Results 1 to 11 of 11
Like Tree9Likes
  • 3 Post By Lovey
  • 1 Post By Dimal
  • 1 Post By Dimal
  • 3 Post By Yelta
  • 1 Post By dbun
Thread: How do you clean group head?
    Nov 2017
    2
    Question How do you clean group head?
    Hi
    I bought Sunbeam EM7000 last month. So far so good. Very impressed how easy to operate. I want to know how people clean the group head. Should I use a cleaning brush like this? https://www.coffeeparts.com.au/acces...-machine-brush
    Thanks in advance.
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    821
    G'day Annapurna,
    I use either a tea towel and/or doing a blind portafilter wiggle and I don't have a problem with ground coffee being stuck in the seal. I got one of those angled brushes and I found it to be a pain to use, but horses for courses though.
    Brewster, Dimal and mdrawde like this.
    15,800
    A couple of well timed deliberate "sneezes" will get most of the loose stuff out at the end of a session, and then it's just a quick wipe around as suggested by Lovey above.
    mdrawde likes this.
    Aug 2013
    Rockingham W.A.
    1,054
    Quote Originally Posted by Annapurna View Post
    Hi
    Thanks in advance.
    G'day Annapurna
    Both of the above posters are (almost certainly) assuming you are undoing the screw holding the showerscreens in and cleaning them thoroughly as well. I only posted this to be 100% sure, as coffee will always become lodged between the screens. The group & seal above that rarely need attention unless your technique is poor / and you allow grounds to work their way onto the seal.
    Enjoy your cuppa.
    TampIt
    PS: Annapurna is the name of one of Perth's best restaurants - unfortunately for me, Indian food is now off my menu...
    Rbn
    Nov 2010
    Southland NZ
    441
    Quote Originally Posted by Lovey View Post
    G'day Annapurna,
    I was given a tip about using the dual walled filter basket instead of the blind, seems to work well too. Just adding in second crack of useless knowledge!
    15,800
    Quote Originally Posted by TampIt View Post
    Nope...
    mdrawde likes this.
    Feb 2015
    14
    After use for the morning/afternoon, I run a clean double shot of water through, to force any coffee residue out of the double walled basket that the boss lady uses. It also unsticks any grinds from the upper screens, without me having to do any work. Mine's an EM6910.
    Then to get the coffee staining off the group heads, screens, seal and filters, every month I load the sink with almost boiling water, and add a scoop of napisan. Leave that for an hour, and the sodium percarbonate (active ingredient) will clean everything, inside and out. Afterwards, run a few empty shots through, to clean the percarbonate out of the filters.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,849
    I'm a portafilter jiggle/wiggle person, the combination of this and a weekly back flush with Cafetto EVO keeps everything sparkling.
    After, or during a session, sit the portafilter lightly in place, turn on the brew switch, lever or whatever, then when water begins to flow jiggle the portafilter from light lock to unlock rapidly for a few seconds, works even better with a blind filter.
    This is quite a good video explaining the back flush process. https://www.youtube.com/watch?v=k1Vkfj83uyg
    And here's the jiggle. https://www.youtube.com/watch?v=ZfkwW4GgAiU
    chippy, mdrawde and zeezaw like this.
    Jun 2017
    84
    blind portafilter wiggle and a brush works for me.
    When I remove the showerscreen for cleaning I will use a cloth to get in there and give everything a good wipe out. There rarely is any coffee grounds stuck up there.
    mdrawde likes this.
    Sep 2009
    211
    Goes without saying, don't over dose the filter basket with a highed dose than what will fit under the showerscreen.
    That removes probably 70 -80% of the cleaning requirement right there.
    * Search 5cent test on here
    GL
    EA
    Nov 2017
    Maddington, Perth. Wa
    375
    G'day Annapurna
    Both of the above posters are (almost certainly) assuming you are undoing the screw holding the showerscreens in and cleaning them thoroughly as well. I only posted this to be 100% sure, as coffee will always become lodged between the screens. The group & seal above that rarely need attention unless your technique is poor / and you allow grounds to work their way onto the seal...
    I just took the shower screen out of mine. Its previously been too tight to get the screw out. So tip him over and hit it with the clutch setting on the cordless drill. OMG! The garbage that came out of there!
    Clear water on the of warming flush now.
