Results 1 to 13 of 13
Like Tree14Likes
  • 1 Post By mwcalder05
  • 2 Post By Magic_Matt
  • 1 Post By MrDerrickC
  • 5 Post By Dimal
  • 1 Post By Yelta
  • 1 Post By simonsk8r
  • 2 Post By Barry O'Speedwagon
Thread: Adjusting the grinder - how much do I then discard?
    Dec 2006
    Warragul, Vic
    442
    You're dialling in your new bean and you've adjusted your grinder and you then need to discard some beans still at the old setting. How much do you discard? 5gms? 10gms? 18gms? I have a Macap M4D and after all these years I've never worked out exactly how much I should discard. I know this is sort of a retention question. Anyway, what's the general consensus?
    Senior Member mwcalder05's Avatar
    Jan 2012
    Sunshine Coast
    437
    Really depends on the grinder. For smaller, domestic types, I would say about a shot's worth after changing the grind. When I'm using a Robur, I dump about 3 shots before using the fresh grind size.
    Magic_Matt likes this.
    Dec 2006
    Warragul, Vic
    442
    Quote Originally Posted by mwcalder05 View Post
    That's why I mentioned the Macap M4D. Perhaps I should have placed this thread in the grinder section.
    Sep 2007
    Northlandia
    1,334
    Simple way to test - switch between two visibly different roasts (maybe sacrifice some filter roast beans), grind until you can see the change in colour, retaining the grounds, then weigh the retained stuff.
    My ECM with antistatic grid removed retains a negligible amount, at a guess less than 1g and certainly under 2. I might run this experiment just out of interest, but it's low enough that if I'm switching between blends for milk coffee I don't bother to grind through the last bit of the old blend.
    barri and kbc like this.
    Jun 2009
    98
    I found with my M4D it was around 10g to clear it out. I programmed the single shot for around 4 seconds for the purposes of clearing out stale grinds also.
    barri likes this.
    Jul 2012
    628
    With Mythos one and fresh beans i have tried purging and without purge and there is no difference. Towards the end of the bag i find a taste advantage to purging around 4grams, but no extra advantage from purging more
    15,798
    Quote Originally Posted by barri View Post
    I never worry about it at all...
    So long as both batches of beans are considered to be still fresh, I've never experienced a bad result by just pouring the new batch of beans on top of the old and going for it. In fact, I've experienced some very interesting and delightful outcomes that have resulted in my experimenting with blends to provide the same, or similar, result in the cup from that experience...
    barri, Brewster, flynnaus and 2 others like this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,730
    Nor do I, I single dose and clean up after each shot, there is bugger all left in the grinder to worry about.
    Dimal likes this.
    Oct 2009
    Geelong
    620
    Same Yelta, I dose only what i use and have a cheap vacuum next to my grinder to get (hopefully) most of dem excess grinds!
    coffe4me2 likes this.
    Dec 2011
    PRL
    2,310
    I give the M4D a quick (1 second or so) blast before the 1st shot in the morning, but otherwise don't bother about it.
    Dimal and coffe4me2 like this.
    Senior Member readeral's Avatar
    Jul 2015
    1,080
    It depends on your basket size I reckon. 15g basket would be more noticeable than a 22g basket. I always spit out 1.5s worth before making the first coffee of the session.
    Sep 2007
    Northlandia
    1,334
    With some strategic mods, I have retention down to less than the minimum grind volume on both of my grinders (ECM V-Titan and Mazzer Kony-E).
    Site Sponsor SpiceBean's Avatar
    Nov 2015
    Wentworth Falls
    46
    Hi Barri,
    Its really just clearing out whats in the burrs and the ejection tube, so really just half a portafilter should be plenty for your grinder.
    Mike K
