tamper question
    Hello
    I hope this is the correct forum for this question.
    This is possibly a silly question but I was wondering if a 54.4mm tamper would be a good fit for a 55mm basket ?
    My instinct tells me yes but thought no harm in asking.. Am I also correct in guessing that the tamper will always be slightly smaller than the basket it is going into or does it not work this way.
    Reason I ask is that the tamper I am looking at does not have a 55mm option only the above mentioned 54.4mm.
    Your help and thoughts are always welcome and appreciated.
    Alastair
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,724
    G'Day Alastair,
    54.4 will be pretty darned close, 55 mm tamper in a 55 mm basket may not fit, if it did would be very tight and prone to jamming.
    "Am I also correct in guessing that the tamper will always be slightly smaller than the basket it is going into" yes.
    Magic_Matt and Stan like this.
    May 2016
    Abbotsbury
    72
    Cheers mate... and I am sure you meant a 54.4 into a 55 not the 58.4 into a 58 - that really would be a close fit
    Nov 2013
    Casula, NSW
    587
    You always want enough clearance so that a couple of grinds between the side of the tamper and basket walls won't make it get stuck. Whether this is achieved through a non-straight side of tamper design (ala PergTamp) or a regular tamper that is a bit smaller than the basket doesn't really matter. You don't want the tamper to be too much smaller than the basket or you might get channeling.
    The trick is to go as close to the edges as possible without the tamper getting stuck. 54.4mm sounds about right, but I wouldn't go any bigger! Maybe even smaller if you use oily beans etc that'll stick.
    Magic_Matt likes this.
    Jun 2009
    Moonta SA.
    5,724
    Quote Originally Posted by Hoggers View Post
    Whoops! correction made.
    15,798
    A trap that is easy to fall in to though, is, where are you measuring the ID of the Filter basket?
    Given that 'most' baskets' walls are slightly tapered, you really need to measure the ID at the distance from the lip of the basket, that the tamped coffee puck will be. Typically, this will be in the range of 6-8mm from the top, such that sufficient clearance remains between the tamped puck and the bottom of the Group Shower-screen.
    Magic_Matt, readeral and zeezaw like this.
    Senior Member readeral's Avatar
    Jul 2015
    1,080
    Good tip Mal
    Dimal and Magic_Matt like this.
    May 2016
    Abbotsbury
    72
    Cheers all and thanks for the responses... all a great help.
    In the process of getting the gear set up ATOM grinder paired with a (yet to be purchased) Izzo Valexia leva
    Looking forward to many many enjoyable cups of liquid gold
    Dimal and matth3wh like this.
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    817
    Hi Alistair. Sounds like you will have a great gold mining combo! Enjoy.
    I'm keen for some Atom goodness myself soon.
    Sep 2007
    Northlandia
    1,332
    Quote Originally Posted by readeral View Post
    Good tip Mal
    Yep - have seen a couple of office setups where the tamper bottomed out well before it achieved a proper tamp. Scary thing is, they were used daily by dozens of people, and one was in a company involved in speciality coffee! 😲
    Dimal likes this.
