Results 1 to 13 of 13
Thread: Question for owners of sunbeam em6910 and em7000 (portafilter)
    Aug 2015
    Sunshine Coast
    88
    Howdy fam
    I would like to make a bottomless portafilter as an owner of the em7000.
    Can you owners of both please confirm with be that the em6910 portafilter would fit the em7000?
    Appreciate it guys!
    Nov 2013
    Casula, NSW
    582
    I don't own one, but I have converted a number of portafilters for various CSs, and one of them was a 6910 portafilter for the owner of a 7000, he said it worked well and fit the same as the 7000 portafilter.
    Aug 2015
    Sunshine Coast
    88
    Thanks my friend
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,664
    It's the old 6900 portafilters that aren't compatible I believe.
    Aug 2015
    Sunshine Coast
    88
    Hey mate. What mm should I use for a 58mm? Like 56mm do you reckon?
    Nov 2013
    Casula, NSW
    582
    Do you mean holesaw size? I use a 57mm for the 6910s and then some tiny flap discs in a drill to smooth it down.
    Aug 2015
    Sunshine Coast
    88
    Thanks appreciate it.
    I was planning to send it to my dad to drill but he doesn't have bits big enough
    I have 2 questions
    1. Is there a budget drill bit you'd recommend?
    2. What professional should I go to to get it done? Like an engineer?
    Thanks for your help!
    Nov 2013
    Casula, NSW
    582
    Send it to me if you like. You pay postage both ways and I'll do the rest for free. There's some photos here of the last 6910 one I did: Portafiller naked conversions
    In answer to your question I would never recommend a budget drill bit. Drill bits and cutting discs on grinders etc are things I never cheap out on. I think the one I'm using at the moment is a Lenox from Bunnings.
    And anywhere with a metal lathe with a stock large enough to take the head of the portafilter (which should be most lathes as the handle unscrews) should be able to do a very clean job for you.
    Aug 2015
    Sunshine Coast
    88
    I'll shoot you a PM Thanks!
    Aug 2013
    Rockingham W.A.
    973
    Quote Originally Posted by science-teacher View Post
    Howdy fam
    Appreciate it guys!
    G'day science-teacher
    1) Yep - the 6910 and 7000 p/fs fit each other.
    2) The early 6910 p/f is brass - OK for a good holesaw. The 2010(ish) and newer are stainless and need a lathe. Before you send your proposed p/f to ninja, I suggest you scratch it and check - there are plenty of places near the spouts which will be removed anyway.
    TampIt
    Rbn
    Nov 2010
    Southland NZ
    395
    And on my early 6910 p/f (brass) like Tampit says, I used a hole saw, with a battery drill so I could go slow at the job.
    Also did the same for two 51mm diameter ones for an EM 4800c, and a Breville Bar Vista.
    All for family members.
    Aug 2015
    Sunshine Coast
    88
    Hey Tampit.
    Im not sure what it is made of as it's coming from ebay.
    My circumstance is
    -I only have a crappy ozito drill handed down from my dad which it would surprise me if it could drill it (can't drill a thin metal sheet which was a washing machine drum used as a fire pit)
    -the drillbit would probably run me $30 odd for a single time use and unfortunately I'm on a tight budget
    I'm going to make the most of ninja's generosity because I can get it sent straight to him and pay postage back
    I appreciate your help and if things were different I would have loved to have done it!
    Aug 2015
    Sunshine Coast
    88
    Thanks appreciate your help
