Page 31 of 31 FirstFirst ... 21 29 30 31
Results 1,501 to 1,533 of 1533
Like Tree970Likes
Thread: Whats in my coffee roaster this week
  1. #1501
    May 2007
    Perth, Western Australia
    3,007
    It really depends on a variety of factors. I haven't tried anything too extravagant, but from what I've tried and from what I've read sometimes they can be quite difficult to roast. And yes quite often people do try to roast them a little lighter to ensure the sweetness and acidity isn't muted at all. This obviously does mean that they often only suit soft brew methods (or lever espresso).
    To get the best out of Geisha I always roast them lightly for filter brewing taking them into a very vigorous first crack and then rapidly cooling, high end cafes use the lighter roasts in their pressure profiling machines to produce espresso based drinks. The longer into the roast you go the more the acidity and florals are muted, still an amazing coffee but not what a lot of people are looking for when paying the high end prices for these amazing beans.
    Natural Geisha's need a little bit more TLC than the washed variety which are not too difficult to roast, it's a little daunting first-up though!!!
    matth3wh and Janus like this.
  2. #1502
    Jul 2016
    Inner West Sydney
    97
    120g Costa Rica La Lapa:
    102g roasted weight / 15% weight loss.
    I'm unsure if i should try pushing the heat a bit more after first crack? I'm getting FC around 192c on the heatsnob, this time I dumped the beans into the cooling tray at about 209, so roughly 4 minutes and 17c from FC.
    Don't think i've hit 2ndC yet on any roasts, from what i can find online it should be around 30c higher than first, so 222 adjusted for my readings, seems like i have a fair bit more room on the upside with temperatures, maybe i'm leveling off the temp too quickly?
    Dimal likes this.
  3. #1503
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,453
    Rwanda Buf Remera Gitantu.
    Dimal and Janus like this.
  4. #1504
    Jul 2016
    Inner West Sydney
    97
    LeroyC, do you use tapatalk on your phone, is that how the photos you post come up full size in the thread?
  5. #1505
    Sep 2013
    1,453
    Quote Originally Posted by Janus View Post
    Yeah I use Tapatalk. When you insert an image into a post Tapatalk asks you if you it full size or reduced size. If you haven't already resized the image sometimes full resolution is too big so I pick the 'medium' resolution in this case. Normally I've already cropped the image and I'm able to choose 'best' to give a good size, high res image. Tapatalk is pretty good for image hosting. It's not perfect as apparently some people that run certain ad blocking software on some browsers can't see the images, but overall it's not bad. Certainly not going to run into any Photobucket type problems.
  6. #1506
    May 2007
    3,007
    That roast looks pretty good to me, it is hard to compare roast temperatures with other peoples roasters and set-ups. I reach the start of first crack at around 198-200C, the start of second crack is usually 16-17C after that, which I very rarely venture that far! You get plenty of smoke nearing second crack, use your sampler to keep an eye on smoke and colour change.
    Janus likes this.
  7. #1507
    Jul 2016
    Inner West Sydney
    97
    Would it generally be fair to approach coffee' which are known to have their best flavours in the lighter acidic/floral ranges with a more aggressive heat profile first up (assuming consistent sizing), coasting from first crack to wherever you can pull them with a good balance of lower acidity while still retaining the floral aspects? For Coffee' where you're looking for more of the spice/chocolates style in the darker roasts, a bit longer time to FC and easing through to a darker roast?
    Seems to me that higher heat/faster progression to first crack results in a better aroma from the coffee straight off the roaster, unsure if this translates to better flavour in the cup.
    If the beans are not sized, then a slower approach is needed to ensure an even roast, but without sizing to consider, is the above something people with more experience than me would agree with? (i know i'm generalizing).
    Wondering if the picture i'm building from my limited roasting experience with heat and fan control is accurate, i still don't have any idea of how to approach a bean i haven't roasted before, i guess i need to start taking notes on density of beans and this will at least give me an idea of where to start in the range of load temperatures, and how much heat the beans will need.
    Good fun, Zambia Terranova was a nice drop this morning.
    Looking forward to picking up my 10kg Beanbay delivery this arvo. Feel like i have a long way to go before i feel like i'm able to get the most out of the beans, at the moment it's dumb luck either way.
    greenman likes this.
  8. #1508
    Oct 2009
    Geelong
    314
    Would it be a fair generally to approach coffee' which are known to have their best flavours in the lighter acidic/floral ranges with a more aggressive heat profile first up (assuming consistent sizing), coasting from first crack to wherever you can pull them with a good balance of lower acidity while still retaining the floral aspects? For Coffee' where you're looking for more of the spice/chocolates style in the darker roasts, a bit longer time to FC and easing through to a darker roast?
    Am also wondering this myself! Is that a good general way to approach roasting?
    (And in saying that, in relation to a Behmor 1600 original, a P1/P2 for the first style of a more aggressive roast, and P3/P4/P5 for the latter style of slower gentler roast? Still wrapping my head around all this haha... great question!)
  9. #1509
    May 2007
    3,007
    This article from Sweet Marias should help Janus!!
    "High grown washed Central American coffees are practically the control coffee when it comes to roasting, the coffees that roast just like they should. They take the heat up front, change color evenly, charge into 1st Crack with gusto and with a definitive finish. On top of all that, they are perhaps the most versatile as far as roast level and roast development, with a plenty of exciting and intensely sweet characteristics expressed from City to Full City+. They also have a lot of room to move the characteristics across the palate and create a 3 dimensional profile.
    The number one fundamental of washed Centrals in my mind is sweetness and the way that you can present the whole range of development of that sweetness. Some washed South American coffees also share this trait and you can include them here, especially Colombians. African coffees can have the vibrant and exotic fruit and floral attributes, and Indonesian and Pulped Natural coffees have the more rustic type of sweetness, but Washed Centrals can be deeply and expressively sweet in a truly remarkable way.
    Lighter roasts without that much sugar development show more of the malty sweetness, but that malty sweetness can also express itself as graham cracker or wafer cookie. Developing the roast a little more moves you into the intense candy-like sweetness, followed by the more fruited sweetness like that found in cherries and other stone fruits, unique fruitiness from citric and malic fruitiness. Continuing to develop the roast leads to a fruity chocolate sweetness and then mild bitterness from caramelization expresses a more dark cocoa character with some vanilla.
    This is the sweetness development path of most coffees, but I feel like Washed Centrals showcase this development in the clearest possible way. And of course Washed Centrals can show floral and more exotic fruit notes, but it is this sweetness that is integral. The other side of that coin is balance. In order to best express the sweetness of a Washed Central, you also want to develop the roast so that there is as much balance between the acidity and mouthfeel as possible. That balance best showcases the clarity in a well sorted and processed coffee, which in turn allows the sweetness to be the star of the show. Because the acidity can be so brilliant and crystal clear there is always a temptation to roast the coffee to highlight that, but it can be just as brilliant if the roast is used to highlight and promote sweetness."
    shewey, chippy, Janus and 1 others like this.
  10. #1510
    Jul 2016
    Inner West Sydney
    97
    Thanks Greenman.
    Just watched a video by a guy Diedrich who's brother makes the roasters, he spent a bit of time in the later part describing how to roast different types of beans to get the best out of them.
    https://youtu.be/1_puhTRiOgk
    Lot of waffle to get through to the guts, might want to skip ahead.
    There's another guy on youtube N3 coffee roasters, who does some good videos getting into the nuts and bolts of how to develop the roast profile.
    Will keep at it - 10kg of beanbay beans just arrived, looking forward to roasting some Aceh beans this evening.
    greenman and shewey like this.
  11. #1511
    Jul 2016
    Inner West Sydney
    97
    The Zambia terranova i roasted about 5 days ago is probably the most flavorsome coffee i've roasted in the drum to date, has that nice spice and chocolate flavour. Similar to the flavours i've been enjoying at this Indonesian coffee roaster on the way to work.
    Dumb luck strikes again!
    greenman and LeroyC like this.
  12. #1512
    Jul 2016
    Inner West Sydney
    97
    Roasted the Aceh and Sulawesi from beanbay tonight. Tried to follow Andy's roasting tips, easy heat on the Aceh, longer roast 11 min to first crack, dropped into cooling tray at 15. Sulawesi more heat up front, think I got what they call "facing" was more apparent prior to bean development, some beans on the flat part looked very dark and mottled, could have been burnt. Dropped them a touch early, was aiming for CS8/9.
    Proof will be in the cup.
    Sulawesi:
    See how the Sulawesi goes after 4-5 days, reckon i singed them though, and they look pretty uneven. Next time will try 5-10c lower charge temp, and let them absorb some of the drum heat before turning the heat up half way to turnaround.
    The Aceh i tried for a slower heat curve to allow the different sizings to equalise as suggested, probably went a bit slow though at 15.5 min roast time and nearly 12 min to first crack (i marked first crack 30-60 seconds late). Note the heatsnob doesn't show accurate air temp, it was 210 on the regular thermometer, the face plate seems to draw a lot of heat when the drum isn't charged with beans for the first roast.
  13. #1513
    Sep 2013
    1,453
    Couple of batches yesterday. Had another go on the PNG Ulya A. The first batch a couple of weeks ago was a complete failure as I didn't manage to tame the acidity at all. I slowed the roast down a bit this time, but still achieved the same weight loss so hopefully it's a better result. They look ok anyway.
    Then I did another batch of Monsoon Malabar, which has come up looking pretty good. I ended up roasting them for a bit longer than the first batch unintentionally so it'll be interesting to see if there's much difference. External appearance and weight loss are virtually the same so I'm not sure what that means. I guess I'll find out in 2-3 weeks! Haha!
    Dimal likes this.
  14. #1514
    Oct 2009
    Geelong
    314
    Yeah I've had that sort of result too, roasting with pretty much the exact same variables, profile and cutoff point, yet a different weight loss in the end... I'm wondering what that means too... :S. I guess maybe looking at the weight lost at the end isn't as important as I thought?
  15. #1515
    Sep 2013
    1,453
    Quote Originally Posted by simonsk8r View Post
    It's somewhat important, but only to an extent. If you roast two batches of the same coffee back to back following the same profile you should get very close as not much will have changed. But if for example you roast the last batch of something today then in 3 or 4 months time buy another bag from your supplier you're unlikely to achieve the same moisture loss by following the same profile. The main reasons for this will be that the ambient environmental conditions and the moisture content of the green coffee will be different.
  16. #1516
    Oct 2009
    Geelong
    314
    Ah makes sense, must have been something that had changed then as it was the same bag... cheers Leroy
  17. #1517
    Sep 2013
    1,453
    Final batch for the week. Colombian Swiss Water Decaf.
  18. #1518
    Jul 2016
    Inner West Sydney
    97
    Wow, they come up dark don't they! I'd read the colour of decaf is something to be careful of, do you just roast to a certain temperature then?
    how does the decaf go for flavour, does it still need to rest?
  19. #1519
    Nov 2006
    1,078
    Decaff needs to rest in the same way.
    Its a nice looking roast there, i have not roasted Decaf for a long time but i used to find that you had to watch it more closely due to the already different colour of the beans in general
  20. #1520
    Sep 2013
    1,453
    Yes the physical appearance of most Decaf coffee is noticeably different to coffees containing caffeine. The above roast is the equivalent of a medium roast so you can see how colour could be misleading as an indicator for roast level. I don't actually use colour to make any decisions on how to manage a roast. My usual approach is to work out how I want to get to first crack then base everything around the time and temp that first crack occurs from which I make a final decision on development time and a finishing time. I don't completely ignore colour but it's more of a safety net than a high priority.
    The Colombian Swiss Water Decaf that I get now is a stunning coffee. It's a very nice coffee in its own right and isn't just 'not bad for a decaf'. It has the typical sweetness that you find in many Colombian coffees and is versatile enough that I use it for single origin espresso, in blends, with or without milk and even in my Aeropress. It's a touch on the mild side as an Aeropress, but still very enjoyable.
    simonsk8r and Janus like this.
  21. #1521
    Jul 2016
    Inner West Sydney
    97
    Have had an aversion to decaf, probably need to try some out. Too much caffeine these days.
    shewey likes this.
  22. #1522
    Aug 2008
    Millthorpe NSW
    1,835
    You need to try Andy's Decaf WOW. It is certainly not a step down - in fact personally I think it is some of the best flavoured coffee around! Wish I could discover the secret of his secret blend FWIW I roast Decaf with the same profile as most of my 'general' beans, but drop them 3-4 earlier than I would with non-decaf. They still appear darker at this level than their siblings, but that roast depth seems to work best flavourwise.
    Cheers Matt
    artman, Dimal and Janus like this.
  23. #1523
    Sep 2013
    1,453
    Threw a batch of Colombia ASPRO Timana through yesterday. Seemed to go ok, but I'll never know as I gave it away.
    Today's batch was probably just the 4th or 5th time I've done the full 450g batch. I used a coffee I know well, the Brazilian Rose Diamond. All went ok. It's probably a bit darker and more developed than I'd really like, but I'd prefer that to it being underdeveloped and useless. At least this was it might not be much good for filter, but will make a cracking espresso.
    Dimal, greenman and Janus like this.
  24. #1524
    May 2007
    3,007
    Saturday arvo roasting session:-
    250g Panama Hartmann Estate Beni Geisha for filter
    400g Burundi Nitita Gishubi for filter
    1800g Fruitcake Blend--equal parts PNG, Sulawesi Blue and Gambella Sundried for espresso, taken to just prior to second crack.
    1800g Spacefruit Blend--El Salvador Finca Dorinda 450g, Peru Ceja da Selva500g, Sulawesi Blue 450g and 400g Ethioipian Geyusu Natural for espresso, prior to second crack.
  25. #1525
    Mar 2017
    42
    hi
    trying to work with the ethopian ardi right now. i'm using a behmor plus.
    i did some a while ago and have just started on it. i think i burnt the crap out of it. no sweetness in the taste. i would say its more like a wood taste if anything.
    so yesterday i got out the roaster and thought i had best try and do some much lighter versions. some dude on youtube was offering roasting advice and i figured i'd try emulating what he was doing.
    he is a manual advocate. so i'm sticking 450 g in, then straight onto manual model and using p5.
    i had the err 2 a few times as temp exceeded 165 degrees (b button temp). however i was able to kick the roast off again straight away and got better at keeping the temp below what seems to be a cutoff for the machine.
    i pulled one batch just past FC and a second batch just at FC. one batch removed from roaster whilst still hot to cool. another left in roaster to go thru cool cycle.
    i've ordered the heat snob so i can log temperature profiles. but am i on the right track here? i guess each 450 g roast takes around 20 min or so. i go full heat (but manage so i stay under err 2 threshold) then less heat at FC (or thereabouts briefly), then onto cool.
    here are some photos of the roasted beans.
    ok so this is the one that tastes burnt (probably pressed cool when it had gone thru SC)
    this one was stopped in error (err 2 before i realised that wasn't an end like err 7 is)
    this one is pulled out of machine after first crack
    this one is left in machine but stopped after end of FC
    this one removed from machine after FC
    i'm a real noob so any ideas for improvement i am all ears. the one i am using right now is maybe 8 days rested. smells great. but tastes like wood.
  26. #1526
    Sep 2013
    1,453
    Wooaah!! I don't know where to start really. Firstly I highly recommend roasting smaller batches while you're learning, 200g is perfect. And learn the auto profiles before you start playing with manual settings. I don't know the Ardi, is it a washed or natural process? If it's a natural then P5 manual is way to much heat for it. If it's a washed then it might be ok, but it's still hotter than I'd go.
    A bit more info would allow us to help you more - time to FC for each roast and the moisture loss from each batch for starters. Until then I highly recommend you do lots of reading. Start with the Behmor roasting approaches thread here in CS then maybe look at something like Sweet Maria's.
    Dimal likes this.
  27. #1527
    Jul 2016
    Inner West Sydney
    97
    Aceh Danau Indo:
    Still hard to get a good rate of rise, these beans Andy recommends starting gently due to inconsistent sizing, however if I go low on the heat early it's difficult to get them moving, will need to keep working on them.
    Yirg special prep, first roast of these. They took off on me a bit, temp increased much faster than the Aceh beans.
  28. #1528
    Jul 2016
    Inner West Sydney
    97
    PNG Wahgi - nice bean easy to roast.
    Struggling with temp monitoring a bit, might pick up a 2nd heatsnob for AT, and guess I need to start noting the temperature setting during the roast to allow for accurate roast reproduction.
    Watching YouTube videos of professional roasters talking about how they will dial a roast in to within 5 seconds of pulling the beans to get best flavour. I'm still bumbling around in the dark, it's fun though
    greenman and simonsk8r like this.
  29. #1529
    Mar 2017
    42
    thanks for the feedback LeroyC. i'll particularly look up those references.
    LeroyC likes this.
  30. #1530
    Jul 2016
    Inner West Sydney
    97
    Think i'm starting to get a feel for the type of treatment beans need for development. A denser seed will need heat off and fan on full sometimes before first crack even starts, to allow for a slower rise in temperature after first crack to get post first crack development, ie. take a long time to slow down.
    Lighter beans like the Yirg where you can see how rapidly the rate of temperature rise is arrested after first crack (when you drop the heater power) require some maintained heat to push them through towards second crack. The beans which need additional temp to keep moving after first crack are usually the lighter less dense type, and they're usually a lot easier to get moving at the start of the roast, after temps equalize following loading.
    There's a definite benefit in measuring density before roasting to give a rough guide to the type of roast profile the beans will need, and the temp needed at loading. The beans are starting to show me how they need to be roasted in a way (ie. you can't push a really dense bean to get a faster rate of temperature rise as the temperature you need to apply will result in scorching, a bean of lower density however is going to be easier to control, so long as you are able to perform minor power adjustments in temp and fan to produce whatever profile you think will fit them).
    Unsized beans offer up another level of complexity, the Aceh Danau for instance roast like a denser bean, and due to the large size variation you need to go easy on them up front to avoid an uneven roast, but the flip side of the coin is the density makes it difficult to get first crack within a time frame that highlights the aromatics in the roast, they appear better at darker roasts though, the spice/earthiness of them seems best expressed in the darker roasts with the perceived sweetness/lower acidity.
    Good fun, loving this roaster, and also loving some pour overs in addition to milk based espresso. I'll leave straight up espresso for further down the track, pretty sure my palate needs a lot more coffee tasting before i can enjoy short black (even though i've loved drinking them in italy - Rome they are almost sweet! - i imagine their roasts not much good in milk based though.)
    Excited with the recent Beanbay order, we are getting definite clear varying flavours from the beans, and i'm getting the idea of how depth and development of roast is used to balance the characteristics of the bean.
    Of course i'm still a massive noob, so happy to be corrected or offered advice from more experienced folks.
    Stoked
  31. #1531
    Oct 2009
    Geelong
    314
    Great post Janus and great to hear!
    Realised I had some Kenya AA beans leftover that I'd bought about two years ago, so thought I'd finish those off, roasted them up this morning.
    Was only 245g left, Behmor setting 1lb P2A, FC at 9:20, rolling at 9:45, end of FC 11:15, pulled at 12:45, moisture loss of 15.71%.
    Fair few beans looked a little mottled after the roast.. but will see how they turned up!
    shewey and Janus like this.
  32. #1532
    Jul 2016
    Inner West Sydney
    97
    Sulawesi roasted again, loaded at about 10c lower to avoid what I thought was scorching last time (wife gave beans to a friend so I didn't get to try them after resting). These beans sure can take a lot of heat, tried to keep the heat on them through first crack, they had 4 minutes after first crack, lowered slightly at first crack
    but they're still not as dark as if wanted.
    Maybe a lesson in coloring not always representing roast depth?
    As always will look forward to proof in the pudding.
    Was going to roast up another batch of Yirg darker than last time, ran out of time.
    Edit: they look darker than I thought actually, maybe it was sufficient heat. I've never gone French roast level maybe I should do one with some older beans just for reference.
    matth3wh and shewey like this.
  33. #1533
    Jul 2016
    Inner West Sydney
    97
    Behmor Coffee Roaster
    Another roast of the Yirg last night, realised with the Quest i can open the rear hatch/cooling area which stops the fan from sucking air out of the drum (on the minimum fan setting it still pulls air, there's no "off" option), tried this to get more heat into the roast for drying, seemed to work. On the darker line which was last night's roast, following rolling first crack the roast nearly stalls and then I overcompensate increasing the heater power, and had to dump the beans into the cooling tray earlier than i wanted. Bit tricky to keep the heat rising in a controlled manner with the lower density beans, is a good learning experience on fine tuning the rate of rise with heat and fan.
  1. Roasters Week NEXT WEEK 15-19th of March 2010
    By beanflying in forum General Coffee Related...
    Last Post: 17th March 2010, 04:25 PM
  2. Your coffee week
    By madpierre06 in forum General Coffee Related...
    Last Post: 17th March 2010, 12:28 PM
  3. A Week Without Coffee (or tea)
    By gregpullman in forum General Coffee Related...
    Last Post: 23rd September 2009, 09:23 PM
  4. Replies: 0
    Last Post: 27th March 2009, 03:37 AM
