Page 32 of 37 FirstFirst ... 22 30 31 32 33 34 ... LastLast
Results 1,551 to 1,600 of 1831
Like Tree1358Likes
Thread: Whats in my coffee roaster this week
  1. #1551
    Jul 2016
    Inner West Sydney
    193
    I've got the citrus notes back in the Yirg with a faster roast time, the Sulawesi Blue I'm not having a lot of success with, tastes ok but nothing special. Would be good to do a tasting class to learn how to differentiate which flavours might be associated with poor extraction/espresso making, and those related to roasting issues. Only 3rd day in however would not expect drastic changes in flavour from now to 1 week after roasting? Time will tell.
    Will try mucking around a bit with the curve, also been a week since I cleaned the Gaggia, maybe that's it. So many variables, can see why people go a bit crazy on high end equipment to get as much control over them as possible.
    greenman likes this.
  2. #1552
    Aug 2008
    Millthorpe NSW
    1,911
    Sulawesi is a great bean, but FWIW I think it is better in a Mocha Java type blend than as a SO.
    I've found that roasting it with a normal-to-faster profile, and dropping it just before second crack works best, which is why it can be pre-roast blended so well with the likes of a 'hit-it-hard-with-the-heat' beans like Harrar or Sidamo.
    As a SO this gives a smooth, thick, earthy flavour, minimal acidity with perhaps a hint of aniseed. Very pleasant as espresso – but not so much if you like zingy, fruity spros!
    Goes quite well with Yirg too – try a 50/50 pre-roast blend
    Janus likes this.
  3. #1553
    Jul 2016
    Inner West Sydney
    193
    Have just tried my first pre roast blend in the drum roaster. Equal 1/3 Yirgacheffe, PNG Waghi and Aceh Danau Laut Tawar. See how it goes. Think I'm getting a feel for end of roast temperatures with my thermocouple and how this results with different beans in the cup. Before I was going more for time after first crack for development, but it seems like the end temp as the goal is giving better results than worrying about time after first crack. Trying not to get there too fast whilst also not stalling the roast. Temp controls on the roaster for different density beans becoming clearer too. Enjoying it. . 15.8pct moisture loss today.
    Dimal likes this.
  4. #1554
    15,664
    That batch looks very yummy Hugh....
    Have to let us know what your taste impressions are when you get to trying some.
    Jul 2016
    Inner West Sydney
    193
    Thanks Mal, yup proof will be in the pudding, will report back.
    The Yirgacheffe and Sulawesi Blue i roasted about 4 days ago are going ok, those lovely fresh roasted coffee aromas started to dissapear, to be honest the Sulawesi doesn't even smell all that good now, and the flavour is unimpressive, i'm doing something wrong with these given so many people rate them. Starting the roast with good heat, then tapering, will start mucking around with end temperatures to see if a few degrees lower end temp help the flavour come out. Yirgacheffe is great, so much zing, mixed them 50/50 this morning for our regular soy flat whites, pretty good.
    Last night's 150g 1/3 blend
    This is my last roast of the Sulawesi Blue:
    Dimal likes this.
  6. #1556
    Jul 2016
    Inner West Sydney
    193
    Pudding is ok, nothing special. Finding there's a lot of oil coming out of the Sulawesi beans already. Maybe my coffee machine needs a good clean.
    Dimal likes this.
  7. #1557
    15,664
    The flavours in the cup will probably evolve over the next week or so, if they're not gone by then of course...
    It's always interesting to track the flavour development over time.
    matth3wh likes this.
  8. #1558
    Aug 2008
    Millthorpe NSW
    1,911
    Quote Originally Posted by Janus View Post
    … i'm doing something wrong with these given so many people rate them. Starting the roast with good heat, then tapering, will start mucking around with end temperatures to see if a few degrees lower end temp help the flavour come out.
    FWIW I've always found (with most or even all beans) that starting more slowly and then ramping the heat up to first crack works better flavourwise – with something soft like the Sulawesi even more so. Might be worth a try? Too much heat early on can scorch the outside (or even the inside!
    Cheers Matt
    Dimal, greenman, Yelta and 1 others like this.
  9. #1559
    15,664
    Absolutely Matt....
    Something I learned from Willem Boot when I first started out.
    Yelta likes this.
  10. #1560
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    5,527
    Quote Originally Posted by DesigningByCoffee View Post
    Cheers Matt
    You bet Matt! with most beans I start cold and aim to hit first crack @ around 12 minutes, works well for me.
  11. #1561
    Jul 2016
    Inner West Sydney
    193
    Yelta and Dimal, are you both roasting on Corretto?
  12. #1562
    Jun 2009
    Moonta SA.
    5,527
    Yes, I am.
    Janus likes this.
  13. #1563
    15,664
    Yes for me and Matt but Matt has modified his Corretto a bit more than I've done...
    Janus likes this.
  14. #1564
    Jul 2016
    Inner West Sydney
    193
    Time for another crack at the Sulawesi Blue 120g --> 104g
    dropped them to cool another 2 degrees lower than last time, the last roast had oil on the surface after only a couple of days and didn't smell great. This roast isn't smelling great out of the roaster straight up, is a lighter colour. Went with a longer drying and then tried to ramp it.
    PNG Waghi, similar dropped to cool a little earlier, great aroma after cooling, haven't been wowed with this one yet, have really enjoyed PNG coffee in the past though so will keep trying 120g --> 104g
  15. #1565
    Jul 2016
    Inner West Sydney
    193
    Aceh Danau Laut Tawar, we love this bean in a blend. And who'd have guessed! - 120g in 104g out
    Attachment 16988Attachment 16989
    Yirgacheffe, the citrus notes are great in this one, a fairly quick roast seems to bring out the flavour well. 120g --> 104g
    Attachment 16990Attachment 16991
  16. #1566
    Apr 2010
    24
    Today I present my very first bean roast, using Colombian Volcan Galeras Especial bean from beanbay, done in a FFRZ700 baby roaster over a gas stove, so unfortunately I do not have any charts to show you guys
    The objective of my first roast is to get some experience in smell, sound and sight of the roasting process. All I know is that I will try to take it to first crack, and maintain a medium roast (I use roasted beans I bought locally as reference, i would say around CS8~CS9?)
    First crack came around 8-9min mark , after which i turned off the stove shortly. The temp. inside the roaster was around 190c during this time.
    I checked the bean's color at 11-12min mark when the first crack appears to have stopped and still found the color a bit too light.
    I turned on stove on low, and continued further 3-5min until the the beans looked similar to my reference beans . I pour out the beans on a large metal sieve and cooled it down with an aid of a large fan.
    I used 150g of greens beans and resulted in 127g of roast so 15.3% loss, sounds about right?
    a shot of the result below, as mentioned its my first roast so any comments are welcome. But personally I am very proud to call myself a home roaster now!
    greenman and Janus like this.
  17. #1567
    Jul 2016
    Inner West Sydney
    193
    Well done! Now the really fun part, drinking the coffee enjoy and let us know how it tastes.
  18. #1568
    Oct 2009
    Geelong
    566
    Quote Originally Posted by justacuppa View Post
    Ah awesome stuff! Yeah it sounds like you've got a great process going there. Have fun with it, and definitely experiment!
    Depending on your brewing method that you're roasting for, it's worth taking a bean to just on second crack or even further into it (if anything to know what it sounds like, but also to know how long after the end of first crack it occurs). So yeah ending a roast on the first snaps of SC, then another 30s before SC would occur, 1m before etc, and tasting them all and seeing what you like! Doing a few batches like this you can test them and take notes, and alter accordingly for future roasts.
    And yeah have a read through this thread for some awesome info, DesigningByCoffee's post is great! Even though it's mainly for the Behmor roaster, still some helpful info in there:
    Behmor and Lighter versus Darker roasts
  19. #1569
    Aug 2008
    Millthorpe NSW
    1,911
    Those Later roast look good Janus- let us know how they taste! And don't stress the aroma in the roaster - not an accurate judge of character
    Janus likes this.
  20. #1570
    Jul 2016
    Inner West Sydney
    193
    Thanks. Yeah it's not the aroma in the roaster it's the aroma after the beans have cooled.
    I'm guessing that beans which have a lot of oil escaping after 2 days are probably overdone, if no luck this time I'll drop them to cool another 2 degrees and so on
  21. #1571
    Apr 2010
    24
    Thanks Janus , Simon,
    I made a shot this morning, 15g in, 30ml out, 40 seconds. I was hoping to get more crema, but I am still experimenting with grind size and getting use to my new espresso maker. Luckily the shot tasted nice.
    I normally drink mostly pour over with V60/Kalita, so I was aiming for a lighter side of roasts.. but lately I have developed a taste for espresso so I should also try darker roasts.. I'll do another batch this afternoon and take it to second crack, still lots to learn but enjoying the process!
    greenman and simonsk8r like this.
  22. #1572
    May 2007
    Perth, Western Australia
    3,056
    Oily beans after a couple of days is not good, too much caramelisation of the sugars, a gentler roast profile and a gradual ramp up to first crack would work better, beans look scorched in places.
    DesigningByCoffee and Janus like this.
  23. #1573
    Jul 2016
    Inner West Sydney
    193
    Thanks, the photos at night with no flash do appear much darker than they are in reality. However there does appear to be some light scorching on the tips.
    Do wet hulled coffee roast differently?
  24. #1574
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    1,714
    I've done 3 batches over the last few days. The first of which was a Yirg natural that might not be any good as the safety time out caught me for only the second time ever since I've had the Behmor. I 'finished' the roast as soon as the machine was cool enough to allow me to turn it on again. I was going to bin it, but I decided to keep it and I'll be interested to see what it's like.
    The second batch was much more successful. Taken just past first crack giving a moisture loss of 15.4%. Looks good -
    Dimal, greenman, timothyp and 1 others like this.
  25. #1575
    15,664
    Indeed it does mate...
    Aug 2008
    Millthorpe NSW
    1,911
    A few batches for a SO and Mocha Java blend.
    Followed Andy's Limmu idea in Beanbay notes for a lighter and regular roasted blend, for some Sidamo Guji. Dropped first one at 215° and the next at a more regular 221°. Then a Sulawesi Blue. Then various bagging variations for cupping!
    20170909-Guji-Light-750g-5amb.jpg 20170909-Guji-Std-750g-5amb.jpg 20170909-SulBlue-750g-5amb.jpg
    Had as a Mocha Java F/W straight out of the roaster - already some beautiful fruity sparkle & aroma from the lighter Guji, but still lovely body… yummmm
    Dimal likes this.
  27. #1577
    15,664
    India El.Hills 'AA', Indo.Sumatra 'C', Dominican Barahona 'AAA' and Eth.Sidamo Guji
    Used a similar blend to last time but altered the proportions slightly between the El. Hills and Sumatra 'C'. Also swapped the Biftu Gesha for Sidamo Guji, just for something slightly different...
    Shortened up the overall profile a little too in an effort to enhance (even more) the fruitiness and sweetness. The previous batch is just wonderful in the cup but maybe this will improve it just a little more. Don't know if you don't try ... Pulled and cooled before the first snaps of 2nd-Crack.
    Blend details below, with profile used and post-roast photos attached.
    Blend Details...
    India El.Hills 'AA'... 300g
    Indonesian Sumatra 'C'... 200g
    Dominican Barahona 'AAA'... 150g
    Ethiopia Sidamo Guji... 100g
    Roasted Weight... 634g
    Moisture Loss... 14.8%
  28. #1578
    May 2007
    3,056
    Sulawesi Blue
    Did a roast of the Sulawesi Blue yesterday--500g - charge temp 170C 66% heat with a gentle ramp up to first crack, took the roast 1m30sec past start of first crack and then cooled aiming for filter/espresso roast. 11min roast time.
    Just had an espresso shot, still a bit lively but pleasant zesty acidity, rich body, fruity notes and a lingering chocolate finish.
    DesigningByCoffee, Dimal and Janus like this.
  29. #1579
    Oct 2016
    Central Coast NSW
    140
    So wanted to share my first few roasts and thought better in this thread then starting a new one. Got a Behmor Plus and a bag of Indian Elephant Hills, Ethiopian Gambella and Sulawesi Blue.
    First few roasts were 100g batches of IEH and thinking should have listen and gone with 200g batches as these were well nothing special. Hard to tell what was happening as it all was a rush. Think 1st crack rolled into 2nd in a heart beat but ??? Both roasts done using P1 then dropping to 25% at 1st crack.
    Tried 200g of Salawesi Blue using P1 then dropping to 25% at 1st crack. after 4-5 days tasted okay and starting to see what are in the beans tasting notes bit not sure if need to take a bit further as has a bit more then light acidity (or my version of light is out). Still drinkable and happy.
    Well rightly or wrongly i tried pre roast blend of 400g batch of 45% IEH, 33% Ethi Gambella and 22% Salawesi Blue. P1, 1st crack after 14 minutes and believe pulled just as 2nd hit. Cooled in Behmor.
    EH 100g batch
    400g blend batch
    Thoughts on the roasts (sorry for picture quality look better on phone)?
    Either way enjoying the new adventure and keen to keen trying / learning
  30. #1580
    Aug 2008
    Millthorpe NSW
    1,911
    Welcome to the journey Mb21!
    It does sound like 400g is a good size for the Behmor - small batches in any roaster are harder to control. Let us know how your blend went
    Matt
  31. #1581
    15,664
    Great stuff Mb21...
    Both batches look pretty decent but the true result will be in the cup of course.
    As Matt says, let us know your thoughts after tasting.
    Aug 2008
    Millthorpe NSW
    1,911
    Interesting
    I've sampled the two Guji variations back to back and as a blend.
    The first roast was a little slower and dropped 5° before second crack at 216°. The results as espresso were a smooth, sweet gummy-bear type fruity espresso.
    The second batch, in the hot roaster, went slightly faster, and I dropped just at the first snaps of second crack at 221°. In the cup, it was much more bitey, with greater acidity, less gummy fruits, but some good poke at the top end.
    And together – they complement each other greatly!
    Dimal, greenman and Janus like this.
  33. #1583
    Sep 2013
    1,714
    This is a Peruvian that I got from the little roastery in my town. They're called Three Llamas and only roast Peruvian coffees that the owner sources direct from the co-ops and imports himself. Most are from the Cajamarca area or San Ignacio. The last lot I had was an organic certified coffee, this one is not. Apparently this ones a bit more balanced, still quite sweet if roasted well, but lacks the bright acidity of the San Ignacio organic apparently. Will be interested to see what it's like.
    Dimal and greenman like this.
  34. #1584
    Sep 2013
    1,714
    The last of my Rwanda Buf Remera Gitantu. I managed to follow the profile of the last batch of this that I roasted. That turned out nicely so hopefully this one is just as good.
    Dimal and shewey like this.
  35. #1585
    Senior Member speleomike's Avatar
    Nov 2005
    869
    Hi all
    Over the last few weeks I have been really impressed with the Costa Rica Cafe Hermosa. Have done two blends; Costa Rica Cafe Hermosa 1 kg + Indonesian Sumatra 300 gm + PNG Wahgi 300 gm and the other blend was Costa Rica Cafe Hermosa 1 kg + Rwanda Nyungwe 0.5 kg. Both are just exquisite.
    Mike
  36. #1586
    Jul 2016
    Inner West Sydney
    193
    The Sulawesi has performed much better this time around (and no oil on the surface), might try a 10c lower charge temp and slightly longer drying on the next batch to see how it goes. The Yirgacheffe has these amazing citrus notes that you can easily lose if you take it too far (still good when you've moved past the citrus though), also the Aceh wasn't as great as before, lost some of the spiciness to the darker roast, the PNG will be my next focus after i figure the sulawesi out.
    Trying to lock down the temperature the Yirg needs to roast to, to maintain the citrus, but not be too bright. Had a Campos superior coffee the other day, swear i could taste a very similar citrus note in the cup.
    Have been away for a few days, so the last roasts are still being consumed, ended up combining them all, this morning's coffee was good, but i'm thinking the coffee has already peaked as the flavours seemed a bit muted.
    Mucking around with the Pullman pressure gauge trying to re-calibrate pressure on my Gaggia Classic, seems to be working better now, a bit less spitting with the naked filter, have to post it off tomorrow. The coffee production is another saga of learning isnt' it.. am able to taste more in pour over as there's less chance of me stuffing up the brew method.
  37. #1587
    Oct 2009
    Geelong
    566
    Felt like some good oooool India Elephant Hills AA! 300g in (3 separate batches), Behmor setting 1lb P2A
    FC and rolling FC
    -11/11:25
    -11:15/11:40
    -12:30/13
    (Am assuming a lengthening because of the ambient temperature dropping, was later in the afternoon..)
    End of FC:
    -12:50
    -13
    -14:20
    End of roast:
    -15:20
    -15:30
    -16:50
    (Stopped about 2:30 after end FC, or 1m before predicted start of SC)
    Moisture loss:
    -16.33%
    -16%
    -15.5%
    Funny that the shorter roasts had the most moisture loss and viceversa hey! Wonder if I know in advance that the ambient temp is gonna drop whether it's worth taking the latter roasts a little further before dropping.. (usually previously they get faster roast after roast even after a fair cooling period)
    I've mixed them all together in a big batch anyways ;D
    Dimal likes this.
  38. #1588
    15,664
    Would probably have been a good idea to set a small amount from each batch aside, for individual evaluation.
    Most surprising sometimes how small seemingly insignificant changes to a profile can realise quite apparent differences in the cup...
    Oct 2009
    Geelong
    566
    Yeah true, next time I might do that. I usually do keep them in their separate bags but wanted a decent amount to chuck in the hopper each time, so thought best to just mix them.
    They seemed to roast pretty similar, not sure if that moisture loss variation will be significant, and also how long to keep the roast going if that happens again.. maybe calculate a percentage of the time rather than stopping at a set time? E.g. if first roast has FC occur at 11 minutes and I end roast at 15m20s, if the next roast is FC at 12m30s, I would end the roast at the same percentage that the first did (no time to figure that out at the moment haha)? Not sure if that's too mechanical though!
    But I'll keep that in mind. I guess it's all a bit of a blend now
    Dimal likes this.
  40. #1590
    Oct 2009
    Geelong
    566
    Roasted up a little Yirg Natural for filter the other night (inspired by greenman's thread), gonna V60 it tomorrow, super excited
    Dimal likes this.
  41. #1591
    Jul 2016
    Inner West Sydney
    193
    I may have cracked the PNG. I've noted the density is quite low on this one, which is reflected when roasting by a slower rate of rise. Previously i've adjusted the heat to try and get to first crack faster, this time i thought i'd apply the heat i would normally to a denser bean, and see. Roast time was just over 17 min, 2nd day post roast and i'm impressed by the beans, look forward to a few more days rest:
    The Aceh i've lost my way a little, think i got lucky on a few of the earlier roasts, recent roasts haven't impressed as much. For some reason the RM software is not opening many of the profiles, some error about too many lines, has happened before however this time i haven't touched them and i've done everything the same as before.. could be my computer indexing or something affecting the file. Still a great bean, think i must have nailed it a couple of times before though, see how we go this week. The initial cool bean aroma after roasting was average, however was better this morning than post roast. Interesting to compare flavour change with aroma change over time:
    Yirg, probably the easiest bean to roast, or else the one i've dialed in the best early, take it as far as you can while still retaining the citrus notes, it's a fantastic pour over and blend bean. Quicker roast seems to work for this one, dropped about 8c above first crack:
    Forgot to measure moisture loss. The PNG in particular has given me an insight (someone else mentioned to me apologies as i've forgotten who), that roast profiling batches are done much faster than production roasts, so may be worth allowing longer roast times. Seems to have helped the PNG, a coffee we loved so much on the stovetop shaker roaster, but have struggled to find the flavours we love in the drum roaster.
    Dimal and simonsk8r like this.
  42. #1592
    15,664
    India El.Hills 'AA' with Guatemala Jacaltenango SHB
    Time to roast up some beans bought by my family for my birthday...
    A very nice surprise this b'day in that I was given funds to buy beans I haven't tried before.
    In a heartbeat, selected the "Guatemala Jacaltenango SHB" and the "Indonesia Aceh Danau Laut Tawar"...
    Roasted a few small batches (~80g) of each in my venerable popper, to get a handle on what works and thereafter decided to combine the Guatemalan bean with a base of India El.Hills.
    As per previous batches, used a steeper gradient profile that was pulled before 2nd-Crack started, roughly about 3'20" after 1st-Crack. Lovely aromas while in the cooler with beautifully plump, satiny finished beans, the end result. Going to be a good'n I think.
    Blend details below and roast profile attached...
    No photos this time though, forgot to grab the camera.
    Blend Details...
    India El.Hills 'AA'... 400g
    Guatemala Jacaltenango SHB... 350g
    matth3wh, samuellaw178 and Janus like this.
  43. #1593
    Oct 2009
    Geelong
    566
    Ah haaappy birthday Mal! Hope you had a swell day!
    Ah and that sounds like an interesting blend! (Also i dont know why it never occurred to me to do a few small batches in the popper to see what depth would work well rather than bigger Behmor roasts.. am so doing that next time. Although not sure how to dial in and pump such a small amount for espresso but just to get a gist of it I'm sure I can get it ball park within the 2nd/3rd shot ).
    Enjoy your b'day beans!
    Dimal likes this.
  44. #1594
    Dec 2004
    Earth!
    14,398
    Happy Birthday Mal!
    Java "Enjoy the beans!" phile
    Dimal likes this.
    Toys! I must have new toys!!!
  45. #1595
    Jul 2016
    Inner West Sydney
    193
    Happy birthday Mal, look forward to your thoughts on the Aceh beans.
    Dimal likes this.
  46. #1596
    Sep 2013
    1,714
    Hope you enjoyed those birthday beans Mal.
    Another batch of a lovely Peruvian for me today. This one is sourced directly by my local roaster from the Cajamarca region. It’s probably 100% bourbon, but probably a mix of yellow and red. A very nice coffee that’s well rounded and quite versatile.
    Dimal, matth3wh and Janus like this.
  47. #1597
    15,664
    As always Leroy, that batch looks pretty darn good...
    LeroyC likes this.
  48. #1598
    Dec 2010
    35
    Yeah thats a beautiful even roast!
  49. #1599
    Oct 2015
    16
    Almost looks edible..
  50. #1600
    Oct 2009
    Geelong
    566
    Behmor Coffee Roaster
    +1 yep definitely does haha
  1. Roasters Week NEXT WEEK 15-19th of March 2010
    By beanflying in forum General Coffee Related...
    Last Post: 17th March 2010, 03:25 PM
  2. Your coffee week
    By madpierre06 in forum General Coffee Related...
    Last Post: 17th March 2010, 11:28 AM
  3. A Week Without Coffee (or tea)
    By gregpullman in forum General Coffee Related...
    Last Post: 23rd September 2009, 08:23 PM
  4. Replies: 0
    Last Post: 27th March 2009, 02:37 AM
