Results 1 to 15 of 15
Like Tree11Likes
  • 1 Post By herzog
  • 1 Post By artman
  • 1 Post By DaveD
  • 5 Post By Hoggers
  • 2 Post By artman
  • 1 Post By Jono_Willmer
Thread: Portafilter handle removal... help!!
    May 2016
    Abbotsbury
    65
    Hello all.
    With the vast and collective knowledge on this forum I was wondering if anyone has removed the plastic handle from a naked portafilter (Izzo Valexia Leva) in order to replace with a timber handle.
    I have tried (rather unsuccessfully) to remove and am stuck (no pun intended) on how to get the handle to part ways with the head.
    I am trying to fit a rather beautiful handle (thanks Leon) but trying to get the original off if proving to be quite a feat. If anyone has successfully done this or has any suggestions then your words of wisdom would be greatly appreciated.
    Thanks in advance.
    Alastair
    Rbn
    Nov 2010
    Southland NZ
    396
    No idea, but the handles on a Sunbeam EM 6910 unscrew.
    I guess you have tried that though.
    But have a look here, must be possible
    Leon Wilcox Handmade Wooden Coffee Parts - Izzo Handmade Hardwood Coffee Parts
    Senior Member artman's Avatar
    Jun 2006
    2,089
    How are you securing the PF to unscrew? Have you got a decent hold/purchase? Some day to said handle in hot water to soften any adhesives.
    Is there a cap on the end? On the bezzera once the cap was removed an inner hex was exposed so you could insert large Allen key to unscrew.
    Dec 2009
    337
    They can the a bugger to remove, often bound solid with loctite on the threads.
    Is it an option to keep the original portafilter intact and pick up a naked portafilter body for the new timber handle.? Should run about $40 or so.
    Jono_Willmer likes this.
    Nov 2006
    NSW
    365
    Artman is correct, some handles have more adhesive than others, even leaving it locked in the machine for a good 1/2 hour or so, I used the machine to hold the portafilter and a rubber mat to turn the handle. Though with an after market naked I had the internal screw was so long that I couldn't get it out without cutting the plastic away from the thread.
    May 2016
    Abbotsbury
    65
    Thanks for the suggestions.. I removed the emd cap in the hope there was a screw but no luck.. there looks to be a metal shaft that runs almost the length of the handle and this in turn is secured to the head.
    I have got hold of a decent vice so will try applying a bit of heat. Planning on inserting a bar (wrapped in cloth to protect the head - the portafilters not mine). This should give me some decent leverage to try to get the bugger undone.
    It is the beautiful Wilcox handles I am trying to fit.
    I will persevere
    Jun 2006
    2,089
    You can always hack off the plastic?
    It would be killing me not being able to fit those beautiful timber handles!
    Hoggers likes this.
    Nov 2006
    NSW
    365
    Sounds like hacking may be the way, I cut mine half way down the handle right through then took the plastic and glue off bit by bit
    Nov 2013
    West Footscray, Melbourne
    175
    Hi Alastair,
    I had the same issue with my rocket portafilter handles. I got the handles off by heating the portafilter head, where it joins the handle, with a heat gun (from my corretto setup). This generated enough heat to melt the loctite glue, then it was really easy to just unscrew the handle. Just make sure to use heat proof gloves when handling the heated portafilter, and be careful not to scorch the plastic handles in case you want to keep them as backup.
    Hope it works for you as well.
    Cheers, Dave
    Hoggers likes this.
    May 2016
    Abbotsbury
    65
    Hi Dave...
    This does sound like the best way to go. I tried hacking and slowly breaking away the plastic but the handle is not going to give up easily.
    I have a heat gun (used for paint stripping) so will apply some careful heat and see what happens.
    And artman.. yes it is killing me
    Cheers all.
    Alastair
    Rbn
    Nov 2010
    Southland NZ
    396
    Please show us the end result, and also let us know where I can get a bottomless/naked P/F for my Sunbeam EM6910 for that price!
    The only ones I can find are for around AU$136.00. To convert that to NZ and put postage on it would mean around NZ$150.00 plus.
    I like my coffee in the morning, but not that much!
    Oops, did I say that!
    Aug 2013
    Rockingham W.A.
    974
    Quote Originally Posted by Hoggers View Post
    Hi Dave...
    Cheers all.
    Alastair
    I stayed out of this so far, however Penetrene is by far the best I know for things that are badly stuck. It is both waterproof and anti-corrosive into the bargain.
    It is particularly effective with brass. Example: Freeing up the C. Y. O'Connor original valves on the Perth to Kalgoorlie pipeline after 103 years underwater... the corrosion was so bad they were barely recognisable. That took three weeks.
    Just get the liquid (not the spray - they are actually different enough to make a difference) and use an eyedropper once a day. Most things free in under a week, the worst was a seized in 1941 / made in 1934 Mercedes engine purchased as a complete car in the late '90's - that took 4 weeks and then said engine spun like a top.
    TampIt
    May 2016
    Abbotsbury
    65
    Woohoo.. success.
    I pop the plastic handle bit in the vice, had heat gun at the ready and thought I will just try once more.
    Hey presto.. off she comes as easy as anything. Maybe the thought of the heat gun scared it into submission
    A lovely new Tassie Blackwood handle fitted. Thanks Leon... work workmanship is a thing of beauty and the photos do not do justice.. speaking of which here it is fitted.
    Jun 2006
    2,089
    Wow, looks fantastic.
    matth3wh and Hoggers like this.
    Nov 2006
    NSW
    365
    Woohoo.. success.
    Fantastic, glad you got there, it looks brilliant!
    Hoggers likes this.
